Question about Printronix Line Matrix P5010 Printer
Close platen signal
Our printer is saying to "close platen" even though it already is. We tried turning it on and off and even blowing out the inside to get rid of any debris. It is still giving us the "close platen" signal though. Any suggestions?
    Scholar:
  • 34 Answers
When you open and close the platen lever you will notice micro switch that should be engaged... When the lever is down to A - C. looks like this... only 2 other things it could be besides the switch... close platen signal - 152417-001.jpg&w=70&h=39 152417-001 P5000 Platen Interlock Switch
If anybody has been in the printer where PCBA's are, check the two cable connectors holders... seated good... worst case,it would be very rare if its CMX Board(main logic)...
Posted on Dec 01, 2008
Canon MP530 will not auto redial, even though the setting is set to on
Try unplugging the printer from power.
Plug it after a while and turn it on.
Remove the document and re-load it on the platen glass.
Make sure the line's jack is well connected.
Hope it helps.Thanks!
Oct 06, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Says copier lid open
The small "sensor" that should "trip" when you close the lid is not engaging. Blow a little compressed-air into that micro-switch, so that it works correctly.
May 07, 2010 | Lexmark X3470 All-In-One InkJet Printer
Printer says inkjet not installed properly but it is and both are full.
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Feb 23, 2010 | Canon PIXMA iP1600 Printer
Paper jam
The way you describe your error, it seems that there is still some residual paper stuck inside the printer that may cause subsequent paper to be mis-aligned.
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
Computer wont reconize ink cartidge
Hi there
4.Close The Cover
Nov 02, 2009 | Canon PIXMA iP1600 Printer
Continue printing greyed out
Hi there
4.Close The Cover
Jul 01, 2009 | Canon PIXMA iP1600 Printer
057 close platen error message
Its located in the adjustment section of the platen control or in the platen itself.
Lexmark may still be supporting this model printer.
Dec 02, 2008 | IBM 6400 Matrix Printer
Platen opeo error
CLEAN THE PLATEN SENSOR IF NOT SOLVED CHANGED THE PLATEN SENSOR.
Sep 15, 2008 | Tally T6218 Matrix Printer
Canon Pixma iP1600 Printer problem
Hi there
4.Close The Cover
Sep 01, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Mf6530 always says platen glass dirty but I've even cleaned both sides
Found the solution at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=13170&kbpage=yes , then enter "clean platen glass" in the search window, and select item #1 "ERROR LCD: PLATEN GLASS DIRTY, CLEAN PLATEN GLASS ". This gives step-by-step instructions on how to clean the area dealing with the platen glass.
Aug 20, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Printronix Line Matrix P5010 Printer Logo
453 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
