Zanussi ZWX 1506 W will not turn on properly. The power button works, but the controls will not function. If you hold the reset down for a while, it chirps and the lights flash. If you hold the reset for long enough, it sequences through all the lights one by one.
5 Suggested Answers
  • 183 Answers
SOURCE: washer will not work
Possible drain fault, check filter. Regards Advisor
Posted on Aug 30, 2007
SOURCE: Power up problem
One thing u can do also. Open your system case, remove cmos battery clean cmos battery and then insert like same. And restart your system. Other wise check power connections voltage. If it is ok then definitely it will wirk.
Posted on Sep 07, 2007
  • 619 Answers
SOURCE: Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Posted on Jan 09, 2008
SOURCE: zanussi zwx 1505w drum not
the drum kep on jamming.
i tuck the drun a part and found a sockjamed be tween wall drum
that solved the promen
Posted on Apr 30, 2008
Slinteriors
  • 8617 Answers
SOURCE: green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
Posted on May 16, 2008
For HL-T5087SA DLP I have lost all inputs to tv. Can't turn off or on with main control in center. All remote functions do not function.
is there a reset button on the tv? on some electronice devices, if you hold down the power button for about 15 seconds, the unit will reset.
May 17, 2015 | Samsung Televison & Video
Colored circle comming up
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
sad mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Feb 28, 2014 | Apple Computers & Internet
Locked
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Feb 23, 2014 | Apple Air Computers & Internet
I have conon mx 868 but i have got error message 6502 and 150 how can i solve the problem?
Here are instructions:
The MPTool is designed for service works with the printer Canon MP-Series
when in Low-Level mode. This is NOT the same as "service mode"
Currently supported for
MP150, MP160, MP170, MP180, MP450, MP460. MP150, MP160, MP170, MP180, MP450, MP460.
BEFORE activating MPTool...you need to
To activate LOW LEVEL mode:
1. Unplug the power cord to the printer for a moment.
2. Then, hold down the on/off button while plugging in the power cord. Keep holding the on/off button down.
3. Right away the green power light (in the button) will turn on solid. Keep holding the on/off button down.
4. Press and release the Stop/Reset button.
(the button w a red triangle in a red circle)
5. Now you can release the on/off putton.
The green power light will go off and the yellow Alarm light will stay on.
Now you can run MPTOOL and resetting the ink counters will work.
Your printer will show up as "another" Cannon printer.
When you finish you must again unplug the power cord for a moment and then just plug it back in. After you do this, you'll see both printers listed in Printers (controll panel) and one will show as offline. You can then rename this offline printer as "Low Mode Canon"
or whatever works for you so you don't mix it up with other functions.
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again. this works. thanks.
For
1, With the printer unplug, remove the ink cart to the right ,
2,Plug in the printer ,Press the POWER button, Do not release the POWER button ,and then press the RESUME button twice in succession .Now release the POWER button ,press the RESUME button 4 times .
3,The beeper may sound once ,Then With the printer unplug ,after that reset the printer electronics ,open the printer and this process is finished.
Reset manual "Ink Absorber Full"
Steps by steps how to reset :
1. Turn off the printer but still connected to a power source
2. Press stop/reset button, and then press power button to restart
3. Press power again and then press twice the stop/reset button.
4. Press power & Stop/reset button together, to enter
the repair status and power lights will be green,
5. Press stop/reset button
6. Turn off the printer
7. Unplug the power cable.
8. Plug the power cable and then turn it on again
Canon MPC INKTank FULL
button pressing
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error mesaages like 6502 or other types of error meaasge to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be releasedbefore doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled,the low ink warnings are showing againand they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be usefull if you need some warranty work done on you printer after the chips had been disabled. Canon does warn that disabling the chips may result in the printer's warranty being voided
Apr 08, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Denon AVR 1506
Try this, turn off the unit and remove the AC power cord from the electrical outlet, Hold the AUTO button and PCM button and plug the unit back into the electrical outlet, if the display starts flashing with 1 second intervals then release the 2 buttons, this initialized the microprocessor
Feb 09, 2009 | Denon AVR-1506 Receiver
Zanussi zwx 1505w drum not spining
Apr 28, 2008 | Zanussi Washing Machines
Kenwood in dash cd player
The protection function is activated when the speaker wire has a short-circuit or touches the chassis of the vehicle. Wire or insulate the speaker cable properly and press the reset button. (The reset button is that little pinhole button below and to the right of the volume control). If you do this and the "PROTECT" code doesn't disappear, you'll have to consult a service center. Further, if you had this professionally installed, they should be obligated to fix the issue for you (hopefully).
Jul 23, 2007 | Kenwood KDC-MP205 CD Player
Washing Machines Logo
131 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
