Question about Refrigerators
I have a frigidaire electrolux frost free freezer, model # ffu17fc4w1, the light comes on, makes noise but the freezer never gets cold
    Genius:
  • 1,073 Answers
You have a sealed system issue ned tech to look at this one
Posted on Apr 16, 2008
My Electrolux EW23CS65GS1 model JCD-23 the freezer makes a strange noise at the rear it sounds like it comes from inside what is it and what can I do?
Thanks for your post, Rob Muzich!
From the information you have provided your Electrolux refrigerator is making a strange noise at the rear. Depending on what type of noise you are hearing it could be a normal operating sound. In the manual it provides a list of sounds on page 23. I have included a digital copy of the manual for you to review. If you need any additional assistance please feel free to reconnect. -Matt
Frigidaire Manual Search Results
Nov 28, 2014 | Electrolux Refrigerators
Need light part # . You reach me @ logy@comcast.net. Heres the # off the Fiigidare Frost Free FCI - 20 Or Model # 61AC4986. Larry
Go to apdepot.com and enter your make of the refirgerator and your model number and you will get an illistration on your machine that will list all part numbers.
Dec 08, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a Frigidaire upright freezer model# ffu20f9gw3. The temperature alarm light is on. Cold air is blowing but the ice cream melted, and the hot dogs are still frozen and loaves of bread that i...
I have had the same problem with my frigidaire/electrolux upright freezer... I am researching to see if there is a pattern. Once or twice a year for the past few years, the freezer defrosted itself. I found the outside of the unit to be VERY hot to the touch around the time that this occurred.
We typically unplug it for a chunk of time when this happens and then replug it. It has always begun working again.
Sadly, we have lost many groceries and have had to clean many bloody meat messes as a result of this. ANYONE buying this freezer should save their receipt... That way, they can return it or have it repaired when it fails. I hate to think of sending all of these failing monstrosities to the landfill... =(
Aug 13, 2010 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Buzzing in a full freezer with icemaker model no. 253.44133802
try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
Feb 03, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer cold- Fridge Not, Loud Noise
that is the damper door malfunctioning this open to allow cold air into the fridge compartment the damper needs to be replaced
Sep 20, 2009 | Frigidaire FRT17G4B Top Freezer...
How to recharge freezer electrolux FFH17FC7CW0
HI, It is a big job to recharge a unit. If it need recharged, it means there is a leak. Do you have any cooling at all? If this a self defrosting freezer? If it is self defrosting, make sure there isn't any frost building up on the evaporator panel.
Vic
May 21, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Fan continuously running, non-stop
hi thanks for the question its normal for a frost free freezer to run a long time to keep a good cold temp i don't think you have a problem thanks the appliance doc
Sep 08, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
