Question about Royal 10X Shredder
Royal shreader pcua-29053u Damaged Gear
Only one of the gears has a tooth damaged. This gear is one of the large metal gears (about the fourth reduction starting at the motor helical drive shaft gear) The gear pitch diameter is about 2 1/4 in od x .375 in face. This is the one with the hex head drive shaft. Is there a place where I can obtain a replacement part?
The original unit must have been a misbuild because the origin of the problem was one of the four screws that secure the drive motor had come out and jammed in the gear that is damaged. Screw appears to be a #10-32 x 3/4 in long. Unit now works but clunks as it cycles past the damaged tooth. It will damage other gears if this continues.
mod Royal PCUA-25053U
  • 59 Answers
Call royal spare parts department at 1800-222-2310 they will ship you a gear for about $6 + shipping
Posted on Jan 22, 2009
My 2005 Pontiac Bonneville GXP will not shift into 4th gear I was to it was a fourth gear band but is that the only problem that will cause itI'notto shift into 4th gear
Which transmission does yours have 4T65-E or 4T80-E ?
4T80-E
No Fourth Gear
Checks
Causes
1-2 Shift Solenoid Valve
Inoperative
Debris
Pinched wires
3-4 Shift Valve Bore Plug
Misassembled
4th Band
Burned, slipping, missing
4th Servo Cover
Cracked
4th Servo Pin
Broken, seized
4th Servo Piston
Damaged
4th Servo Seals
Rolled, cut or damaged
4T65-E
Slipping or No Fourth Gear
Slipping or No Fourth Gear Checks
Cause
DEFINITION: A large engine RPM increase is noted in fourth gear, Drive range, with little or no vehicle forward speed increase. First, second, and third gear operation are normal. Shifts into fourth gear are soft or do not occur. Fourth gear ratio is 0.705:1.
Automatic Transmission Fluid Level
Low fluid level
Transmission Main Line Pressure
Low transmission main line pressure
Oil Filter Assembly
• The oil filter assembly (100) is missing, plugged, or damaged.
• The oil filter seal assembly (101) is missing or is damaged.
Control Valve Body Assembly
• The 3-4 shift valve (362) or the 4-3 manual downshift valve (360) is stuck or binding.
• Debris is found in the passages of the control valve body (301) or of the control valve body spacer plate and gasket assembly (396)
Case Cover Assembly
Distortion or damage occurs at the manual valve (404) or at the case cover (401), causing PRN oil leak.
Driven Sprocket Support Assembly
A plugged third clutch oil passage in the driven sprocket support assembly (609)
Fourth Clutch Assembly
• The clutch plates (500-502) are worn, damaged, or misassembled.
• A missing or not seated fourth clutch spring retaining ring (601)
• A damaged spring assembly (602) or piston (603)
• Worn or damaged fourth clutch piston seals (604, 605)
Third Clutch Sprag Assembly
• The sprag (720) was misassembled or backwards on the inner race (661).
• A damaged third clutch sprag assembly (653, 661, 719-721)
Dec 06, 2015 | Pontiac Cars & Trucks
Thanks! I have a 7x Crosscut Paper Shredder, Model # PCUA:29053U. The teeth are jammed due to I believe a build up of paper. I have run it on reverse & tried to pick out the paper. The motor runs but...
If the motor runs but the cutting teeth dont turn then you have stripped or broken a gear in the drive train. You can get replacement parts from Royal at 1-800-524-0799.
Oct 19, 2010 | Royal Office Equipment & Supplies
Gear needed
Call 1-800-524-0799 at Royal for parts assistance.
Jun 03, 2010 | Royal 15MX Shredder
I need a gear for shredder AG15x. Part number is
For parts and prices call Royal at 1-800-524-0799.
Feb 10, 2010 | Royal AG15X Shredder
Royal 10X PCUA 29054E, the gear appears to come off/brok
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Feb 16, 2009 | Royal 10X Shredder
Royal SC800 power shredder I need the large metal gear.
I have the SC800 apart. My problem is not fixing it. I just need the part. The large gear which appears to be made of pewter has a couple of teeth missing. If I could find the part I can fix it. It's a very simple machine. If you know where I can get the part I would appreciate you letting me know..
Sincerely;
Ken Ashley
Oct 14, 2008 | Royal JS800 Shredder
Royal 10X Shredder Logo
1,118 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
