Hello...
you can download the manula from the below link..
http://www.totalpos.co.nz/Downloads.html
Cheers:-)
SOURCE: i looking for a printer head for casio ce-4700?
Hi. they are getting quite rare now. You can still find dealers with some stock, but as this is a major part of the machine, they are not cheap. Unless the register is in good condition, it won't be worth fixing. If you haven't been running paper in both sides of the printer, then the platten will also be damaged. This is the most common reason for head failure.
SOURCE: Casio ce-3700 e01
Hi. You have turned the key before you finished what you were doing in another mode. A flag clear will jump you back to reg mode. Try this:
Turn power off at wall.
Turn key to program mode.
Hold RECEIPT FEED button down.
Turn power on at wall and let go of RECEIPT FEED after 5 seconds.
You should see 'FFFFFFF' on display
Press SUBTOTAL
Turn key back to reg mode and try it.
Mark
SOURCE: hi i have a casio ce-4700 and the it just printing
Which error? Does it only happen when you issue a receipt?
Casio Ce 4700 keeps saying ERR CLK???
