Question about Whirlpool GEW9200L Electric Dryer
Duet dryer mod YGEW9200LW1 wont throw heat. It goes through sensing but no heat.
  • Jackfish May 09, 2008
    Thanks. I did find a open element wire. The thermostat and fuse were fine. It all happened when vent was severely plugged. Cleaned it out and she's purring away now!
  • Anonymous Jul 17, 2008
    no heat
  • 117 Answers
Coul be a fuse pn: 279973 or heater pn:3387747
I don't believe that is a heater because its a new machine.
You can get the parts at sears . com and search for parts.
If you open the botton plate of your dryer you gonna see at the right side the heater and screwed into the heater is a thermostat and a fuse.
Before replace the heater , make sure that your vent is cleaning otherwise its gonna blow again
Posted on May 09, 2008
Why wont whirlpool duet dryer model WED8300SW1 heat?
Is the dryer gas or electric? But you can also try cleaning the vent tube the pipe that goes outside also the pipe that goes into the dryer it's a good chance it's full of lint.
May 07, 2014 | Whirlpool Dryers
Whirlpool duet dryer goes to sensing..but wont turn on
The control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box. Here is the part to order.
Nov 26, 2012 | Whirlpool Dryers
My dryer wont heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet dryer not drying like it used to
If your duet isn't heating properly and you have taken care of the lint problem then you could have one of two problems. Either you have a bad heating element or you have a bad fuse or temperature sensor.
If your dryer is not heating at all then it is most likely the fuse or temp sensor. If it is heating and just not enough it is probably a bad heating element.
Both problems would require a repairman to come and fix normally, however if you believe it is the heating element that can usually be replaced by the homeowner without too much trouble. Just make sure to ask where it is located from whatever place you but the new element from.
Dec 12, 2009 | Whirlpool Dryers
Whirpool duet dryer mod GEW9200LW0, working but not heating up
If it's starting and not heating it's usually one of two things. Take off the bottom panel. 2 screws hold it in place. If you have a way to check the element with a meter or something that would be ideal. It should read about a short circuit. The other part that goes out a lot is the thermal fuse located in the front on a pipe it's long and narrow. Here is a link to show where things are in there. Let me know if you have any more questions
http://www.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=GEW9200LW0&productCategoryId=0151200&brandId=1198&modelName=DRYER
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool duet dryer quit working
chould be a fuse inside dryer its oblong white ck it but unplug dryer first
Mar 21, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Dryer wont start
Possible door s/w or thermal fuse. If its blowing thermal fuses with a clean and avg vent run check the relay, cycle unit with no heat fuction if the heat still comes on replace the relay board. Call your local servicer.
Mar 16, 2008 | Dryers
Whirlpool GEW9200L Electric Dryer Logo
289 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
