Question about Samsung CLX 3160fn All-In-One Printer
Samsung CLX3160FN - LOUD grinding noise
Printer makes a terrible grinding noise prior to and after priniting...also black is printing extremely terrible...Any help or suggestion would be great warranty ended 2 weeks ago...
  • 10 Answers
SOURCE: GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Posted on Jun 07, 2008
  • 4 Answers
SOURCE: samsung 3160fn all in one
Here's what I posted in regards to my CLP 300 which had the same problem. Might be the same thing??...
Mine did this after I replaced a toner cartridge (the round ones). Here's what causes the loud clicking:
Some (most?) replacement ink cartridges have a little square chip -- like a mini circuit board -- on them which gives the printer information about how full they are. This is located on the insertion end, right next to the round black thing with the little gears on it.
For the cartridge to go in all the way, and allow the gears to properly "seat," the square "circuit board" needs to "float" just a little on the spongy thing it's attached to. So when you push the cartridge in FIRMLY, the gears seat, and the "circuit board" will end up getting pushed in about 1/16 of an inch.
I think what happens in some cases (at least with mine) is some cheap replacement cartridges don't let the "circuit board" push in at all, which means the gears don't quite seat properly, and, as they are trying to connect on the printer's gear receivers, they are constantly connecting and disconnecting, causing that loud clicking noise.
On one cartridge just pushing in the "circuit board" really hard freed it up and allowed it to "float" (be pushed in little when the cartridge was then inserted). In another case, I ended up getting a butterknife and prying off the circuit board (breaking the plastic or glue seal that was holding it) then setting back in, on top of the little spongy sticky thing it's supposed to float on.
In both cases, the cartridges were then able to go in all the way, and the clicking noise stopped.
Hope this helps!
Posted on Aug 06, 2008
  • 30 Answers
SOURCE: VERY LOUD NOISE WHEN PRINTING WITH MY SAMSUNG CLP-300
You all say that the toner cartridge is okay, so it could be the hole OPC Image Drum or the ITB which is the tranfer Belt.
The Tranfer Belt is behind the Image Unit.
Posted on May 28, 2009
  • 30 Answers
SOURCE: Why Samsung CLP-300 Printer making annoying/loud clicking noises?
So try to get the black toner cartridge out of the Machine. On zhe backside of the Cardridge is a gear. Try to turn the gear, maybe the Toner inside is clump together. When you can turn it very easy in both directions it's fine.
Posted on Oct 19, 2009
SOURCE: Everytime I print something, the printer makes a
the problem is the fusor...but the warranty is only for 6 month...
Posted on Apr 21, 2010
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
LOUD GRINDING NOISE
The black dust is toner. Be carful as it is carcenagenic (dont get it on your skin) you will need to dispose of the leaking toner cartridge and get a new one. also you will need to clean the printer very carfully to get rid of the spilt toner. A combination of spray duster and a toner hoover are the best way. do not use a normal hoover as you will kill it.
It is always possible that you have done serious damage to the printer using a non standard toner cartridge. I would recomend getting a qualified person to give the printer a good service.
Jun 03, 2009 | Sharp AL-1655CS Laser Printer
Grinding noise on OKI C3300
I have had a similar problem. . Black drum needed changing. There was also a grinding noise developing. I have taken each drum and toner module out of the printer and booted it up with one of the 4 missing. It was the Cyan drum that was making the noise. . Question is what can I do? I am not a printer expert. .
I will contact the local printing shop that I use for more info and will come back to you. I suspect that I will need a new drum . . .
Nick Smith
nick@selectaccountingservices.co.uk
Nov 28, 2008 | OKI C3400n Laser Printer
Makes noise
Click HERE for HP troubleshooting for your printer.
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Canon MP530 Makes Grinding Noise when printing starts
I had this same problem and called tech support. Instead of sending a new printer they had me
1 remove print Cartridges
2 remove print head
3 replace print head
4 replace print Cartridges
5 unplug power from the wall
This seemed to fix the problem.....for me anyway.....for now.
hope it helps
Dec 15, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Printer makes noise while cleaning heads
Grinding noise is most likely caused by the carriage lock getting stuck and holding the print head at the home position. The noise is caused by the toothed belt that pulls the head back and forth, skipping over the splines on the motor drive wheel. If you have been able to print since the problem occurred, chances are that it has freed itself up and will be fine. Regarding the loss of cyan & magenta output, follow the solution given in my previous posts to complete a manual under-head cleaning cycle. This should get you going. Check this previous post for cleaning info: http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Jul 05, 2007 | Epson 1000 ICS All-In-One InkJet Printer
Samsung CLX 3160fn All-In-One Printer Logo
98 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
