Copying a drive image to move your installed software to an other computer
I have a computer with a failing hard drive. I'd thought I might copy the image of the disk to another one of the same type and put it back in the same machine. I might also like to do that and run the installed software on another machine.
Is either of those physically possible? If so do you do that? If not why is it that copying the entire disk image would not transfer all the information on it?
  • Phil Henshaw Apr 16, 2008
    Do you know of it working to switch drives without loosing all your setup's?
Copying the entire disk image is easy using a program something like Norton's Ghost. If the hard drive is failing, it's pertinent to do this QUICKLY.
Posted on Apr 16, 2008
Hi experts, I have scoured the internet and I have not found anyone who is in the same situation as I am. I just bought this laptop by HP "hp envy touchsmart m6-k022dx sleekbook" to replace my previous...
if you want a hard drive that will not fail the hard drive should be a solid state (SSHD)
they are priced at around $60.00 a gig and come in sizes from 120 to well over 500 gig
as there are no spinning discs, failure is remote
besides that a sshd will store more for the same gig size than a disc HD
now best talk with a computer geek to get exact information but you should be able to remove the hd in the computer and replace it with a new one
now connect the hard drive ( removed ) back to the unit as you would a backup hard drive and then down load it back into the computer
remember when fitting a new hard drive you may have to reset the bios to boot from the cd os disc or boot from the removed hard drive as the new hd will not have an os on it
AS I said talk with a geek and get how to do it
computer capacity is also determined by the ram size so if you have the slots fit another ram stick
Mar 02, 2017 | Computers & Internet
Error
If you have an external hard drive, you can use software such as Acronis, to make a copy of that drive to save everything in an image. Get a new drive to install in place of the old one. Next you can use Acronis to copy the image on the external hard drive, back to the computer, onto the new hard disk in your computer.
Jul 19, 2013 | Microsoft Windows Vista Ultimate Edition
When I switch on the Cybershot Camera, I get message "Error when formating" and tried to format via menu but i do not want to loose my pictures, so I canceled this option. What can I do to fix...
Hi peter_phasha ,
If you need to format your cybershot camera without losing your pictures , please follow the below steps :-
  • Make sure that you copy all the pictures from your camera to your hard disk , so that in case of an accidental format your data is saved.
  • To copy images from your camera to your computer or hard disk all you need to do is connect the camera using the cable which is supplied along with it , to your computer , and then install the software that came along with it, usually in a CD.
  • When you install the software you would find a storage drive is being reflected in my computer in case you are using windows xp , this will have all the pictures that you have taken from your camera.
  • Select the folders of the pictures of the specific pictures you want to copy and then select copy option from the edit menu , or press CTRL + C when the images or folder has been selected.
  • Now you need to paste these images on your hard disk , so you can do this by just creating a new folder on your desktop and then opening it , and pressing CTRL + V option so that the files get copied to your desktop , which is stored in your hard disk.
Note :- It's always better to copy your important images/fies to a seperate partition , instead of copying them to your root drive in which the operating system has been installed.
This could save your data from being deleted accidentally in case you format your root drive for reinstallting the operating system or the partition is lost , or corrupted.
May 17, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
How do I install a new HDD and still keep the IBM_SERVICE partition for restoring to factory installation?
If you're replacing the hard drive and want to keep the service partition information, you'll need to clone the disk. You can do this with another computer and a software tool like Norton Ghost, an old copy of Drive Image, Acronis, or some other disk imaging tool. THese tools will allow you to copy the service partition (along with any other partitions) from one drive to another. It's a little more complex than a straight file copy from one drive to another, but it's possible.
Mar 03, 2010 | IBM ThinkPad X41 Tablet PC
2 hard drives
Switching the two is a big big job that involves either significant BIOS changes and or reloading windows.
Instead of doing this, move all your files to the big drive. Keep only the system on the "C" drive.
Remember,. nearly all progams want do install default to the C drive ...
If you insist, you will have to copy all of windows to the other drive, change D to C (make it the master, Cable Select or Pin Select? Serial interface or IDE, SCSI?
Several questions you must resolve before you make this move.
Really, the simplest thing to do is move your stuff to the big drive (or you could dump it too!)
Thanks for using FixYa.com
a
Oct 29, 2009 | Computers & Internet
Does the external hard-drive copy and backup installed software that is on my original computer if i try to plug the external hard-drive into another computer?
No, installed software cannot be copied just like that. in order to use install software installed on one hard driver to another you must clone the hard driver and of course you may jot want to do that. You may copy the files but you will not get the software installed.
Oct 01, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How To Copy Installed Microsoft Office 2007 As A Set Up File??
There is no way to install your software on the other system unless you have the installation files. You can however make a ghost copy of your hard drive and copy a mirror image from one hard drive to another. There are many software packages available for making ghost copies of your hard drive, ie. Norton ghost.
Let me know if you need any further info on this.
Best wishes,
Graemevm
May 06, 2009 | Computers & Internet
I'm about to move to a new(er) computer -- does SoftRescue work?
Only your files will be able to be copied. Installing the software again is required, because it will need to look for the program file's locations on the current Hard drive. If the address is not the same, it will not be found. To go into in depth will cause utter confusion, but the short answer is, you will need to re-install your programs. Data files are ok to copy because you can point the program to the files that need to be opened.
Dec 26, 2008 | Compaq Presario M2000 Notebook
Loading pictures onto flash driver
Drag and Drop
You simply right click on what ever image you wish and while holding down the right mouse button and drag the image from where ever it is to the flash drive. you can select
( copy here ) or ( move here )
Copy is good because it keeps a copy of the image in the original location in case you screw up ...
Sep 08, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
EMachine won't complete restore, clocks on "What is the name of your computer"
There is a good possibility that the disc is corrupt. First try a different disc or test your disc in another machine. However, you can't totally rule out the hard drive yet. If the hard drive has a bad or failing sector, it will do the exact same thing. Most of the time when I run into this type of problem it's the disc. Another way you can check the disc is to copy the disc or make a disc image to the hard drive. If the disc hangs up or won't copy or make an image then the disc is corrupt. This will have to be done on a different computer with burning software, obviously.
Jul 16, 2008 | Fujitsu Siemens AMILO Pro V7010 Notebook
Computers & Internet Logo
David Payne
David Payne
