Question about Frigidaire Affinity ATF7000E Front Load Washer
Affinity washer front loader glacier blue
I purchased the frig washer/dryer in blue - delivered it sat 4/12/08 - washer would only work on hot and then i had to use the extended spin (they came hooked it up but didnt see if the whole cycle would work) so I had to wait until tuesday 4/15/08 for them to come back out (the store where I purchased it) they took off the metal hoses and thought they were on backwards? I have brand new 48 inch metal hoses with back splash(?) - all the water levels were working, when it go to the rinse cycle (22) they said its ok and I left, with the washer finishing itself, I get home and the thing was beeping E10 all day - and it reverted itself back to only hot - I called and they said they are coming out Saturday with a new one - now I am nervous that they are going to replace it and the same thing is going to happen, do you have any suggestions, or advice - I think i may have purchased a dud and do not want to go thru this again since its been sitting there since sat and i have not been able to use it. thanks!!! Lisa
    President:
  • 1,294 Answers
Since this is brand new, and that they are going to replace it, it should be fine.
Posted on Apr 24, 2008
Code E 21 Error on Affinity Washer Front Loader
I've had problems starting my washer because the door does not close properly, and then I get an error or pau code
What has worked is to unplug the washer for a minute, close the door, and then plug it back in. it then starts normally with 2 pushes on the start button
Jul 06, 2014 | Frigidaire Affinity ATF6000F Front Load...
Can I reverse the door on my new Frigidaire Affinity front loader?
Hi, as far as i know you can only reverse the dryer, the wiring for the door latch doesnt allow you to reverse it on this washer.
Sean
Mar 26, 2011 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Bleach/Fabric softner dispenser full of water after wash
I cannot help you solve your problem with your Frigidaire, however DO NOT buy an LG washer unless you happen to be intimately involved with an LG employee!!
I purchase a $1200 LG washer 3 years ago. Until this year it worked very well. Then the bearing in the stator motor blew. This, mind you, is *still* under warrantee but I have been unable, even with the dubious help of LG, to get one of their "authorized" repairmen to come to my house and fix it. True, I live in a rural area, but it isn't like I'm hundreds of miles from any of the three repair services they named. Apparently LG doesn't pay them well for warrantee repairs because they all wanted more money and refused the work!
I am going to turn all of the information and communications I have had with LG (by email thank goodness!) to my State's Attorney's Office.
Good luck in getting this repaired.
Sep 22, 2008 | Frigidaire Affinity ATF7000E Front Load...
No panel lights!
Solution - MEASURE voltage in outlet with digital meter and if it is not ~115 V or very close do nothing - wait till it gets to norm.
Longer explanation:
I had similar problem today. Dryer fine, washer (front loader Affinity 6000) dead. Electric power there. Day before had no electricity for few hours. Turned out to be that this thing is sensitive to voltage. I have now from 101 to 103 volts and it needs something close to 115. I have almost disassembled it but it was hard to do and no manual on web (except to purchase for $15). So, after removing back paned and few screws from front I have turned my attention to my UPS I have for TV - it sometimes would blink with blue diode (means it is starting). I thought why... Then I have luminescent (energy saver) lamps around house and those are not sensitive to voltage so lights are fine. In bathroom however I have halogens and those seemed dim. This time I have looked at my tester again and noticed that it shows ~101.2 volts. So I am taking UPS from my TV and moving it to laundry, plug UPS to outlet, washer to UPS - washer still dead. I unplug UPS from outlet and washer comes alive...
Hope this helps.
Orest Dmytryshyn
Edmonton, Canada
Jul 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
85 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
