My Liteon hd760gx recorder does not recognise any blamk disc i try to record on.A message tells me to insert a disc into the machine even though there is one in. I have tried different makes of disc but get the same message. I have tried the usual turn it off athe mains to see if the memory will clear but to no avail. i can still record direct to the hard drive.
  • mrbrock Apr 18, 2008
    sorry this advice did not help.
    Genius:
  • 3,422 Answers
The first thing i would suggest you to do is a hard reset by unpluging the the player for 30min and then try again.
If this does not solve your problem then please see if the player tries to read the disc.
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
If the problem does not get solved then you have to get it repaired.
Goodluck..
Please don't forget to rate the solution.
Posted on Apr 16, 2008
    Sergeant:
    Champion:
  • 304 Answers
Significant differences can exist between CD-RW writers; for a variety of reasons, one might work well with certain discs and poorly with others. When choosing a brand of CD for burning, always look at the list of compatible media that the manufacturer of your CD-R/CD-RW drive has provided (assuming such a list exists). These are the brands the manufacturer has already tested and recognized as working well with your hardware, so if you’re having trouble with a brand that isn’t on the list, save yourself some aggravation and try using a brand from the list. Naturally, a manufacturer might recommend its own media, and this media might cost substantially more than the brand you’re accustomed to using, but compatibility is often worth the extra cost if you find yourself burning coasters.
My LiteOn LVW-1101 Erasing DVD's Hi, Hope you can help me with this problem as Im not techically minded? I own a LiteOn LVW-1105HC and after recording DVD's(even DVDR's) I put the disc back in to...
Your lite on has lost its mind and needs replacement.
Meanwhile a non rewritable disk cannot be erased. If not finalized it may not be read on another machine but the originating machine can read it.
May 08, 2017 | Lite On LVW-5115GHC+ DVD Recorder
Where can I get repaired in India LiteOn DVD Recorder ?
There is no ,LiteOn authorised repair centre in India. You can get in touch with a local repair technician for the same . Alternatively you send Liteon support people an email. Incase they have a tieup with an indian service & repair company.They would let you know.Find the link below
http://www.liteonit.com/global/index.php?option=com_wrapper&Itemid=70
Thanks for using fixya
Proton
Sep 05, 2009 | Electronics - Others
Liteon HDD/DVD recorder/player
lite-on dvdrw in model HD-A760GX will not recognise dvd disc. KEEPS STATING TO INSERT BLANK
Jan 26, 2009 | Lite On SOHD - 16P9S Internal DVD Drive
Lvc9016g
I have successfully made hundreds of play-able DVDs from my home video using this Liteon LVC9016G. Overall I like this machine although it is very quirky.
First, I can tell you the only DVD that can work is SONY DVD+R 120min / 4.7GB. NOTHING ELSE WILL WORK RIGHT. I have used some DVD-R: You can record on it since everything appears to work. The got-ya is you cannot play it at all. I am sick of this because I have re-used some tape but ended up with useless DVDs! Take my word for it, I have tried many media like Maxwell or Verbatin. These "other brands" are fine on the computer but not on this machine. I don't know what this machine can detect and see the differences in the media.
The good thing is that I was able to connect the DV port from my camcorder (Sony mini DV) to the dv port on this unit. Cable was not included so I bought one very cheap from eBay. This connection gives the best control as the LiteOn remote control can control the recording from camcorder to the DVD recorder and even make different menu items. This is not a published feature but I figured out. As I said I have made hundreds of home video on this unit and it is very nice (when it works.)
Jun 06, 2008 | Lite On LVC-9016G DVD Recorder/VCR
DVD PLAYS CD'S BUT WONT PLAY DVD'S
Aquarius0128 there are two things to consider here.. dvd's recorded on a computer need to be closed/finalized after you have recorded onto them in order to be used on a stand alone player.. they will play ok on original recorder because of the design of these machines finalizing prepares the structure of the disc so it can be recognised by other players as a dvd video disc.. you will usually see a 'finalize disc' option in your recording program
Second issue is this.. even if finalized an older (or even some modern) stand alone players will not recognise a recorded disc made on a computer or even if it can there are different formats DVD+R DVD-R and even DVD-RAM and DVD-RW (the two latter ones are rarely recognised outside a computer)
Jan 29, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Lite On LVW-5045 DVD Recorder - won't record onto disc
Liteon lvw 5045 problem action failed.please consult our customer service for recovery. (error code: 0x810D0004)
Dec 11, 2007 | Lite On LVW-5045 DVD Recorder
Playing disc
any disc recorded on the liteon must be "FINALISED" before it will play on other machines.use "disctools" in the liteon menu to tdo this.
Sep 04, 2007 | Sanyo DVW-5000 DVD Player/VCR
Recording problem
I have the same problem. What I found was the recorder will not recognize a disc that was inserted into the machine and then the machine is turned off. If I load a disc, either a -R or -RW, program the timer recording and DO NOT turn the recorder off, then the unit does make the recording. I called the Toshiba techs and the only thing they recomended was to return the machine to them for repair at a flat rate of $140. The unit only cast $180. A friend of mine has the same recorder and he is going to check if it will recognise a previously loaded disc after the unit is turned off and back on. Perhaps everyone with this problem should call Toshiba so they can make a firmware update for the DR4s. I hope this helps. MW
Jan 26, 2007 | Toshiba DR4 DVD Recorder
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
