Pioneer XR-P260F. All works fine except tapes will not roll. All connections checked. All buttons are on. Can you assist me in whether it needs to go to repair shop or is there something that I can do. Thanx 10,000X Bob in AZ
  • jtamaresis Dec 08, 2008
    i have a very similar problem... the tape wants to switch but doesn't and as a result the tape will not lay
Ok, this is the problem: The heat that comes from the bottom "cooks" the rubber rings the tape uses to work. It is an unacceptable design error from pioneer and we were not aware of it. Solution: change the rubber belts over and over and over and...
Posted on May 22, 2010
Fisher dual cassette player recorder doors wont open
The eject mechanisms may have simply aged to a point where they no longer work. There could be dried out lubricant or a failed mechanical part.
Mar 23, 2014 | Sony Audio Players & Recorders
Can not open cassette player door
There are typically cam belts that become lose after some time that allow the deck to get stuck in a mode that locks the door closed such as play mode. Rotating the pulley that is driven by the motor will release the tape but that is just to release the tape- you need a new belt in the unit and some cleaning and lubrication to make it working again.
Oct 18, 2012 | Audio Players & Recorders
I don't know if you can help or not, but i picked up a pioneer stereo/cd/dual cassette player - model xr-p260f at a garage sale. It's really clean and looks like it hasn't had much use. The...
Tape players have several rubber belts in it and if we do not use them frequently belts loosen and become useless and they need to be replaced... . To accomplish this however you need some sort of handy man ability.. Take out the metal cover of the player by removing the screws on the sides .after removing the cover you can access the tape head /transport mechanism. if you look carefully to underneath of tape transport you will see the motor unit which belts will be there...check the belts for the moving mechanism and make sure the belts are not loosen / worn out or broken . You can replace it with a new one that may available in radio Shack stores. Take care..and let me know if it does not work out..
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 09, 2011 | Pioneer Audio Players & Recorders
Haveing trouble wireing a Pioneer A-400X INTERGRATED AMP, Need the user manual really.Where can i download tthis manual can you help. .
I can't find the manual but there's no real mystery to any generic stereo amp.
http://hifi4sale.fullboards.com/t5345-pioneer-a-400xusedsold
OUTs go to INs.
Just about any standard output of an audio device will connect to any Input on theamp EXCEPT PHONO, which is for a turntable.
Tape loops are for tape decks or sound processors like equalizers. When a tape loop is selected the program goes out, gets processed and comes back - all before any volume or tone controls.
May 21, 2011 | Pioneer Audio Players & Recorders
Hi, My Pioneer CTF-7272 Cassette Deck has stopped playing. Rewind works fine, but FF and Play will run for about 5 seconds and then the tape just stops. Any info on this problem is greaty appreciated....
check the belt whether it is broken or loose. if so replace the belt.
I hope this will solve your issue.
Good luck
If my solution proves useful please rank it.
Regards
Arjun.
Mar 27, 2009 | Pioneer CT-W205R Single Dual Cassette Deck
Pioneer CD deck Receiver XR P250. Neither of the two tapes work. They dont go round.
Hi John
This is something I can tell you that you can sort out yourself with a little bit of mechanical aptitude and a couple of screwdrivers.
FIRST turn the power off to the unit.
If you pop the lid off the unit, you will see that the capstan drive belts to the tape decks mechanism have failed, Either turned to back muck like windscreen sealant, or just broken and dropped off. The belts (each deck has one) will need to be replaced. The part number for the belt(according to my records) is REB1272 You should still be able to get them from Pioneer spares directly in your country. Let me know where you are and I can get some better information to you.
good luck. Happy to assist you further and answer any questions you may have.
regards
robotek
Nov 06, 2008 | Audio Players & Recorders
Tape adjustment
Jazzie: Your pinch rollers are worn. Put in a new set and probably a drive belt while you're at it and you'll be back in business. When the rollers are worn and tapered, the tape just rolls right off. Be sure to get the Pioneer replacements! Part---- RXB-325
Oct 29, 2008 | Audio Players & Recorders
Kenwood KA-72B Stereo Receiver HELP NEEDED.
Why not plug the cassette directly into the CD recorder? Are they trying to achieve some eqalization change? If not, then this should work. It's all analog at tape level.
Mar 02, 2008 | Audio Players & Recorders
598 people viewed this question
 Grubhead
Grubhead
