Question about NorStar M7310 Corded Phone
Changing Time and Date
Our phones will not accept any feature number entered in attempt to change the date and time. Have tried Feature **8463, Feature **266344, Feature **23646. Any suggestions?
  • Anonymous Mar 09, 2009
    I am having trouble getting passed the password when attempting to change the time on my norstar m7310 phone.
  • 326 Answers
I had this problem a while ago, you have to set the time from the main phone
Press FEATURE **8463 – Display shows PASSWORD:
Then type in 23646 (Note this number will not show on display)
The display will show hours.
Press CHANGE (or NEXT if you do not need to change the hour).
Enter the hour (00 to 23). If number is less than 13, the display shows AM.
Press CHANGE to select PM.
Press NEXT. The display shows minutes.
Press CHANGE (or NEXT if you do not need to change the minutes).
Enter the minutes (00 to 59).
Press NEXT. The display shows year.
Press CHANGE (or NEXT if you do not need to change the year).
Enter the last two digits of current year.
Press NEXT. The display shows month.
Press CHANGE (or NEXT if you do not need to change the month).
Enter the month (01 to 12).
Press NEXT. The display shows day.
Press CHANGE.
Enter the day of the month (10 to 31)
Press RLS (release) to exit.
Posted on Apr 18, 2008
I entered **266344 and my password is not working any suggestions???
Posted on Mar 12, 2009
How do I change date and time?
Step 1 Press the FEATURE key followed by **8463 Step 2 Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options: Step 3 Select CHANGE - the display will show the following options: Step 4 Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. Step 5 After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same. If you want to change the date, select NEXT. Step 6 The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005). Select NEXT, and repeat to change the month and the day. Step 7 Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Mar 30, 2011 | Nortel Norstar 16-Line PBX Speakerphone
I need the directions to set the time and date on Partner 18D phones and how to set up extentions
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
To change the date enter #101
the display will say system date and the current programmed date
enter in the new date in MMDDYY format
press feature "00" to logout
As far as setting up the extensions, I'm going to need a little more specific info to help.
Aug 26, 2010 | Lucent PARTNER18 Corded Phone
Trying to set the time on the phone but i dont know the password
Try feature **8463 (time) or feature **266344 (config). Either way, changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 8 4 6 3" or "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Aug 16, 2010 | Nortel T7316E 2-Line Corded Phone
HOW DO I SET THE TME AND DATE ON PHONE
enter in "#103"
enter the new time in 24 hour format to change the date enter #101 the display will say "system date" and the current data enter in the date in MMDDYY format
Aug 15, 2010 | AT&T Lucent MLS-12D Phone
Cant change time and date on nortel t7208 phone tried the f xx23646 and so on, nothing
Programming on the nortel system is done on M 7310, M 7324, or T 7316 sets only.hopfully the receptionist station has one of the larger sets.
Apr 15, 2010 | NorStar T7208 Corded Phone
Edit time on norstarM7310
Feature **8463 and the password is 266344.
After that it will give u option of cahnge date and time.
Thanks
Jun 29, 2009 | NorStar M7310 Phone
Norstar CallPilot 100: need to change the time within the system to reflect daylight savings time
the time change goes off the system time to change system time press feature **7463 enter the admin password then press change and enter new time
Mar 09, 2009 | NorStar CallPilot 100
Changing the date and time
Do you have the ADMIN password? If so you cna change the time and date by logging into the system, press next until you get to " Time and Date " and change it there. If you do not have the ADMIN password please let me know and I'll try to help. ....Mitelmike
Nov 04, 2008 | NorStar M7310 Corded Phone
How too change time
Norstar Merdian Press Feature.
Enter "**8463".
Enter the password (default is 266344). The display shows
Hour: 01
Next Change
Select CHANGE. Display shows:
Hour: __
Cancel
Enter two digits for the hour. Chose AM or PM when Prompted.
Select NEXT.
The display shows:
Minutes: 00
Next Change
Enter the minutes.
Press the RLS button to end, or press NEXT to change the date.
The diplay shows:
Year: 99
Next Change
Enter the two-digit year.
Select NEXT and repeat to change the month and day.
Press the RLS key to save the time and date and exit programming.
Top of Page
Norstar Meridian CICS Time
  • Press "FEAT".
  • Press "*".
  • Press "*".
  • Press "266344" (CONFIG) or "23646" (ADMIN).
  • Enter password "23456" (ADMIN) or "72787" (SCPLUS).
  • You will see "Terminals & Sets".
  • Press "Next" five times.
  • Press "Show"
  • When you see "Hour", press "Change" or "Next" to skip.
  • Type in the hour using military time as a 2 digit number.
  • Press "Next".
  • When you see "Minutes", press "Change" or "Next" to skip.
  • Type in the minutes using a 2 digit number.
  • Press "Next".
Date:
  • When you see "Year", press "Change" or "Next" to skip.
  • Type the year in 2-digit format.
  • Press "Next".
  • When you see "Month", press "Change" or "Next" to skip.
  • Type the month in 2-digit format.
  • Press "Next".
  • When you see "Day", press "Change" or "Next" to skip.
  • Type the day in 7-digit format.
  • Press "Next".
  • When you see "End of List", Press "Rls" to exit.
Top of Page
Nortel Norstar Telephone Systems Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
  1. To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
  2. Enter password (default = 266344) - display should read "Terminals & Sets"
  3. Press "NEXT" 5 times - display should read "Time and Date"
  4. Press "SHOW" - display should read "Hour:___"
  5. Press softkey "CHANGE"
  6. Enter hour - display should read "AM OK or Change"
  7. Select AM or PM
  8. Press "NEXT" - display should read "Minutes:___"
  9. Press softkey "CHANGE"
  10. Enter minutes
  11. Press "NEXT" - display should read "Year:___"
  12. Press softkey "CHANGE"
  13. Enter year
  14. Press "NEXT" - display should read "Month:___"
  15. Press softkey "CHANGE"
  16. Enter month
  17. Press "NEXT" - display should read "Day:___"
  18. Press softkey "CHANGE"
  19. Enter day
  20. Press "NEXT"
Sep 15, 2008 | NorStar T7316E Corded Phone
CHANGE THE TIME/DATE AND TURN THE RINGER ON
You have to use the feature 9 # from the administrators phone (usually extension 100)
Go to extension 100, press "feature,9,#" and you'll see the numbers on your display blinking like a digital alarm clock. Enter the time and then press feature to complete.
Oct 11, 2007 | NEC DTU 8D-2 Corded Phone
NorStar M7310 Corded Phone Logo
418 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
