Hi khangal74,
If you dont have issues playing your usual psp games, you dont have to worry about the orange light. That is normal. It means that your PSP is saving the data to your memory stick.
Also make sure that your WLan switch is turned off ( that also causes a blinking orange light ).
However, if you are experiencing a flickering orange light and your screen remains black ( and you cannot play any games), it means that your PSP is having issues reading you memory card.
Do these:
Remove the memory card and turn your PSP on without the memory card (it should turn on with no problems)
Now, slowly re-insert your Memory stick. (You may need to do this several times until your PSP recognizes your memory card)
If this still does not work, your Memory stick is busted or may be infected with a virus and therefore needs to be replaced.
Wishing you with positive results. All the best to you.
Try these steps. If this doesn't work you may want to take the card to Game Stop or something and have them test it to see if it's working. Hope this helps!
Insert the Memory Card into the PlayStation 2 console. The port is located directly above the controller port. Note that there are two different memory card ports; there is no difference between the two. Some games, however, will attempt to auto-load from slot one so it is recommended that you keep your memory card inserted in slot one.
Plug your controller into the PlayStation 2. Power up the system without a PS2 disc inserted. You will be taken to the system menu screen. Select the "Memory Card" menu to examine any data on the card. If the memory card is new there should be no data on the card, if it is used you may see old saves from the previous owner on the card. If you no longer desire to keep these saves, you may highlight them and press the "Triangle" button to delete them.
Insert your PlayStation 2 game disc into the system. When the disc appears on the system menu, select it. Load the game, and play until you are prompted to either create a user profile, or to save your game. Once you have saved any data to the memory card, reset the system.
Select the "Memory Card" menu and examine your memory card. You should see a new icon representing your game's save data. If this data appears on the card, you have correctly set-up your PS2 Memory Card.
If the data does not appear on the card, you will need to format the card. If the system detects corrupt data on the card it will automatically open a prompt asking if you would like to format the memory card. Select "Yes" and the PlayStation 2 will format the card.
Hi the ps1 games come in cd format so if your buying the games from shops then they come as cds, how ever if you search using google you can find sites that let you download the games onto a memory card this isnt legal so icant give you many details but searching google will help you then copy the games onto a memory card and also the ps1 data onto the card and you can then play games without cds you just insert the memory card in the card slot on the ps and then you play the games that way.
The memory card plugs into the back of the controller.. i believe. No you do not need a memory card to play games, but you want one if you want to save your progress in games. Without a memory card to save progress, you will have to start a game over everytime you want to play it.
I am sorry I don't know what the expansoin pack is.... maybe a memory card, or rumble pack.
Make sure you have a memory card with your phone. Without that, your phone may go into "phone shock" and will probably crash because theres no space to think. I suggest getting a memory card if you don't have one, if you do have one get a bigger one, and if thats not the problem then you may have a hardware problem and might have to ask your phone company for a replacement phone, which they usually do for free.
if the game is rented then take it back if you own it try cleaning it or inserting in a computer to check for further problems . But if you dropped the console the first time playing the game then try playing it with a different memory card
One trick that I found working every time is that turn on the console, pull out memory card, insert game disk and start the game. When the game menu shows up put memory card in. From there onwards games will be loaded and saved properly without this issue hopefully
