Question about Mitsubishi VS-6043 60" Rear Projection Television
TV-Bowing Our TV was purchased in 1996. The picture is bowing now. Sometimes the picture stays on for a minute and then starts to bow again with colored lines. Can you help out with a suggestion? Thank you.
  • Mitsubishi Master
  • 8,617 Answers
Can you post a pic of your screen so i can properly diagnose the problem as it could be either a pincushion or convergence problem. A picture would clarify it for me.
Posted on Apr 16, 2008
The top of the picture is bowing down, and the bottom of the picture is bowing up, and throwing the convergence out. What is causing this?
The 2 STK convergence ICS and some or all it resistors are the cause and is dead.The tv convergence board require these parts to be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 13, 2010 | Sony KP-61HS30 TV
9p5544c102 Horizontal bow
ok meoff check the convergence circuit. shadow in the picture is defective convergence circuit... replace a new.
Sep 28, 2007 | Philips Magnavox 9P6034C 60" Rear...
Bowing top and bottom temporary on cold TV
problem with unit is convergence--i would resolder convergence ics(they start with stk932-......)if that does not work replace them--if you need the exact part numbers email me at djstvrepair@comcast.net
Sep 15, 2009 | Pioneer SD-P50A3-K TV
Picture is bowing & has red & green shadows
what type of tv do you have. sounds like a loss of covergence. if its
May 04, 2009 | Televison & Video
Toshiba CX32G60 1/2" vertical inward bow center of video
change the electrolytic capacitors in the vertical section of tv. you do need a qualified tv tech to do this repair for sure
Nov 30, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Slight bowing of picture
Only on newer TV's, yours (I dont think)has the adjustment, if it does it would be in the menu area.
Apr 22, 2008 | Sony KV-36XBR450 36" TV
Mitsubishi TV Picture Bowing
You will find a very good guide here and here to fix your TV.
This might not be a DIY if you do not feel comfortable. The repair shops charge about $350.00 to $400.00 for this type of repair.
Apr 19, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Model #
Im sorry ive been so busy with so many different tvs i have forgotten which set i was asking about? I have one RCA ptk178LA that has bowing at top& bowing upward on bottom it acts like bad cap because sometimes it will all of a sudden snap into full correct picture, then after awhile it will go back to bowing.
Feb 21, 2008 | Sony KP-46WT500 46" Rear Projection...
Horizontal bow and shadow
Replace convergence IC's--then re-check convergence alignment in servicer mode,if necessary.
Sep 27, 2007 | Philips 9P5544C 55" Rear Projection...
Help with bowing
Usually consumer described bowing is bad solder connects
on pins of convergence IC's. If the effort is made to pull the center PC board out,then replace both Stk392-570 IC's for
durability.
Note: V-Pin amp and pin out relates to left/right side bowed-in
  issues,a problem not usually found on your model.
Aug 30, 2007 | Mitsubishi WS-55908 55" Rear Projection...
Televison & Video Logo
179 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
