Pixma ip1500 not compatible with vista - Office Equipment & Supplies
    Sergeant:
    Champion:
  • 333 Answers
Yes it is compatible...
Try this add on for Vista for the ip1500
http://software.canon-europe.com/software/0025531.asp
If it works please leave feedback --:)
Posted on Apr 16, 2008
  • 158 Answers
SOURCE: Hello, When I tried to
If you are in the USA, go on the internet to www.usa.canon.com. Select the DOWNLOADS tab, and follow the instructions on the DOWNLOAD LIBRARY page to find your printer. Once you are on the PIXMA iP1500 page, left click on the DRIVERS AND DOWNLOADS tab. Under DRIVERS/SOFTWARE SELECTION , choose your new computers oprating system in the drop-down window. You will then see updated drivers and software you can download for free. Just click on the red highlighted download file you want, and follow the onscreen inspructions.
Posted on Jul 18, 2008
ginko
  • 19396 Answers
SOURCE: I need a driver for my Lexmark z82 vista compatible
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:
LEXMARK : Official Lexmark Drivers and Software
CANON : Official Canon Drivers and Software or Canon USA:DRIVER & DOWNLOADS
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Posted on Nov 24, 2008
  • 2692 Answers
SOURCE: I HAVE A CANON PIXMA IP1500 PRINTER
Yes. But you must download annd install additional software. See below:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=10236
Posted on Jan 17, 2009
Techno-Geek
  • 38 Answers
SOURCE: Canon pixma ip1500 compatible with Vista if I use the install CD?
Ideally the CD you have should contain the drivers.
Still if you dont find them there, Please click on the link below and you will find the drivers on this website.
http://software.canon-europe.com/products/0010092.asp
I hope i have answered you question fully.
Please rate the support offered to you if you find it useful.
Thanks and Best Regards,
Techno-geek.
Posted on Apr 06, 2009
  • 164 Answers
SOURCE: Canon Pixma ip1500 printer
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3. Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
Try this solution to reset the ink tank , it should work for most pixmas and several other Canon printers.
http://www.fixya.com/support/t538192-waste_ink_almost_full
Posted on Mar 31, 2010
Ink reservoir indicated full, any home remedy??? canon PIXMA IP1500
Look here: http://tricks-collections.com/resetter-printers-canon-pixma-ip1000-ip1200-ip1300-ip1500-ip1600-1700-ip1880-ip2200-ip3000-ip4200-ip5200/
Oct 07, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Missing cd
First download and install the latest drivers for Windows Vista. Then try connecting the printer.
The latest drivers can be obtained from:
www.download.com/BJ-Printer-Driver-Canon-Pixma-iP1500/3000-2116_4-10555901.html
Jun 19, 2009 | Canon PIXMA iP1200 Photo Printer
Techno-geek.
Apr 06, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Problem installing the PIXMA MP500
are u on vista with vista drivers ? thx nick
Feb 06, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Canon pixma ip1500 printer
If you are using XP the driver will be there, if not you can download from the net.
Nov 22, 2007 | Computers & Internet
Lost installation disk for canon pixma iP 1500 inkjet printer
I just cut and pasted pixma ip1500 into google and went to first link, and choose correct driver from driver section for download.
Nov 07, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Windows vista unable to install my canon pixma mp500
First download and install the latest drivers for Windows Vista. Then try connecting the printer. The latest drivers can be obtained from: www.download.com/BJ-Printer-Driver-Canon-Pixma-iP1500/3000-2116_4-10555901.html
Sep 27, 2007 | Canon Pixma MP500 All-In-One InkJet...
79 people viewed this question
k24674
jasbo
jasbo
