Question about Sony SuperLite ultracompact Project VPL-CX5 Multimedia Projector
Blue Bleed A blue bleed is occuring at the top of the screen. Is there any way to fix it. I have just replaced the bulb. Sony vpl-es1
  • Bro_D Apr 17, 2008
    This happens all of the time. I have new wires, and is still there all of the time Video, S-video you name it and its there. Someone told me it had to do with the magnets inside overheating but not sure.
  • Anonymous Apr 07, 2009
    I get blue bleed on the top and sides when the TV has been on for a while. In my instance, it appears to be related to overheating. When I cleared the air filter, that got rid of it for a while.
  • 563 Answers
Hi there
Does this only happen once a signal is inserted ?
Does it happen on both PC & Video signals ?
Have you tried using a different cable yet ?
Posted on Apr 17, 2008
How to fix the big dark circle in the middle of the screen
I think you may be having a problem with the projection bulb.
Jun 09, 2014 | Sony VPL-ES1 Multimedia Projector
I have a sony vpl vw60 projector. When it is turned on it shows only a blue screen. I do hear the DVD playing but only blue is shown on the screen. Not sure of the problem. I do have a replacement bulb...
Check out your output, they all show blue until you hook something up to them, make sure you have it hooked up right. write a post and let me know what you have hooked up to it.
Apr 23, 2011 | Sony BRAVIA SXRD VPL-VW60 LCD Projector
When the SONY VPL - ES1 projector is turned, the lamp cover opens , no light and after a while lamp cover closes. Mounted on the ceiling, it has happened after it was working well previously. Lamp has...
definately a lamp problem, for some reason the projector doesnt seem to accept or recognize the new lamp and switches to "safe mode". usually the projector turns off before the bulb explodes...
Jun 11, 2009 | Sony VPL-ES1 Multimedia Projector
Blue Haze on screen Sony cineza vpl-hs50 projector
I also have the same problem -- the fix is to replace the optical block ( Internal lamp engine ) which is a $1,100 part. I just purchased a used projector for half the price of the part.
Nov 29, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
VPL ES 1 LAMP RESET
i have replace lamp but stlii no picture coming through
Sep 23, 2008 | Sony VPL-ES1 Multimedia Projector
Blue Bleed
It sounds like you have the typical sony burn lcd issue. You can confirm this if the background of the "stain" is the absence of blue, if so read on.
There are basically 2 manufactures of lcds for projectors and rear sets, sony and epson. Sony will bleed, epsons will shift or ghost images. The problem with sonys is due to heat and it physically burns the liquid in the lcd. If you think about it, it makes sence that it happens on the blue only. Blue is the hottest wavelength of light, and on top of it, the UHP lamps as they get used up, will shift twords the blue specturm, so you allways have to make sure that the vents are clean, fans are working and that the lamp is replaced at normal suggested times.
Unfortunatly there is no fix for this one other than to replace the entire optics block which is more expensive than a brand new set.
Aug 26, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony VPL-ES1 projector
Hi Max
Is there any power on the unit at all ?
i.e. Does the LED's on the unit indicate that it is in stanby ?
If it isn't then it could just be a fuse that has gone on your Powersupply.
Apr 21, 2008 | Sony VPL-ES1 Multimedia Projector
SONY VPL-ES1 DATA PROJECTOR
I have same problem. There is light on power led. 2 hours of standby doesn't work..
Dec 11, 2007 | Sony VPL-ES1 Multimedia Projector
Bleeding blue color upon projection
Yes you can replace the lamp, but service in must including the RGB Panels for the same. that will solve ur problem.
Viren
Nov 24, 2007 | Sony VPL CS1 Multimedia Projector
Blue tinting appearing on the right side of screen on vpl-es1 projector
A warning in the manual was given as to be carefull when using this projector with games as some parts of the screen will not move, just like if you watch Tv on it and there is a channel logo in one corner that doesn't move! It burns the display like it would on a pc monitor if no screen saver set. This is not a problem you can fix, that is perminant damage to the lcd in the projector!! S Platt
May 13, 2007 | Sony VPL-ES1 Multimedia Projector
Sony SuperLite ultracompact Project VPL-CX5 Multimedia Projector Logo
212 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
