Question about Kenmore Oasis HE 27062 Top Load Washer
The F code
I did not recieve a book about what the codes mean
It fills and starts to run then beeps stops and says F and then the remaining time. I stoped the cycle and took out some of the cloths to try ro re-balance the load. the above run for a few minutes then stop and beep with the F signal again. help
  • Anonymous Aug 08, 2008
    I get the f1 error code too. Would it help to open the console and tighten all the computer connections?
  • Anonymous Sep 06, 2008
    Same problem I can move machine around some and get it to work.
    What can I do?????????
    President:
  • 1,294 Answers
Refer to manual; your filter could be blocked, or something could be clogged in the drain pipes. Plug off the wall & check the pipes, filter first.
Posted on Jun 06, 2008
Stops and starts filling in short bursts then stops all together by beeping with the first and last light remain on how can I fix this ?
some machine use this filling process as a means of achieving a complete balance of clothes for the cycle
check that the program is not on long soak before it starts to wash
If you have everything as per the manual then call the technician as there may be a problem in the board
Jun 30, 2015 | Washing Machines
WASHER WAS OVER FILLING PUT NEW PRESSURE SWITCH ON STILL OVER FILLING MANUALLY PUMPED WATER OUT MACHINE STOPS AND BEEPS 6 TIMES THEN 1 WHAT DOES THAT CODE MEAN
Can not tell you what the beeps mean because you did not tell us what model washer you have. Sounds like a problem with the water inlet valve sticking open.
Jun 20, 2015 | Washing Machines
Code in digital display does not have a E in front of it
Please let me know if you can get a number after this - if so what number shows up?
Model differences:
• Better models have a digital readout display
• Good models do not have a digital readout display
In the Better Models line, the failure codes will appear in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, Final Spin and Control indicator lights will flash.
Example: E14. To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains
stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something
that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is
started.
In the Good Models line, the control signals the failure code by flashing the five indicator lights of Door Lock, Wash, Rinse,
Final Spin and Control for the first number or letter after the E and the Start indicator light for the second number or letter
after the E. When a failure occurs, the washer stops or pauses and the control beeps and flashes the five indicator lights to tell
the customer that a failure has occurred. To stop the flashing and beeping, the customer may touch the Pause Cancel button.
The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer.
If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate
normally the next time it is started.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking
LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Please Note the following...... on a small number of washers with serial number prefix XC4,
if the previous procedure does not perform as specified, follow the option below:
• Follow all previous steps but instead of pressing Start and Pause Cancel buttons,
press and hold Options and Pause Cancel buttons.
If the washer is a Better Model, the error code will appear in the display. Troubleshoot problem by using charts on the
following pages.
If the washer is a Good Model, the five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the
number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit.
Take
separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice
indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START
indicator light start flashing at the same time.
The control will pause for 2 seconds, then repeat the code as long as the two buttons are pressed and held.
Note: A letter appearing in the code stands for a number higher than nine:
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code F1: the first digit would be 15 and the second digit would be 1. If this code would appear on a washer in the
Good model line, the five indicator lights would blink fifteen times and the START indicator light would blink once.
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
Galanz microwave Code 310
This how i fixed with mi open hand i hit the number pad , 3 times hard like i dont care anymore and yeaaaaa it work like new again
Jul 03, 2013 | Microwave Ovens
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
I have a Fisher and Paykal Smart Drive 053 washine machine. It has just started doing the following: Start load - Cold, warm or Hot and any size Fills intermittent. will fill for a couple of seconds...
Hi just read your posting.When the machine stops and starts does it beep and show an error code.This error code will be a series of lights that light up and the machine will beep.On the wash progress line of lights which lights are lit when the machine beeps,Is it the 1st and 6th or the 4th and 8th etc.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Jun 05, 2011 | Fisher and Paykel (IWL12)
My amana gas stove keeps beeping and the code F1 is flashing?
Hi!
The F1 code means that the Key Pad is defective, the book says that if pressing CANCEL for 10 seconds don't stop the beeping and resets, the Pad should be replaced. I have learned that if you unplug the unit from the wall outlet for a couple of minutes, most of the time the pad will reset by itself.
Good Luck!! Don't forget to rate this post!!
Sep 27, 2010 | Amana ACS7270AS Electric Kitchen Range
Boot up beeping problem
Hit VGA Card if it is not connected properly. If there is any dust, clean it by using an eraser.
Aug 17, 2009 | HP dx5150 Microtower PC Desktop
The wash beeps all the time
To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is started.
Nov 18, 2008 | Frigidaire GLTF2940ES Front Load Washer
Open Questions:
See all Kenmore Oasis HE 27062 Top Load Washer Questions
Kenmore Oasis HE 27062 Top Load Washer Logo
62 people viewed this question
Sal De
fordexpert
Robert Rankin
