Posted on Apr 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No power when i switch my box on there is no power can somebody help me please
  • wml170 Jan 03, 2009
    POWER PLUG IN THE BACK OF TIVOLI/SIRIUS RADIO IS APPARENTLY BAD AS WHEN PLUGGED IN MUST MOVE IT AROUND AT ALL ANGLES TO FINALLY HAVE POWER GET THROUGH.....CORD IS OK AS IT WORKS WITH OTHER TIVOLI/SIRIUS RADIO WITHOUT PROBLEM...IS IT A BIG PROJECT TO REPLACE THE PLUG IN THE BACK OF THE RADIO OR ARE THERE OTHER SUGGESTIONS....THANKS
Anonymous
Level 2:
  • Expert 85 Answers
  • Posted on Apr 19, 2008
Anonymous
Expert
Level 2:
Answers
85
Questions
0
Helped
43940
Points
146
1. check to make sure that Ac power is flowing through the box
2.check your wall socket outlet
3.troubleshoot the equipment power stage
1helpful
Can somebody please tell me how to turn on my Magnavox converter box without a remote I do not see an on-off switch nowhere
I'm sorry but you can't turn it on without the remote.
https://www.google.com/search?source=hp&ei=IvuMX-qPGq7H_Qabq7PQCw&q=how+to+turn+on+my+Magnavox+converter+box+without+a+remote&oq=how+to+turn+on+my+Magnavox+converter+box+without+a+remote&gs_lcp=CgZwc3ktYWIQAzIFCCEQoAFQuKIBWLiiAWCFqAFoAXAAeACAAewCiAHsApIBAzMtMZgBAKABAqABAaoBB2d3cy13aXqwAQA&sclient=psy-ab&ved=0ahUKEwjqqIiYz7_sAhWuY98KHZvVDLoQ4dUDCAk&uact=5
Reverse lights not working
sounds like cable is broken in side temporary run a cable from fuse to reverse-switch.. then check out if ok run new cable from fuse to switch
I have model DDL-555-5 with controll box model MC-200, now my issue is the Bar tact do not work, please advice how to fix it?
hi there
please check firist this points:
1 - make sure the connection between MC200 panel and control box is connected secure.
2 - make sure backtack switch on control is activated ( start or end or both )
3 - if somebody play on rotary DIP switch please power off and by flat screwdriver change A,B,C and D to 3 stitches or 4 stitces up to you ( normaly set to 4 )
if you need more information please ask or email me at [email protected]
BEST REGARDS
ASHRAF ABOZID
CAIRO - EGYPT
2005 Dodge Grand Caravan power locks will not lock with key switch, door switch or autolock with car moving, I think it's a fuse but where is it at, looked under the hood at that fuse box but nothing was...
the other fuze box is eather when you open the driver door on the side of the dash, or it is under the dash on the driver side is the other places for your box
Hi.i have the box and all my channels are fine except sky movies channels and mtv channels. i tried everything but i just cant bring them back. please somebody help its been 2 days and im about to...
Try Menu-Installation-Manual Scan-Down Frequency 000000-
Network Scan Enable (change with R/L arrows on remote)
Wait a moment press OK, and they should be at the end of your list.
hope that works.
1helpful
LOOKING FOR DIGVOX CODES IF U HAVE THEM PLEASE
i have got new super 4 box somebody will tell me how i can do setting please help me thanks
Kenwood Power Supply Dip Switch Setting
why don't you get a controller for that supply? I got one...
John
1helpful
My tv won't switch back on...can please somebody help me???
sounds like a power supply problem. The blinking sound could either be the relay or high voltage inside the picture tube and flyback transformer. Bottomline is, you would need to have it checked by a qualified tv tech.
 Grubhead
Grubhead
SmartAviator
SmartAviator
