Question about iLO 3200 32 in. LCD Television
Color missing I have a Toshiba 42HL167 I can't get any blue color on it . Everything is a shade of green or pink. Can i fix it ?
  • oldod Apr 16, 2008
    Fixed it myself but I haven't a clue as to what I did or what was wrong
    Genius:
  • iLO Master
  • 1,689 Answers
You cannot fix this yourself. It is a problem in the signal path of the missing colour channel. The fault can be in the main processing, or along the video signal path, or in the actual panel. The signal processing is in digital. To track the signal processing path, would require the in depth design information, extensive instrumentation compared to what the standard service shop would have, and the data protocol information.
This type of set is serviced with module swapping. There is very little supported component level servicing on these sets. They use high density surface mount technology with multi layered circuit boards.
You will have to send the set out for factory level service.
Jerry G..
Posted on Apr 17, 2008
Shaded color tinting everything in pink and green. I've tried Magic Focus (5). It's a Hitachi 51SWX20B.
sound like a common problem where the coolant for the tubes has become contaminated. It is possible to replace the coolant yourself and can be a much cheaper alternative to getting repair shop to fix.
do a search for replace coolant 51swx20b
Oct 21, 2013 | Hitachi 51SWX20B 51" Rear Projection...
@the monitor appearance changed to pink shade and we are not able to see in this colour pl give me a solution to sent it back to normal mode
probably the color setting of the monitor has been changed.
on the monitor panel press the menu button and go to the color option.
see if increasing or decreasing the RED GREEN and BLUE color options sets back the monitor to normal.
usually some monitors have a reset option also, by selecting it everything will get back to normal.
Aug 02, 2011 | Computers & Internet
I have an Epson EMP-S4 projector. When I hook it up to my laptop the light comes on, but everything is in a shade of pink. I've tried adjusting color to no avail. Tried with another computer, same...
Check your cable you are missing a primary color and it could be that your cable is missing a pin/bent ck on both ends and even the projector input.
Jun 15, 2010 | Office Equipment & Supplies
I have a toshiba 65hm167 no red color on the screen
Your TV is a DLP one lamp does it all, not like the old projection TVs with the Red, Green & Blue CRTs. Your TV may have a bad light engine or lose cable connections.
Good luck
N Sabre
Nov 08, 2009 | Toshiba 65HM167 65" Projection Television
The pink colour is missing every time i clean the
Probably one of the red cartridges is empty or near empty or possibly the yellow - it will miss whatever color is low or empty or substitute the next closest shade using the remaining colors if one is out.
Oct 02, 2009 | Epson Stylus Color 670 InkJet Printer
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Missing colors on screen
if you have H/D one of your cables might be loose red/green/blue  i suspact red
Oct 21, 2007 | Toshiba 32WLT58 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
50 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
