Question about Vacuums
My 12 year old Rainbow SE suddenly began a burning odor
I think the motor may have burned out.  Is that something I can replace simply?  Or could there be another cause for the sudden problem.  It is possible someone may have used the vac w/o water, as it was sitting out when some workers were in the house doing some renovations.
Thanks,  Pam Thornton
  • pamtee Apr 17, 2008
    Thanks, you have convinced me this is beyond our skill level.  Probably after 12 years it needs a good tune up anyway.
    Have a great day,
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
My 12 year old Rainbow SE suddenly began a burning...
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can replace the motor your self if you are mechanically minded but there are wiring problems and a gasket replacement and to also replace the spider (looks like a small bowl with vents on the side of the bowl) underneath the vacuum. It you mark the wires with tapes on each wires it can be replace but the motor is a $300.00 or better if you do it right and include the motor, gasket and spider. This price may include labor in a vacuum shop. The $300.00 is just an estimate and you would need to contact the local vacuum cleaner dealer in your area to do the replacement, it’s a good vacuum and if you like it have the motor replaced. Always use water when using the vacuum, the workers may have used the vacuum to pickup sheetrock dust of which will get into the motor and reduce the life of the Rainbow motor and will destroy any vacuum on the market, it plugs the spores of the cloth, paper and dirt cup filters of which need replacing.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Posted on Apr 16, 2008
If you dopn't change the hepa filter will motor burn up or explode
No. The HEPA filter is simply to collect fine dust and allergens that make it past the water. Hmm. If it gets full/clogged and isn't changed, then the motor is more likely to burn up from overheating. It's more likely it will shut off if the filter gets full. It will not explode.
Dec 17, 2010 | Rainbow E series Canister Wet/Dry Vacuum
I smelled something burning one day , but i kept using my d4c, now the motor part does not run but the top plug in will run
I work on Rainbows. D4C-E2 etc. Not sure what you mean by the top plug in. There are two motors in the rainbow, one in the main unit, one in the power head. Where was the odor coming from? email me back with more info, I can help you with this. Jerry
Nov 06, 2010 | Rainbow E series Canister Wet/Dry Vacuum
My e-2 vacuum runs very loud and smell like it's burning.
You may have damaged a bearing or bearing housing and that could be causing the motor armature and field to rub together which in turn causes the motor to draw a significantly increased current to overcome the friction. It could be a simple fix if it is a bearing but if it is the housing then it is likely toast. I used to repair motors years ago and the cost then was not bad. However if the motor is heat damaged, as happened to my power rack last year, it was cheaper to buy a new one than replace the motor. A burned out motor is not worth repairing these days.
Dec 19, 2017 | Rainbow E series Canister Wet/Dry Vacuum
I bought my rainbow se vacum 4 years ago and I was using it and suddendly stoped working, I try to on no power I on and off not working at all. what shall i do is there posibility to work again.pls.help...
Hi, there is no reset button on a Rainbow vacuum.
All SE series vacuums have a built in thermal and load fuse on the motor, and if it blew, it has to be replaced, or wired directly, with out it on there.
Motor brushes are usually the source of a non working Rainbow D4 and SE and all model Rainbow vacuums and when they burn out, they usually take the motor armature with them, from excessive heat and flare electrical arking to the armature. It is probably the thermal and load fuse, that is your problem, if you did not smell any electric burning type of smell, before it quit. It could be the power switch, but not as likely as the fuse. If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Feb 13, 2010 | Rainbow 75th Anniversary Canister Vacuum
Kenmore vac producing burning odor
It sounds like you have bad carbon brushes on the motor. Get replacement brushes from a local vac shop, and take the unit apart. On each side of the motor their is a retangular piece of plastic with what looks like magnets in them. In most cases they are simply held by 2 screws. Replace these brushes and reasemble the unit. If the problem persists you have burned out the comutator on the motor and the whole thing must be replaced.
Apr 15, 2009 | Kenmore 22085 Bagged Canister Vacuum
Rainbow will not come back on
Bad idea.... I think the foam got through the separator and into the fan system. When it dried it hardened and now it need to be taken apart and cleaned.
Turn it on for less than 1 sec and if you hear motor making humming sound - it is ALIVE and cleaning (maybe new fan blades too) may be all that it needs. If no sound at all it may be KAPUT. You must have smelled something burning when you turned on and it did not work.
for D4 and SE models - When cleaning I would recommend to replace bearings as they are not that expensive and if you took it apart - maybe a good idea to replace them. Also you probably will need a new gasket as when taking old one off (it is glued) it may rip apart.
For e-series - you will need a new HEPA filter.
(parts HERE)
For Parts see
Mar 03, 2009 | Rainbow E series Canister Wet/Dry Vacuum
My Husband put a cleaner in the water when turning the vaccum on.
If nozzle works but the main unit does not then it leaves only few things - motor is "kaput" or some wire got loose somewhere. When motor burns it usually stinks pretty bad.
You have to open it up to see and test. We can do it for you but you'd have to ship it here.Se instructions
Feb 01, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Vacuum smells like something is burning.
When it is running look on top of unit to see if there is any flashing from the brushes, if your unit has been getting pretty hot on top, it would probably be motor brushes. These are not very expenseive to replace and by doing so you will have your unit for so many more years.
Dec 31, 2008 | Rainbow 75th Anniversary Canister Vacuum
Vacuums Logo
198 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
