Question about Xitel INport (HFLI1X1) Audio Input
Xitel INport audio not coming through
I loaded everything up and it looks like it is recording my lps from the recording levels..., but no sound is coming out on playback?
  • Anonymous Nov 19, 2008
    no sound is coming out.
  • Anonymous Dec 02, 2008
    My INport Delux was working fine until yesterday but now I get simultaneous playback o.k. but LPRipper doesn't show my recording for trimming and editing. Help!
Change your recording device in your control panel back to your soundcard that will allow the sound back to your computer. In order to record you had to change it to Inport.
Posted on Apr 23, 2008
2 Suggested Answers
DickCanFixIt
  • 948 Answers
SOURCE: Problems with Xitel INport Audio
Check the Xitel fix for this at http://www.xitel.com/USA/support_inport.htm
Posted on Jan 03, 2009
Is there an upgrade for Xitel Inport for windows 10
Yes. V11.1 of LP Recorder is supported on Windows 10 with Xitel's INport. There are instructions on how to configure Windows 10 to use it here:
http://www.cfbsoftware.com/Windows10/INport.htm
Sep 26, 2016 | Xitel INport Deluxe
Which xitel product records directly from turntable
You need a turntable with a built-in phono preamplifier that has a 'Line out' output if you want to record directly from it using Xitel's INport. Alternatively you could connect your turntable to a standalone phono-preamplifier and connect the INport to its output.
Feb 26, 2014 | Xitel INport (HFLI1X1) Audio Input
LP recorder incompatibility
The software (LP recorder) does not recognise your soundcard. Download a different free program to record your LPs.
Dec 19, 2013 | Xitel INport Deluxe for PC
Xitel Inport De luxe with window 7
The directions for using the Xitel Inport Deluxe under Win7 are the same as those for using the device with Vista. The drivers are built into the OS. You will need to set the audio input to the Xitel device. For most installs of Windows 7 (Aero capable), with the Inport Deluxe plugged into a USB port on the computer, click Start > Control Panel > Hardware and Sound. Under the Sound listing, click on Manage Audio Devices. In the Recording tab, right click on Microphone Input and select Disable. Right click on the Line INport and select Enable. Right click again on Line INPort and make this the default device. Click on the Playback tab and right click on Speakers INport and select Disable.
If Aero isn't available, it's Control Panel > Sound.
You can use any recording software that runs under your version of Windows 7. The LP Recorder software manual starts on page 8 of the Xitel Inport Deluxe manual. If you do not have the original disc, LP Recorder is available here: http://www.cfbsoftware.com/lprecorder/lprecorder.aspx . (Audacity, http://audacity.sourceforge.net/ , works much the same way as LP Recorder. However the drop down menus for the source and output are available from the main program with the default toolbars enabled.)
I hope this helps.
Sep 26, 2012 | Televison & Video
I need a software for windows 7 for xitel inport
INport - Windows 7 compatibility
Your INport Deluxe hardware and software is all Windows 7 compatible straight out of the box. Please click below to download the Windows 7 user manual addendum for instructions on how to install your INport Deluxe hardware.
http://www.xitel.com/USA/support_inport_vista.htm
Apr 08, 2011 | Xitel INport (HFLI1X1) Audio Input
INPORT Installed, Sound Disappears
The Xitel site http://www.xitel.com/USA/support_inport.htm says when this happens, " 1. Go to START -> CONTROL PANEL -> SOUNDS AND MULTIMEDIA PROPERTIES -> AUDIO TAB
2. Make sure that in the Audio tab your soundcard appears as the Preferred Playback device with USB Audio or INport as the Preferred Recording Device. There should also be a check next to the option 'use only preferred device'.
3. When you start LPRecorder you should also make sure that Recording Device is set to USB Device or INport and Playback Device is set as your soundcard and that there is a check next to the option Simultaneous Playback."
Jul 20, 2008 | Xitel INport (HFLI1X1) Audio Input
I have Xitel plug and play and it works perfect on my PC-- do they have a driver to work on my mac. john
Apr 17, 2008 | Xitel INport (HFLI1X1) Audio Input
Audio
Try the solution at the Xitel site http://www.xitel.com/USA/support_inport.htm
Feb 17, 2008 | Xitel INport (HFLI1X1) Audio Input
Xitel INport (HFLI1X1) Audio Input Logo
485 people viewed this question
Top Xitel Televison & Video Experts
CFB Software
Level 1 Expert
boneman1975
boneman1975
Are you a Xitel Televison and Video Expert? Answer questions, earn points and help others
