Question about Radio Shack Cinego D-1000 Multimedia Projector
Cinego turns itself off after 10 mins
My Cinego will turn on like normal, work fine for about 10 minutes and then just turn itself off...any suggestions?
  • 563 Answers
Hi There
Check if your lamp has any faults like discolouration or marks on it.
Otherwise it could be Mainboard that will need repair or replacement.
Posted on Apr 21, 2008
My hp Pavillion dv6000 looks like it wants to turn on but turns itself back off after a min or two. It does this process over and over without turning on.
Unplug AC & battery. Then, unplug the cell battery right at the memory compartment (wait for at least 10 min).
Plug everything back in. Laptop should be back to normal.
It works for me.
Cheer
May 12, 2010 | Computers & Internet
Set won't stay on, won't turn on
Sounds like a capacitor on the power supply is bad. Easy fix.
Sep 24, 2009 | Hitachi 50UX57B 50" Rear Projection...
KV-27TH70 SONY TV Shuts Down for no Reason
hi there, normally bad/broken connections in the horizontal or on the flyback. hjope this helps.
Aug 04, 2008 | Televison & Video
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Flashing red light
sounds like a flaky power supply or lamp ballast
Jun 01, 2008 | Radio Shack Cinego D-1000 Multimedia...
Cinego d-1000 after 3 minute turn off
Hi Rcasso
There could be a whole number of things that is the cause.
The most popular of which would be replacing the lamp or Ballast ( lamp's powersupply )
Could you supply me with the LED status when the unit shuts down ?
Apr 29, 2008 | Radio Shack Cinego D-1000 Multimedia...
CINEGO
Mine does the same thing and I just replaced the bulb after waiting almost 6 months and I purchased one directly from Radio Slack. It will turn on for about 10 seconds and then goes into shut down.....At three hundred dollars I can't see putting another bulb in, when this one has less than 50 hours on it.
What do you think
Oct 29, 2007 | Radio Shack Cinego D-1000 Multimedia...
The cinego turns off
Someone told me to change the bulb and it would fix it. I guess that is what ill have to do also.
Oct 11, 2007 | Radio Shack Cinego D-1000 Multimedia...
194 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
Frank Zabroski
Frank Zabroski
xxxxxx xxx
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
