Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Replaced cap i replaced cap worked two days now samething green light kicks on quicker though but wont turn on tv
  • slopyjoe12 Apr 21, 2008
    I turn my tv on and the green light comes on, cuts off 3 times then nothing.
    Sergeant:
    Champion:
  • 375 Answers
You have otherissues get a tech to look at it you tried
Posted on Apr 18, 2008
PS3 wont power up
try another outlet if the light still will not turn green you will need to contact sony,
if the light does turn green let me know and we will get this fixed
Dec 24, 2011 | Sony Playstation 3 (PS3) Console
TV won't turn on after lamp was replaced
Check the switch on the lamp door. Listen for the color wheel to spin. if the door switch is bad the lamp wont come on, samething if the color wheel is bad.
Jun 16, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
The green light comes on then turns to yellow.
if you look at the capacitors on the boards you will find several of them that are domed or blown, these are the most likely cause of the problem. you can find replacements for any capacitor online at electronics supply stores, like radio shack but don't try them they don't supply enough different types. you can also find examples of blown capacitors by doing a search for "blown capacitor image" on any web search. unsoldering these bad caps and replacing them with identical values like 220uf (microfarradys) and say 25 v(volts). these caps have a + side and a - side the caps are marked and so is the board. hope this helps.
Mar 20, 2009 | Proview PL926WBi 19" LCD Monitor
D52w20 RCA Projection wont turn on
On the Deflection board CK 3 fuses they will be in a roll on right side of Flyback Transfomer FL231 they look like small rectangler brown caps they are fuses Then Check 3 capacitors cp150 2200uf 16v if puffed up on top it is bad replace cp114 and cp120 220uf 35v.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Magnavox 32mf23id/37 wont tun on
Had the same issue, I replaced two 1200uf caps on the power supply board and now it works fine again. Remember to replace the caps with caps rated for at least 35wvdc.
Jan 29, 2009 | Philips 32MF231D Television
LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
Oct 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Dead tv :-(
ai have the same fault on my tv will not swith on any help any1
Mar 22, 2008 | Televison & Video
Flashing green button, won't reset or turn on
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
Dec 18, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Green light blinks, TV DOES NOT COME ON!
Install horiz driver kit # 483531057673 and replace weak cap in
horiz driver circuit = 47mf/25v.Fix applies to all L04.01U chassis..........................T.
Nov 22, 2007 | Philips 32PT6441/37 32" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
18 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
