MY CANON PIXMA MP600 PRINTER HAS STARTED TO PRINT HALF ONLY HALF THE LINES OF A LETTER. I HAVE RECENTLY CHANGED ALL THE INKS WITH ORIGINAL CANON CARTRIDGES AND THIS IS THE FIRST INK CHANGE. DOES ANYBODY HAVE AN IDEA WHY IT HAS STARTED DOING THIS? THANKS AND REGARDS
  • colli848 Apr 16, 2008
    WILL TRY YOUR SUGGESTION. THANK YOU.
  • 655 Answers
Colli,
It seems your cartridge are not setting well or there may be some head jammed.
  • In your manual there is a section 'Maintaining the print head'.
  • Goto this section and follow the instruction on it.
Gud Luck
Iqbal
Posted on Apr 16, 2008
Hello....I am on my second Canon Pixma printer and this one I bought in May of 2009......suddenly it is making faeded looking prints.....I changed all of the ink tanks and did deep cleaning about 10...
refill cartridges most of the time will not give you good quality prints on average sometimes they simply just do not work I know i refill them best advice before cleaning printer heads get original cartridges perhaps from another machine just to test if the copy quality is good buy originals
Oct 13, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Pictures are printing out very green - I have just swapped all colours and cleaned the heads but still green pictures!
You have poor quality inks. Get original inks and new print heads and your printer will work fine.
Aug 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Ink Monitoring System
I have this Canon MP600 using unchipped cartridges. Once you have changed the chip over onto the catridge and inseted it should stop flashing which indicates the cartridge is located. The printer will not tell you the level of ink until you run out. When changing the chip over from original cartridge onto unchipped ensure it is not damaged and fitting properly other wise the error sign will show.The printer should print without any problems, i know you can not disable the ink monitoring system. Hope this is some help Mr T
Apr 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Streaky printing from canon pixma MP600
There is usually a maintenance button or similar in the "printer properties" dialog box to run a cleaning cycle."Right click" on your printer, select "properties", and you should see something. Try that.
Also, are these Original cartridges or compatibles / refills? Non originals can often cause image quality problems
Mar 01, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Ink carriage will not stop at centre to allow change of ink cartridges
hi star
Try this
After the printer decides the cartridge is empty it will start giving you warnings. Eventually it will give you a message to press the Stop/Reset switch for approx. 5 seconds to disable ink level monitoring on the empty cartridge. Ink level monitoring will be re enabled if a new OEM Canon cartridge is installed. There is no way to reset the chip on the cartridge but you can replace for new ink
oke
cropp
Mar 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Black ink not printing
1. turn off the printer and open the front panel of printer
2. clean right side box wr all cartridge are stop
3. then change black cartridge
Mar 04, 2008 | Canon PIXMA MP600 all-In-One InkJet...
113 people viewed this question
jasbo
jasbo
