Question about Minolta EP4000/5000 CS/PRO Copier
Copies only 75% of page
I recently replaced the toner cartridge but now the same problem occurs: only 75% of an 8 1/2 x 11 page is copied.
Please note my product is model 1083 CS Pro copier.
  • Lynnwood Apr 17, 2008
    Nitrotrike, thanks very much for responding! The image is being cut off. Lynnwood
  • brian c
    brian c May 11, 2010
    Is it reducing the size of the original image, or just cutting it off?
    Problem Solver:
  • 11 Answers
  1. see the black guide next to optical lens under black cover
Posted on May 07, 2008
Just purchased a Zerox XC1255 Copier at an Auction. Replaced the toner cartridge because the light was on. The copies seem to have excessive toner in the background of the copies. I am wondering if I...
Could be a bad drum unit. Is the new toner cartridge a refilled? Remanufactured? or Brand New Xerox brand toner? If it is refilled or remanufactured I would run some copies and give it a chance to clear. Sometimes they end up with too much toner in the Developer mix and can be overtoned which causes a general background over the whole page. They should clear up as you run copies, say within 100 pages. Also try manually lightening the copy with the exposure control on the operation panel. If lightening the copy clears all of the background then you need to have the optics cleaned. There are 4 mirrors under the large original glass that need to be cleaned. If all this fails then you are looking at either drum unit or a defective or out of balance toner/developer cartridge.
Good Luck and Thank You for using Fixya.
Aug 18, 2010 | Xerox Office Equipment & Supplies
I have a muratec mfx 1930 and the toner is not reaching the amount of 16000 copies after 8000 copies the pages are coming out with black marks like clouds on the sky the only solution is to replace toner...
If replacing the Toner cartridge fixed the problem then obviously the cartridge was defective. The cartridges should last "up to" 16,000 pages ( 5% coverage ,11" paper) Take the cartridge back to the Dealer you bought it from and explain what happened.
Aug 10, 2010 | Muratec F-300 Fax
Xerox 4118
That isnt unusual. The 8000 pages is for a page with 5 percent coverage area, or a rather short letter.
the 3600 to 4000 pages is not out of the ordinary for that machine, Although the xerox brand may work better, although not more copies, if you run pages with more than 5 percent of the page printed, that is about right.
Also there is no chip on a 4118 cartridge. The toner is monitored by a sensor and window in the middle of the cartridge. It shines light through the cartridge, and when the cartridge is empty the light actuates a light activated sensor.
it is not an efficient machine.
Dec 15, 2009 | Xerox WorkCentre M15i Laser Printer
Copies are coming out streaky
Defective toner. And a cartridge is only good for about 2000 pages - not 10,000.
Mar 02, 2009 | Samsung ML 2010 Laser Printer
Streaking copies
Have you changed the drum unit recently or emptied out the waste toner in the drum unit? If not try to empty the waste toner and clean the area that is right under the drum unit... * Note* do not wear any thing white... Toner can make a vey big mess...
Jan 26, 2009 | Office Equipment & Supplies
Prints completely black page when copying.
hello! are you usinga brother oen toner and drum cartrdige? that is the first thing to try, you are welcome to post back to me for additional help good luck brother tech
Jan 22, 2009 | Brother IntelliFax-2820 Laser Fax
Poor quality of copies
If it is a real genuine Brother toner. Not a reman. You may also need to change the drum. If you have a user manual, it will show you where the drum life setting is in the menu structure. Make sure the little glass window inside on the right is clean so it can read the toner level. Make sure the toner save feature is turned off.
Aug 14, 2008 | Brother IntelliFAX 4100 Laser Fax
Panasonic DP-150PA Light Copies to no copies
Have you reseated the drum and toner?
It can be a drum cartridge problem. have you tried that?
You say copy or print, so I am asuming this is multifunction and you do both printing and copying.
1, Have you shook up the toner cartridge well.
After the drum and shaking the toner, I would suspect the transfer assembly, Off hand I cant remember of that machine has a transfer roller, or if there is a channel where there is a hair fine wire running through it.
The wire may have broken, or if its a roller making poor contact.
The laser is also possible.The transfer will be on the right had door assembly.
Take the cartridges out and see if there is anything laying loose in the machine,
what you are describing sounds more like a drum or transfer problem.
sounds very much like a defective transfer. And again, could easily be the drum.
Did you have a jam just before this occured? If you had a jam in particular in the right hand door, you broke the transfer wire.
Yeah, i am rambling huh?
Apr 09, 2008 | Panasonic Workio DP-150PA Copier
Canon PC941 Copier: Wide white bar down middle of copies
Try replaceing the cartridge the toner has run out.
Any problems please get back to me.
Thank You
Mar 25, 2008 | Canon PC-940 Black and White Copier
How to remove or change toner
If you dont have the user's manual, here you have it online :
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
Look at page 24 - "Installing the toner cartridge" where you'll find this, but also pictures to illustrate how to do it.:
"1 Grasp the front cover and pull it toward you to open.
Note: Because the printer is very light, it may be moved when you
use it; for example, when opening/closing the tray or installing/
removing the toner cartridge. Be careful not to move the printer.
2 Remove the toner cartridge from its bag and remove the
paper protecting the cartridge by pulling the packing tape.
3 Gently roll the cartridge 5 or 6 times to distribute the toner.
Thoroughly rolling the cartridge will assure maximum
copies per cartridge.
Note: If toner gets on your clothing, wipe it off with a dry cloth
and wash clothing in cold water. Hot water sets toner into fabric.
Cautions:
• To prevent damage, do not expose the toner cartridge to light for
more than few minutes. Cover it with a piece of paper, if left
exposed for more than a few minutes.
• Do not touch the green underside of the toner cartridge. Use the
handle on the cartridge to avoid touching this area.
4 Locate the cartridge slots inside the printer, one on each side.
5 Unfold the toner cartridge handle and grasp it. Insert the
cartridge in the printer until it snaps into place.
Note: Carefully insert or pull out the toner cartridge not to scratch
against the printer.
6 Close the front cover. Make sure that the cover is securely
closed. If the cover is not firmly closed, printing errors may occur when you print.
Rate the answer please.
Mar 08, 2008 | Samsung ML 2010 Laser Printer
57 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
