How to hook up old Aiwa surround sound unit to tv.
Lost owners manual when I moved. Model #CXZHT63U --has receiver, disc player, dual tapes and runs digital slot machine on front when not in use.
  • 2 more comments
  • rosanne6 May 13, 2008
    I have a aiwa 5 speaker suround sound stereo and don't know how to make the 3 disc player work. I have put 3 cd in and pushed the cd button, it spins and than stops - no sound. Please tell me how to work it> I have no manuel. Thank you, Judy
  • jcruse3 Sep 03, 2008
    If anybody has a manual for the AIWA cx-zht63u I would like to buy a copy or?
    jcruse3@alltel,net
  • MIKEYSMAGIC Sep 07, 2008
    I RECENTLY GOT AQUIRED A OLD(?) AIWA RECEIVER(AVD58)SUPER T BASS" -5 SPEAKERS AND -BASS SUBWOOFER-AFTER HOOKING UP THE SPEAKERS/SUBWOOFERS-ONLY 2 SPEAKERS COME ON AND THE SUBWOOFER IS SILENT-IM WONDERING IS THE SYSTEM FAULTY OR DID I ASSEMBLE IT WRONG.........HELP!
  • irsagent Feb 22, 2009
    Everything works but the three small speakers.
I have this problem all the time. you have to take the back of the stereo off, then clean the lens on the CD with a soft cloth. i've tried cd cleaners that have a brush on an actual CD - doesn't work. you can only fix this problem by opening it & cleaning it with a cloth.
Posted on Sep 18, 2008
Trying to connect my Aiwa VIDEOplus video player to tv to sort out old video tapes. Lost the manual re what goes where.
Video cassette players usually have three output leads: right audio (R), left audio (W), and video (Y). These connect to corresponding inputs on the rear of the TV. You will have to select the appropriate input source using the remote to be able to see what's playing.
Jul 26, 2016 | Aiwa Audio Players & Recorders
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
I lost the manual to the magnavox dvd/vcr dual player so i dont know how to set it up. so i can watch dvds and vcr tapes.
The easiest way to hook up the combo is to use the cable in and out to tv connectors located in the rear. for this connection you will hgave to set the TV to Channel 3 or 4. You can usually download an owners manual from magnavox.com, you will need a model number.
Mar 19, 2010 | Philips Magnavox DVD/VCR Dual Player
I have a new rca receiver and have it hooked up to my dvd player which works fine. I have it hooked into my tv and Im not getting sesurround through my tv how can I connect to the tv to make it work my tv...
Take a clue from the 10-year old vintage of the TV and the two analog audio cables. It's Dolby Pro Logic Surround at best, not Dolby Surround in the modern, digital, multi-channel sense.
TV's are not the source nor the end of a multi-channel audio chain. Feed this thing a 2-channel source from a Cable Box (into the "TV" jacks), DVD, Video Tape or CD with proper Dolby Surround encoding and will seem to open up the sound field a bit and kick in a little surround effect. It can also simulate a Hall effect and Dolby 3 stereo.
http://en.wikipedia.org/wiki/Dolby_Pro_Logic
Jan 27, 2010 | RCA RT2400R Receiver
AIWA CXNMT 520 CD/TAPE/RADIO PLAYER
Click Aiwa Support to download required user manual for CX-NMT520 (NSX-MT520) that has all info about this sound system.
Thanks.
Dec 18, 2009 | Cameras
No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Feb 05, 2009 | Pioneer VSX-D608 Receiver
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Tape deck does nothing when play is pressed
Maybe a problem of no power to motor. I own 2 identical Aiwa units, both have tape deck problems. This brand is prone to them They also have nasty habit of tape cassette doors jamming.
1st off you never said how old the unit is. Awia have huge amount of models. Mine are the NX series that came out in black plastic. Most of the others are silver/grey. Honestly, unless you pop side screws and lift the cover off to eyeball anything loose. and none is? And if out of warrenty, the value of fix, mat exceed value of unit.
Sorry, but I see many of these,  of 4-5 yr old units Aiwa brand,
get the heave ho!
The most stupid thing about this is: for units size, has the best sound of any other brand it's size.. Brilliant for hooking to ones TV sets, for  surround sound!
What I did was get an older getto blaster  that plays tapes to play my tapes on. some of these units are around and in good order, dirt cheap. And most electronic equipment problems cost at least $35  just to have a quick look at your unit.. cost of repair on top?  I brought my 1st one new @ well over a grond. 3 yrs later, 2ns one, exactly the same $15.00 in a charity shop. The  laser unit was dusty. All go in half an hr. Perhaps if it is an older model , look for another mate to it,   It all comes down to costs.
Which is better option... you are the one who has to made the choice. Good luck. Jamz
Oct 25, 2007 | Aiwa NSX-AJ20 CD Shelf System
No sound from stereo
If you can hear a hiss then the spkrs and amp are OK. It sounds like you're not on whichever source you're wanting to hear or it is on mute. Make sure ther is no function enabled that turns the sound off or over-rides it (like a tape monitor or AUX in...).
Sep 09, 2007 | Aiwa NSX-DS55 CD Shelf System
Center, surround speakers not working. "Can't Use" message for DSP.
Sounds like the old stuck button thing after a move??? What i mean it go over all the push buttons and maybe you will find one that is not pushing in and returning??? If alls ok then you should check the obvious like bent shafts or balance controls ect. ay have jogged something inside and you will need to see a pro to assit you unless you know how to trouble shoot solid state electronics?? These units have no real serviceable parts inside. Check with your owners manual for the sevicer nearest you. If they are not listed call the service # or try 1-800-289-AIWA . good luck
Jun 06, 2006 | Aiwa AV-D50 Receiver
1,744 people viewed this question
 Grubhead
Grubhead
