Question about GPS
Tomtom 510 battery not holding charge - GPS
  • Anonymous Mar 04, 2009
    battery light always flashing on low and green light on nav is on , but not charging and then switches off !!! press the front of the unit to put some force on it and batt light shows charging
    happened last year it was the pcb
  • gquadri2000 Apr 12, 2009
    i have the same problem. after installing the new battery, battery light falshing and showing low battery. Green light is on but no indication of charging even on car charger or home charger. When some pressure is applied for few seconds charging shows.
    Problem Solver:
  • 12 Answers
You can get a new battery for your TomTom 510 at NewPower99.com
Posted on Nov 21, 2010
How do i get the battery out of a t/t 510
Posted on Jul 29, 2008
3 Suggested Answers
homemender
  • 158 Answers
SOURCE: battery will not hold charge on tomtom 300
TomTom will not service tomtoms out of the warranty period. I tried them and they dont . They say / argue that there are many companies offering service . I would suggest that the battery is user replaceable with a little bit of DIY knowledge. You need the correct screwdrivers whicth are Torx type. You can buy them cheaply in sets from size T5 up to T20. First remove screen surround by pushing the windscreen mount clip underneath the tomtom , towards the screen. This will push the surrounf out enough for you to grab the bottom of it and pull it off. Next unscrew the 4 torx screws located in 4 holes around the screen. Next , extract the tomtom 'innards' by easing the assembley out of the front of the case. Next , unscrew the 2 torx screws that hold the speaker in place. Next , remove the 2 smaller torx screws UNDER the speaker. This will then allow removal of the plastic clamp that holds the cylinder shaped battery in place.NEXT , unplug the battery ( theres 3 wires go to a little plug on the circuit board ) and withdraw it through the gap left by the speaker. Fit NEW BATTERY ( available off ebay ) and reassemble in reverse order. Of course all this should be done very carefully. DO NOT RUSH. Work on a clear bench and put something soft on the bench to protect the tomtom. DO NOT force anything , it should all come apart easily. If you are unsure , inexperienced at messing with fiddly things or just plain nervous then get someone else to do it.
Posted on Jun 12, 2008
  • 171 Answers
SOURCE: My TomTom 510 will not hold charge and now cannot be switched on
If you are not bothered about using it on battery your tt should work if you have it hooked up to a external power supply such as the car charger or home charger. If it doesn't work using either of the power supplies then your problem is deeper than just needing a new battery. Check the pins on the bottom of your tt to see if they are bent, or out of place. The most common problem for them is the negative pin on the far left with the lcd screen facing away from you gets bent or is not making contact even though the green light is on.
Hope this helps
Posted on May 04, 2009
MY TOMTOM GPS NEED TO BE TO RESET
I will advice you reset the unit, this might help fix the abnormality with the white screen problem. follow these procedure to reset your tom tom gps.
Make sure your battery is charged before you begin. TomTom suggested allowing your device to charge for at least 2 hours before resetting it. Remove your device's SD card from the card slot.
Find the "Reset" pinhole button on the bottom of the device.
Hold the "Reset" button down for 10 to 15 seconds or until your device resets itself. You will need a flattened paperclip or another small metal object to reach inside the pinhole.
Power the TomTom back on and insert your SD Card. You have now reset your TomTom gps and this should fix the white screen problem.
Take care.
Jun 28, 2010 | Tomtom GO 510 GPS Receiver
Tomtom 510 - packed up
try re setting the TomTom, reset button is founded on the bottom underneath where the docking mount connect, hold down for 15 seconds, then press the little button on the top on the right side while turning on. worked for me
Jun 06, 2010 | Tomtom GO 510 GPS Receiver
Tomtom 510 doesn't reset
Before you keep resetting your tomtom I would intall a new battery. Call your closest "batteries plus store" or "radioshack store" and then try to reset it, it might be only the battery and nothing to do with the reseting.....
Mar 24, 2009 | Tomtom GO 510 GPS Receiver
Tomtom will not start
I had a similar problem, ther is a minute reset button where the connector is under the unit, it requires a pin to press it!
Mar 22, 2009 | Tomtom GO 510 GPS Receiver
Tomtom go 510 battery won't charge and unit will not switch on
Claire.....honestly, it it going to ge a hit or miss if it is going to work or not.....just be prepaired if it does not work
Mar 06, 2009 | Tomtom GO 510 GPS Receiver
Frozen tomtom
You can get your original splash scren from here. You can also download free splash screens created by user through TomTom HOME.
To correct your device, try:
1. Hit the reset button on the back of the device - inside the serial connector.
2. Make sure the device is off and connect it to your computer via USB dock and connect the charging cable (green light should be on)
3. Hold down the power button until the device restarts.
4. The device should automatically connect to your computer.
5. Run TomTom HOME and check for any updates.
6. If there is no new application, try: www.tomtom.com/9091 <-- that will show you how to remove and then reinstall the application.
Dec 22, 2008 | Tomtom GO 510 GPS Receiver
I purchased tom tom go510 14months ago, but it will not charge in house or car charger, what shall i do, this cost me over 269.00, i am not very happy its only lasted just over 12 months
I would call tomtom and see if they can send you a new battery sounds like it might be bad,is the green light showing that's it charging?if so and the battery isn't holding a charge I would call them and say that it went bad about 2 months ago.Good luck
Jul 28, 2008 | Tomtom GO 510 GPS Receiver
TomTom go 510
COMMON PROBLEM SO FAR WITH THESE. IF STILL UNDER WARRENTY CALL TOM TOM THEY WILL REPLACE THE BATTERY UNDER WARRENTY
Feb 20, 2008 | Tomtom GO 910
Is there sonething wrong with my tomtom go 510?
Usually resetting the unit (pressing the reset button) is supposed to fix this
Oct 22, 2007 | Tomtom GO 510 GPS Receiver
GPS Logo
836 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
