Question about Panasonic KX-FL501 Plain Paper Laser Fax
Fax is in an Endless User Stopped, Saving Data Cycle
Yesterday I was making copies. The first copies went through fine. I was only trying to copy 4 pages two at a time. By the fourth copy the fax machine failed to copy and started an endless Saving Data Cycle, so I pressed the Stop button as in the past, but the User Stopped Saving Data button is flashing endlessly and one cannot do anything else. I do not know if anyone can send a fax or not. I know I cannot do anything at all. I have held the button down for many seconds, but it is the same.
Is there a way to get this thing to turn off and back on again by any button. I cannot find a turn off or reset button anywhere.
Thanks a lot. Donna - dkkdolls@aol.com
    Genius:
  • 2,120 Answers
Try unplugging the machine.
Posted on Sep 01, 2008
What does Standby indicate when sending fax
There is some reason's it's given bellow.
  1. Fax is not working properly
  2. Fax configuration error(user level OR programing level )
  3. Machine is in off line.
  4. It's fax copy or document saving to the fax memory.
  5. Fax Line is Faulty.
For more help send me the details about this
Tks
Feb 10, 2015 | Canon PIXMA Office Equipment & Supplies
Changing forwading Fax ID address from fax Canon JX200
This information appears at the top of each document you send.
1 Press [Menu].
2 Use [{] or [}] to scroll through the menus and select <DATA REGISTRATION>, then press [Start/Copy] twice. The LCD displays <DATE & TIME>.
3 Use [{] or [}] to select <UNIT TELEPHONE #>, then press [Start/Copy].
4 Enter your fax number (up to 20 digits) using the numeric buttons, then press [Start/Copy] twice (see page 9).
You can enter a space to make your number easier to read.
5 Enter your name (up to 24 letters) using the numeric buttons, then press [Start/Copy] (see page 9).
6 Press [Stop].
Registration ends and the fax returns to standby mode.
Nov 19, 2011 | Office Equipment & Supplies
Want copy ---comes up unrecoverable scan---ties up machine for 5-10 minutes---LEXMARK 5600-6600---IT also makes a knocking sound. until red light goes off and green light comes.on---1st time happened...
Unrecoverable scan error is a hardware problem. Features affected by this error are scan, copy and fax. Recommended action is to contact Lexmark technical support for assistance.
Sep 20, 2010 | Lexmark All-in-One Printer with PictBridge
Lexmark x7350 will not scan, fax or copy
If under warranty contact mfg for warranty repair locations
Sep 09, 2017 | Lexmark X6170 All-In-One InkJet Printer
Hp officejet 4110 all in one
I have the same experienced the same problem. When trying to copy I go through an endless loop of copy options without the ability to actually start the copying process.
Jun 17, 2008 | HP Officejet 4110 All-In-One InkJet...
Bad print with repeated text on fax or copies
Make a copy and shut the power off or open a door when the paper is 1/2 way into the machine. You are just basically going to have to try to time it. When you hear paper being fed into your machine (the blank paper from the tray) count about 3-5 seconds and then open a door on the machine or shut the power off. IF you have timed it correctly, the paper should be 1/4 - 1/2 way through the machine. Remove the jammed paper **** But be careful..... The toner is NOT FUSED at this point so it will rub off if you brush it up against your clothes or hands. If the image is doubled at this point.. then its the drum unit. If the image is good at this point, then it is probably your fuser.
Hope this helps.
Good luck.
Mac =)
Apr 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Trouble saving data on a dvd from my computer..
you need Winavi to convert to a DVD format
Nov 02, 2007 | Mitsuba mv300 Camcorder
Even vertical lines on fax/copy
TYPICALLY SF900 FAX USES A DIFFERENT CIS SCANNER , THSI SORT OF INDICATION IS EITHER SMPS BAD OR CIS SCANNER BAD. HAPPY FAXING OMNIRESENT
Sep 16, 2007 | Panasonic KX-FHD331 Plain Paper Thermal...
Check paper size comes up all the time. Also pulls anywhere from 4 - 10 blank pages through at once.
dear sir pleaz select the correct paper size in the user data programing of your machine
Sep 10, 2007 | Canon FAXPHONE L80 Laser
Panasonic KX-FL501 Plain Paper Laser Fax Logo
43 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
