Question about Nintendo DS Lite Console
DS LITE SCREEN ISSUES
I just replaced a Power Switch on my Nintendo DS Lite, And it powers on as well as charges perfectly fine now.
However once i turn the power button on the screens stay black no backlight or anything. I have unplugged the screens(top & bottom) and plugged them back in repeatedly but it doesnt seem to be working.
Is it possible that the Ribbon Cables are bad??
  • 1 more comment
  • Ian Wade Apr 16, 2008
    Nintendo DS lite 2006 USG-001
    Power Switches are the same.
    I have already disconnected and reconnected All Screen ribbon cables.
    It is Both Screens. Top and Bottom.
    Screens Are total black nothing.
    how would i go about using a multimeter to check that power is getting to the screens ??
    Genius:
  • 3,422 Answers
HI,
One thing is for sure the problem is internally.You will have to get it repaired by a tech or replaced to fix this problem and that's the only solution.
Anyways i have got some links dealing with screen problems.Please do check them out.
CLICK HERE
CLICK HERE
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 16, 2008
    Master:
  • 788 Answers
Is it both screens or just the one? Which one?
It's not the backlight as you should still be able to see the screen with the backlight off as it is on option to play with it off. I would beleive that the screen(s) is/are not getting power. Check the connections, you could try using a multimeter to check for power while you have the DS opened.
  • Dean Joly
    Dean Joly Apr 16, 2008
    I'm trying to find a schematic so that I could tell you what pins to check. I'll get back to you.
  • Dean Joly
    From what I can tell, the smaller cable comming out of both screens with two wires is the power, check to see if there is power comming from the connector this cable plugs into.
    Master:
  • 377 Answers
Possible on the flat ribbon cable has the problem, and 2nd if it's not the cable its possible the problem is on the backlight on the screen...
Please check the contrast of the screen..
Thanks
  • 552 Answers
First try disconnecting anything that you had disconnected during the repair.
Check to see if your power switch is indeed the same kind as the original.
Be sure you hooked it back up correctly.
By reconnecting everything that was undone, you may solve the problem when you repeat your steps.
  • Hjalmer Lamminen
    Hjalmer Lamminen Apr 16, 2008
    If you are using a battery pack, you may have an undervoltage shutdown.
    Be sure the battery is charged well and if you are using an adapter, make sure the voltage from the adapter transformer is correct.
    Usually shutdowns occur because of low voltage.
    Genius:
  • 1,142 Answers
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
  • Maanita Chadha
    Maanita Chadha Apr 16, 2008
    Check this url this might help you.
    http://www.whatconsole.co.uk/nds.php
My DS Lite wont charge! Help!
Try another charger, yours may be faulty. Alternatively,the battery may need replacing as it is no longer holding charge, these can be obtained very inexpensively from Ebay and you will just need a small cross head screwdriver to remove the cover on the back of the DS lite, then tap the unit in your hand to dislodge and remove the battery.
Dec 22, 2013 | Nintendo DS Lite Console
Nintendo ds lite help
Maybe the battery is defective. try to replace it.
Jun 29, 2010 | Nintendo DS Lite Console
NINTENDO DS LITE WON'T CHARGE OR POWER ON
Each time you charge your battery, the charge capacity is decreased. After a large amount of charges, the capacity is decreased to an amount only enough to turn on a/the screen(s) for a second. Try getting a new battery.
Mar 02, 2009 | Nintendo DS Console
Power gone on nintendo ds lite
Hey if you have a warranty nintendo might repair or raplace the Ds.I thought about replacing the charger or place the charger in another power outlet.I hope I helped.
Dec 30, 2008 | Nintendo DS Lite Console
Nintendo DS Lite won't come on
@JoepIt, you have a defective LCD screen. Could be upper of lower (I thing for 99% the upper).
@pietras1422, on the mainboard next to the power-switch, there is a resistor. If could be loose or is missing completely. Problem will occur when the DS Lite is dropped to the ground
Nov 18, 2008 | Nintendo DS Lite Console
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
Nintendo ds lite not turning on
see if you need new carger or if it needs new batteries
Jun 26, 2008 | Nintendo DS Lite Console
Ndsl power problem
As Bob (HowlingMad) said, the Ds and Ds Lite will turn off immediately after being turned on if the connection to the top screen is broken.
Check the connections between the screen and Ds, if they look damaged then try replacing the ribbon cable for the top screen (or you may have to replace the whole screen - i'm not sure if it is built together on the Ds Lite). If the connections appear fine then it may be that due to the movement the connector has come out of it's socket/plug (also like Bob said), this is easily fixable if this is the case and would require you to take the casing off your Ds and plug it back in.
Hope this helps
Mowcius
May 07, 2008 | Nintendo DS Lite Console
No power and battery is charged
try going to game stop they sell ds or ds lite batiers i think thats the problem
Nov 19, 2007 | Nintendo DS Lite Console
Nintendo ds lite will not turn on, when trying to charge the orange lite blinks once.
after researching this for a while, i heard that it is because the fuses have blown inside the ds. you can try to fix it but it is risky.
good luck!
Sep 17, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
75 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
