Question about Sony STR-DE597 Receiver
Stuck protector mode
After replacing blown fuse 8amp receiver turns on then 3seconds protector is displayed whats the problem help.
  • 158 Answers
Find out why the fuse blew in the first place.the protector is just PROTECTING the main circuits of the receiver.the receiver turns on just to confirm the power circuit is OK.
have it checked by an electronic engineer.
Posted on Apr 16, 2008
When pluged in the On/Standby LED will light. When pressing power the On/Standby LED with flash then go solid but nothing apears on the display. I can select what speakrs to use (A or B). All the LED's...
Most likely the unit does not receive power from main transformer. Possible several reasons:
- bad power transformer
- bad main internal fuse 7-8amp. Bad fuse most likely because of one of the channel is blown and shorts the power, so before installing new fuse good idea to check all channels by meter or at least visually for burned parts
- bad power relay
- bad connection, cracked soldering joints
Jul 18, 2011 | Denon AVR-1602 Receiver
I have to replace 2 fuses 8Amp 125volts from a sony reciever, but I can't find it to buy , do you know any site to order on line or if I could use 8Amp 250volts?
fuses have different sizes even though they have the same rating's, the best remedy to do is, do you any stranded wire, cut one piece out of the whole strand and solder it on the fuse housing that will do the trick.
Jun 09, 2010 | Sony STR-DE935
Sony STR-DE945 8A 125v fuses
Check HomeDepot they have 7amp , maybe your store has 8amp.
Dec 18, 2009 | Sony STR-DE945 Receiver
My 50" Plasma blew a 8amp fuse at the power supply. I replaced it, and the TV works again, buy why would this fuse have blown in the first place?
if the fuse was at the or near the AC plug chances are your got a power surge, if you did you got very lucky the fuse was there you might want to get a surge protector on the set ... But sometime you get just a defective fuse as long as the set is working I would not worry about it
Dec 07, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
May 27, 2009 | Sony STR-DE635 Receiver
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
Sony STR-DE597 Receiver Logo
948 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
