Question about Canon PowerShot S5 IS Digital Camera
Focusing problems My 6 month old camera wont focus properly. Instead of green boxes in my viewfinder I get one yellow one..so all my photos are out of focus. How do I correct this
  • tommytoff Apr 30, 2008
    I haven't been getting different colour boxes but I have got the same focussing problems. It takes a few goes at half depressing the shutter button to get a good focus. Or even using a different picture setting. As I am not happy I have sent it in for a warranty job just yesterday. My S2iS didn't suffer any of these problems.
  • KevinO May 28, 2008
    I have an S5, and I bought an additional zoom lense and a wide angle lense so I could take pictures at sporting events, and when using these lense I can't seem to get them focus. Any suggestions.
    Thanks
    Kevin
Many things can cause this problem. Here are some ideas:
First be careful not to block the Focus assist light with your left hand while holding the camera.
Some setting won't let you properly focus (like being in macro mode from too far away).
Posted on May 15, 2008
Problem with viewfinder - focus?! I've been using my Nikon d3000 for over a year now. Few days ago I tried to take a photo but when looking through the viewfinder, the photo wasn't focused. It was...
There's a diopter control near the viewfinder to adjust the viewfinder to your eye. Try adjusting that while peering into the viewfinder and try to get the focus brackets and the data at the bottom of the viewfinder into focus.
Jun 20, 2011 | Nikon D3000 Digital Camera
My canon 18-55 lens will only take a picture in wide angle. as soon as i try to zoom at all it won't take a picture. it is 4 months old and hasn't been used much. and i haven't dropped it. any suggestions?
The Auto-Focus on the lens is damaged. I have had the exact same problem with my 18-55 and I ended up buying a new one because I take shots at weddings and I can't afford to manually focus each photo. You can still use it if you switch the small knob to MF and then use the focus ring for manual focus.
Jan 18, 2011 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
The electronic viewfinder will not focus. Photo results, however, are properly focused. LCD properly focuses, but I prefer to frame my pics using viewfinder. What's the fix?
There's a diopter adjustment control near the viewfinder. Adjust it while peering through the viewfinder until the image suits your eyes.
Sep 10, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
I have the Olympus E-510. I haven't used it for a while but I have recently had a baby, so I've pulled it out from its hiding spot. The problem is, when I look through the viewfinder it's all blurry and I...
First make sure that the viewfinder glass is clean. If that is not the problem, it may be that the diopter adjustment has been accidentally changed. On the right side of the viewfinder screen is a very small knob. This adjusts the focus of the viewfinder to your vision. Aim your camera at a stationary object and let the camera auto focus. Look throught the viewfinder and turn this knob one click at a time until the image is clearest to you. Hope this helps.
Aug 05, 2010 | Olympus EVOLT E-510 Body Only Digital...
Appears in focus in viewfinder, but isn't
Change your focusing setting to spot focus. Then, focus on your main subject, keep the button half-way pressed while you re-compose the shot and then press it the rest of the way. Does that improve the shot?
Sep 21, 2009 | Nikon D100 Digital Camera
RE: LG CU920 camera focus problem
Press the shutter button partially down and hold it there. The image centering box will turn green momentarily and then you can take the picture and it will be clear. I almost returned the phone because the pictures were blurry before I figured this out.
Jul 09, 2009 | LG Vu CU920 Cellular Phone
When take photos it looks in focus through the viewfinder, but the pictures come out slightly out of focus
I'm not sure what camera you are using. But I believe you are taking pictures like the old Kodak Instamatic which you just literally point and shoot. Even then people took blurred pictures. There are 2 reasons I can guess. First is you are pressing the shutter button too fast. When you press the shutter, it should be like squeezing the trigger of a gun. You SQUEEZE slowly. Not press the button and let go. After you hear the camera has done all the sound it wants to make that means you picture is being recorded. And hopefully it will be clear. If it still isn't then it means your camera take a little bit longer to focus on the subject. That's what happened to my wife. She thinks she can point and shoot and that's it. You need to camera a few seconds to focus. I know the Casio's have a little beeping sound that tells you it has focused and is ready to shoot. My Konica Minolta does the same but I see a box on the screen (I took the sound out). You need to listen for that tone that tells you you camera has focused on a spot and is ready to shoot. In order for the camera to do this you need to press the shutter only half way. When you hear the tone then slowly press all the way and don't move till all the clicks are done. That's usually 0.5-1.5seconds only. Hope this helps.
Nov 19, 2008 | Canon Cameras
Green focus box
It might be because u r working in macro/supermacro mode (u can see a little flower on top of the viewfinder/lcd display) and focusing on a distant object or u try focussing a subject placed very near the cam while working with non macro mode. If changing these doesnt solve ur prblm, plz provide full details of what mode u use, what u r focussing on, what is the lighting conditions u used, etc..
Dec 11, 2007 | Canon PowerShot S3 IS Digital Camera
DSC D700 Focus Problem
Yes, many people can use the diopter control to fix the manual focus set-up. Others have had to send the camera back to Sony for internal adjustments.
Sep 08, 2005 | Sony Cyber-Shot DSC-D700 Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
122 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
