Question about Rangemaster 110 (Gas) Kitchen Range
RANGEMASTER CLASS110LPRG/B Do you know what the metres cubed per hour is for this appliance. So correct gas supply can be installed alongside a combi boiler? Thanks
  • Paul Carew May 11, 2010
    you need to know the btus of both for pipe sizing
  • Steve Smith
    Steve Smith May 11, 2010
    Hi, It all depends on the size of your property, and what combi boiler you're having, also the distance from your meter, sp please proveide the following: 1) How many bedrooms 2) make of combi boiler 3) distance from meter to combi I can definitely help after you have given me the details. Thanks Steve
  • Rangemaster Master
  • 3,253 Answers
You need the btus of both to size gas pipework
Posted on Jan 23, 2010
After moving my gas meter from inside the home to outside and having a semi concealed meter connected we cant get the combi boiler to work properly we can get hot water and have the gas fire on but
your boiler needs a minimum gas pressure of 16 mb to light successfully. if your gas pipe has been extended it has to be able to flow enough gas. it may need upgrading to 28mm for even as little as a metre from the gas meter. if your central heating works ok when the fire is off then this is your problem
Oct 12, 2014 | Water Heaters
Rangemaster 110 on lpg wish to convert to natural gas
You must get a tradesman or technician who is qualified to convert a gas appliance, your local gas fitter or plumber should be able to help with this. the regulator needs to be changed the jets also need to be swapped out for the type of gas to be used. normally from lpg to Natural gas the jet size needs to be increased by installing new jets or by drilling out the old ones
Hope that helped
Oct 22, 2013 | Rangemaster 110 (Gas) Kitchen Range
I dont know how to calculate m2
Hi, a cubic metre is a measure of volume, a square metre is a measure of area. you need to know length and width as well as depth. eg; imagine a cube is 1 metre wide by 1 metre deep by 1 metre high, this is 1 cubic metre, if you sliced this cube into 10cm slices it would cover 10m2. if you sliced it into 5cm slices it would cover 20m2. I hope this helps.
Mar 14, 2013 | Cars & Trucks
Poor quality ice
Is the ice too small or is it dirty in appearance? If it is too small then the 1.4 inch water supply line may be pinched or clogged. Trun off the water to the unit and remove the line connected to the rear of your fridge. Then get a large bowl and have someone turn on the water supply. If there is sufficient pressure then more than likely the inlet screen to the ice maker water valve is obstructed and will require cleaning. Follow the input water line to the ice maker water valve. Some valved can have the screen cleaned with the valve installed by removing the input line and then the input screen. You can gain access to the screen by removing the flexible back panel, remove it by using a pointed tool on the outside of the screen ede only. Then wash / or scrub it clean with your fingers while running water over it. Reinstall the screen, reconnect the valve input line and then reconnect the water supply line and turn on the water supply. It can take several hours before the unit starts making ice cubes again as you have intorduced air into the system and it will self purge during the next few ice making cycles. You should have the correct sized cubes within 24 hours. If the cubes are dirty then go to any appliance parts supply store, purchase a charcoal filter and install it just above the inlet supply line connection.
Jan 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My subzero 680, the icemaker has low ice production.
How many cubes is it producing per harvest and how many harvests are you getting per day? You should be getting 8 harvests per day with 8 cubes in each harvest giving you 64 cubes in a 24 hour period. Are the ice cubes formed well? What is the temp in the freezer? Let me know this information and I will hopefully be able to give you a solution
Jun 17, 2009 | Refrigerators
Where can i buy a set of jets to convert to lpg a tecnik range cooker,dual fuel,model no.1285 ,please.
From the manufacture of the appliance.
Contact Us Office Hours: 9am - 5:30pm Mon - Fri Trade Sales: 0161 786 4692 Appliance Care Service: 08705 678910 Spares: 08705 543210 Whirlpool Service Service & Spares: 0870 600 8989 Rangemaster Service Service & Spares: 0845 603 5312
Apr 09, 2009 | Tecnik TKC1285 Dual Fuel (Electric and...
Rangemaster Disconnect the gas to move house
I dont know if your in the UK but if you do disconnect your gas feed the way MrMark has mentioned you will be breaking the law.. you'll need to be corgi registered to do it that way.
BUT.....
Again if you are in the UK, some gas supplies were fitted with a quick release system.
With this all you need to do is slide your cooker out, locate the connection at the wall, not the back of the stove.
Press down on the top of the connector and turn the pipe coming out about 1/4 of a turn and it will release and self seal the gas outlet.
Jan 28, 2009 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 gas model
I have downloaded the users guide from rangemaster.co.uk which has details of how to change parts & a wiring diagram, Hope this helps. Here is a section..............
5. To Remove Clock
Disconnect from electricity supply.
Remove the Control Panel (See 2). Pull off the timer
control button(s).
Remove the timer/mounting bracket assembly from the
control panel by removing the fi xing screws.
Remove the timer from its mounting bracket by
depressing the plastic lugs on the timer case, at the
same time pulling the unit forward.
Reassemble in reverse order. When replacing leads
refer to the wiring diagram. Check operation of timer.
BEFORE SERVICING ANY GAS CARRYING
COMPONENTS TURN OFF GAS SUPPLY.
Sep 07, 2008 | Rangemaster 110 (Gas) Kitchen Range
Leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Nov 13, 2007 | Ovens
Range master toledo 90
I would follow these requirements if I were you:
The cooker must be connected to the correct electrical supply as stated on the voltage label on the cooker (This is obvious so far!). It should be connected through a suitable cooker control unit incorporating a double pole switch having a contact separation of at least 3mm in all poles (This means one of those big red switches with "COOKER" written on them). The cooker must NOT be connected to an ordinary domestic power point. The cable size used should be between 6mm squared and 10mm squared twin and earth. Where the installation is protected by a 30 milliamp sensitivity residual current device (RCD Breaker), the combined use of your cooker and other domestic appliances may occasionally cause nuisance tripping. In these instances, the cooker circuit may need to be protected by fitting a 100 milliamp device. This work should be carried out by a qualified electrician.
Oct 28, 2007 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Rangemaster 110 (Gas) Kitchen Range Logo
91 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
