I have an acer 4050 Travelmate, it has just suddenly stopped charging the battery. The machine works with the battery out and on 240v. If you put the battery in and on 240v it wont turn on. The battery has been working fine and has had good life between charges. Can anyone help, could it be setings or is it battery
  • markymarkdot Apr 16, 2008
    Thanks for that, It sounds to me that the lap top has been programmed to break down. I have someone who can check in to this. The problem did start after I accidently removed the battery by catching my finger on the release clip, although the battery did not come all the way out. Thank you very much for your help. Some one else said about trying to recalibrate or reset/Flash the BIOS?
    I don't fancy doing that. I suspect now that a new battery will still not work.
    Genius:
  • 1,027 Answers
Sounds like the battery and how the system is wired (circuits)
Some systems require the voltage reg chips to run through the battery before turning system on. When the battery fails, the system will not boot, the dead battery interrupts the circuitry.
Once the Battery is removed the open circuit then is allowed to go to a new path.
Try this. boot up system and go into set up utility. plug in the battery, if it shuts down, get new battery. If it accepts it, save settings and reboot into OS.
Posted on Apr 16, 2008
  • Mark Williams
    Mark Williams Apr 16, 2008
    Check the pins both on the battery and on the motherboard
Bluetooth of my computer does not work , My computer type is : Acer , TravelMate 4050. Please help .
is the blue tooth mode running you can check this by going to your start menu and look for a folder named acer or acer tools or bluetooth and see if its running also ctrl alt del at teh same time bring up task manager and look for something called bluesolil (sp) .exe running.if its not on or there is no option you need to re install your blu tooth drivers from acers website. some of there travel mates DO NOT contain blu tooth tho
Mar 26, 2011 | Acer TravelMate 4050 Laptop Charger...
Free download acer travelmate 4050 serios cl51 drivers
The only drivers available for this laptop are for Windows XP.
You can download these drivers directlyu from Acer:
http://us.acer.com/ac/en/US/content/drivers
From this page, choose "Notebook" then choose "TravelMate" then "TravelMate 4050"
You will see that Windows XP is the only operating system selected, and Windows Vista and Windows 7 are not selectable.
The two choices for Windows XP are XP Home Edition( 32 bit) and XP Professional Edition( 32 bit)
The drivers listed here are for:
Intel Chipset
Realtek Audio
ENE Cardbus
SMSC FIR( (Fast InfraRed) A high-speed IrDA protocol with data rates up to 4 Mpbs.)
RealTek LAN
Agere Modem
Feb 27, 2011 | Computers & Internet
Acer travelmate 4050 bios setup password, reset password is required
hello, and I have a problem with Acer TravelMate 4050 and the problem lies in the total extinction of the system, namely when you turn on Windows light up when you enter and suddenly black screen and do not even think about blocking it immediately, but he remains on but do not think .... that is the problem?waiting for a response or contact id doi_ochii multtumesc advance ....
Oct 05, 2010 | Acer Computers & Internet
I'm using acer travelmate 4050. The problem is all 3 usb port did not detect anything attached to it.
hello ... can you add to doi_ochii yes? have a problem with an Acer TravelMate 4050 block of everything I and my lcd is black cateoodata ... waiting to talk more beautiful there ... thanks
Jun 09, 2010 | Acer TravelMate 4320 Notebook
Acer Travelmate 4060. Dead. Flashes power/battery led once when I hit the power button then nothing
Try removing the battery and plugging the machine in as if you were going to charge it, then try starting it up.
If it doesn't start up, check the connections on the adapter. If everything looks fine then theres a possibility that you have a broken adapter.
Mar 30, 2010 | Acer Aspire 4520-5582 Notebook
Battery works and then doesn't
first off all remove the batterey and just connect the laptop directly to the power adaptor and check out is it working properly with out battery as it should work without battery on power adaptoir.if it works that means the battery is faulty if it does not works that means the laptop main board is having loose connection problem get it repaired do not do it your self very risky.
Mar 02, 2009 | Acer TravelMate 2201LCi Notebook
Batter Not Charging
if your unit can charging battery from 0% to 28%, it's mean your battery is bad.
But if your unit can't charging battery at all, it's mean your motherboard is bad,
Jan 25, 2008 | Acer TravelMate 2300 Notebook
Acer laptop problem
Is the charging light on when connected to ac, is the battery old or new? The power supply connector might be faulty either at the cable side or inside the laptop.
Jan 12, 2008 | Computers & Internet
Computers & Internet Logo
169 people viewed this question
David Payne
David Payne
