Question about Microsoft Windows 98 for PC
How install windows nt work station 4.0
Hello sir ,
tell about .
how slove the problem disk boot failure
  • 552 Answers
Before deleting your current windows version, you should do a "wipe disk" for you hard drive.
This requires that you be able to get to the program in windows that will allow you to do that.
otherwise, you need to go online and find a good program that is freeware and download that.
Look for a boot disc creator and one that has "wipe disk" feature in the same program.
www.download.com is a good website to look for one.
The disk boot failure is probably due to having or having had windows 98 on the comuter.
If you are going to load wondows nt, then you need a program that is compatable with it and then make a boot disc.
Posted on Apr 16, 2008
NTLDR is missing means what?
NTLDR (NT Loader) is a crucial part of your Windows OS
Without it your system cannot boot up.
This tells me your OS is corrupted and possibly beyond repair.
If you have a Windows installation disk you could try booting up with it on and attempt a repair install. If that doesn't work your only other option is to reinstall Windows
Mar 03, 2015 | Computers & Internet
I have windows vista trying to install a learning disk, But every time I try to install it tell's me that windows does not support NT what does that mean? and how can I fix it?
Have you ever installed this on a computer running Vista? If not it may not be compatible with Vista (this was my first thought when I read your issue). Check with the manufacture to see if they offer a Vista compatible version.
Jan 29, 2012 | Microsoft Windows Vista Ultimate Edition
Can you please help me how to fix the BIOS ROM CHECKSUM ERROR. TO MY MOTHERBOARD (TRINITY 400 S1854 AGPX4-PCI-ISA) i reformat the windows NT version 4, and after i restart, the message come bios rom...
turn the computer off
now turn on and hold down the delete key until the bios screen appears
in the boot tab select first boot as the cd disk, install the cd for win nt in that drive
close down the cd and then restart and it will boot from the cd
BY reformatting the hard drive win nt you have wiped the win nt operating system from the hard drive
Feb 17, 2018 | Tyan Trinity 400 S1854 Motherboard
Hello sir, can i ask u abwt my computer problem? i need ur help nw bcoz i cant open the computer...it says here DISK BOOT FAILURE. THANKS
DISK BOOT FAILURE...
1st-check ur hard disk drive see if the sata/ide cable loose o not
2nd- change ide port o sata port
3rd- goto BIOS make sure HDD booting first
4rd- check ur HDD by scaning using windows chk dsk o use other utilities such as HDD generator
or something else
Oct 26, 2010 | Computers & Internet
What is NTLDR error sir?
NTLDR (abbreviation of NT Loader) is the boot loader for all releases of Microsoft's Windows NT operating system up to and including Windows XP and Windows Server 2003. NTLDR is typically run from the primary hard disk drive, but it can also run from portable storage devices such as a CD-ROM, USB flash drive, or floppy disk. NTLDR can also load a non NT-based operating system given the appropriate boot sector in a file.
NTLDR requires, at the minimum, the following two files to be on the system volume:
  • NTLDR, which contains the main Boot loader itself
  • boot.ini, which contains configuration options for a boot menu.
This error means that NTLDR is missing somehow from your computer,hard disk problem,virus.etc
You can go to that page and follow the instructions exacty as he says and your problem will gone:)
http://www.tinyempire.com/notes/ntldrismissing.htm
Jan 12, 2010 | Abit KW7 Motherboard
Hi, i have window vista homprimem when i
i have,nt slove problem.no driver can work for orbicam.
Jun 22, 2009 | 2008 Victory Vision Street Premium
System getting disk boot failure r disk error report
It could be a problem with your hard drive. It's starting to fail, may be some day you cant boot anymore. Try replacing it!
Jan 22, 2009 | Tablets & eReaders
Harddrive
Get into boot setup and change the 1st boot device as hard disk
Dec 30, 2007 | Computers & Internet
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Used Dell Dimension 3000 drive issues
If you mean you need to install windows, you need to set your cdrom drive as first boot device in advanced bios settings or it will try to boot into a non-existent windows. Make sure your hdd is showing as the master drive, save settings and exit bios. Re-boot pc with windows disc in cd drive and hit enter when prompted to boot from cd.
Jan 26, 2007 | Dell Dimension 3000® Pentium® 4...
Microsoft Windows 98 for PC Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
