Question about Hitachi DZ-MV730A DVD Camcorder
730 camcorder it wont power up at all.Is there a fuse that can go out
  • mennogeek Oct 04, 2008
    I Have the same problem with the same camcorder. the battery is good and it won't work on ac plug in either. any ideas?
  • mendez4047 Jan 24, 2009
    were in the same boat. Mine wont power up even when I plug it into the wall outlet. I fully charge the battery and it still wont power up or do anything. Can anyone help? is there a fuse or something the blows out that can be replaced?
  • 92 Answers
Well it sounds like the battery is dead. try charging it fully...if it doesn't work, then try getting a new battery for it, and if that doesn't work, try taking it in to a camera repair shop.
Posted on Jun 28, 2008
2008 jeep liberty flashers and lighter port wont work. changed fuses, still wont work. any help??
What flashes ? What fuse's did you change ? Only one fuse for lighter , M7 20amp located in the ( TIPM ) - totally integrated power module . There is a relay that powers that fuse , Run/ Accessory relay , also in the (TIPM) The TIPM is part of the under hood fuse box.
Oct 22, 2016 | 2008 Jeep Liberty
Rockola Model 490 2 Super Sound Juke Box wont power on
(1) Make sure the wall outlet has power. (2)Make sure the power switch is "on" (3) check the fuses. If you discover a blown fuse, be sure to replace the fuse with the correct value. If it blows again, you may have a more serious problem.
May 26, 2013 | Audio Players & Recorders
Power windows and power locks wont work
Check your fuses first. Then check for power at the switches, and power from the switches to the respective solenoid and motor. Most likely it's fuses. Also check where the wiring runs through the door into the car for bare spots in the wiring that might have blown the fuses.
Jan 21, 2010 | 2004 Mitsubishi Endeavor
I pulled a shorted fuse that was causeing some clicking. the clicking stopped and the car wont start. the fuse went to the lower beams it said in the manual. not sure why the car wont start.
do you mean a fuse that is blown? pulling out a blown or shorted fuse wont cause any changes, since the circuit it feeds will be isolated anyway. It sounds like you may have pulled out a good fuse that powers some essential components. will the car start when the fuse is put back in?
If the clicking you hear is due to a faulty electrical component, then try to identify which component the noise is coming from by listening to wear the clicking comes froms. Pulling out the fuse to that component will only cut the power to it, it wont provide a fix.
Nov 09, 2009 | 2005 Ford Escape
Wont read obd 11 at all
some cars power thes canner through the lighter fuse, if its blown the scanner cant get power from the obd2 plug.
Sep 18, 2009 | 2001 Dodge Caravan
My sx 950 wont turn on the lights wont work could it be a fuse?
Yes, check the incoming fuses over by the main power transformer first.
If the fuses are good, the next check will be power switch and then transformer itself.
Jul 25, 2009 | Pioneer Audio Players & Recorders
Their is power in the fuse and in the power line but unit wont start is their an internal fuse or am i missing something
Hello paul543,
First check all the fuses. The primary and any onboard fuses.
Then, in addition to the power wire, check the ground and make sure that there is +12V on the remote turn-on terminal when the head unit is turned on.
Hope this helps
May 01, 2009 | Car Audio & Video
Jump wont work. 80 amp fuse blown under hood. where does fuse go
that is the alternator and vehicle power supply fuse, did u jump this wrong? u will need to replace this fuse before the car will start.
Mar 20, 2009 | 2001 Kia Sephia
94 toyota corolla
The alternator fuse is BOLTED onto the power feed bar under/inside the fuse box; you cannot pull it out; you have to remove the top/bottom of the fuse box to gain acccess to the bolt that holds the fuse to the big metal bar that branches power to the other fuses.
Oct 24, 2008 | 1994 Toyota Corolla
Hitachi DZ-MV730A DVD Camcorder Logo
50 people viewed this question
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
