Add a cd/dvd to computer - Computers & Internet
    Scholar:
  • 55 Answers
Click on start menu, click on "run" type in : ADD <device> select DRIVE as "autodetect" ON = 1. The device should be teleported to your computer without hasitation !
^ Just a little joke. Ok here's what you REALLY DO:
What you need: A DVD or CD or DVD/CD Combo Drive, screws that came with it. A 80pin ide cable (IF YOUR DRIVE IS IDE) an additional free power source from your Power supply. One of the thick plugs that come from your power supply that usually have like 4 openings at the end with a red,black,yellow wires attached to it. A phillips screwdriver. Make sure you
1.) Power off your machine
2.) Unplug the power cord.
3.) Open your computer case (watch out for waranty seals: if on, let the cd-rom be built in by the people who sold you the pc, otherwise your waranty will be GONE
4.) Remove one of your "Drive bay covers" @ the front of your machine.
5.) Check that the jumper configuration on your Drive is set to "cable" select. On the device self, it should tell you which jumper setting to use.
6.) Slide in your Drive into the drive bay where you have just removed the little approx 3cm x 20cm cover (Dont forget to put it out of the box or plastic though)
7.) Now take the screws (4) and fasten your new drive in the drive bay by using the Phillips. Check to the front so that the drive is neatly alligned with the front side or your PC (not needed but looks n1cer !)
7.) Connect your IDE cable to your motherboard, suppose to be on the secondary ide channel. IDE cables usually have three bus connectors on them. The ones that are very close to each other must come to the drives, the other one that is "alone" goes into your board. Standard cables can only go in one way. Other ide cables state which one goes to the "HOST" (Motherboard) or the "DRIVES" your Hard drive or CD-ROM DVD.
8) Connect the other side of the IDE cable to your Drive.
9) Connect your power plug to it (The little white one with the red, black and yellow wires attached to it. You should have a couple of free ones from your power supply.
10) Confirm that everyithing sits tightly and all cables are connected corretly
11) Close your PC casing again.
12) Plug back your power into the machine.
13) Start up and enjoy the pleasure of having a new drive :)
Posted on Apr 16, 2008
I already wrote disc but how to overwrite a disc
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file?
Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file
You can add more data if there is space on the DVD+R, but you can't overwrite it.
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
You cannot overwrite this data.
It's kind of like trying to use a permanent marker on the same spot of paper twice.
CD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM.
650 megabytes (MB)
Highly compatible with most computers and devices.
CD-R
You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
650 MB and 700 MB
You must close the session to read this disc in a different computer. Highly compatible with most computers and devices.
CD-RW
You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times.
650 MB
Compatible with many computers and devices.
DVD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM.
4.7 gigabytes (GB)
DVD-R
You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
DVD+R
You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
You must close the session to read this disc in a different computer. Compatible with many computers and devices.
DVD-RW
You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times.
4.7 GB
You don't need to close the session to read this disc in another computer. Compatible with many computers and devices.
DVD+RW
You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times.
4.7 GB
DVD-RAM
You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times.
2.6 GB
4.7 GB
5.2 GB
9.4 GB
DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices.
hope this helps
Aug 28, 2012 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
I have dvd /rw model of LG : gh22np21driver but i lost cd-driver and i cant re add this hardware
if it is internal cd drive it actualy auto detect on the computer, you can see it on my computer all you need to install is the software for burning
Aug 04, 2011 | LG GH22NP21 DVD-Writer - Internal...
I want to install HP deskjet 3940 in my computer
Do the below steps.
1.Connect Printer cable(usb cable)to Computer&Swicth ON the printer.Printer driver cd also put in your cd/vd drive.
2.Start-device&Printers-Add Printer-Add a Local Printer-Select Port as USB001-Next-Have disk-Select yor Cd/dvd drive(Put Printer driver cd in your Cd/dvd drive)-next-next-Finish.
Jun 11, 2011 | HP DeskJet 3940 InkJet Photo Printer
Restarting Trouble
It is doing this as it is trying to install a Virtual CD/DVD, sometimes it mucks up. Boot into safe mode and uninstall from add/remove programs. Try another install in still no good, uninstall from add/remove programs again & try another burner.
Feb 08, 2010 | Computers & Internet
How do you transfer photos from computer to blank CD/DVD's ? Need to make more space on computer Hard Drive ? How many or much can 1 CD/DVD store ? Need to Know. Thanx. M.K. Bey
1 cd can hold 700mb of photos.
1 dvd. 4700 mb of photos.
depending on camera and the resolution of the pictures you are looking at about 350 pictures for a cd and 2500 for a dvd.
Scott
Sep 19, 2009 | Dell Inspiron Desktop with AMD Athlon 64...
My LG dvd writer not work properly only read dvd
just uninstalled it!!!!!!!!!!!!!!!!!!!!
go to my computer right click, properties
click device manager
double click the CD/DVD ROM driver
right click cd / dvd hardware, unis-stall
restart system
go to control panel
click add hardware and their is the instruction follow that!!!!!!!!
ok
Jul 04, 2009 | LG GSA-2166D DVD RW Dual Layer Burner
Acer Aspire 3000 CD-RW/DVD not working
in add new hardware
you should be able to add your cd drive
does the drive show in my computer if so you can check the settings there
May 01, 2009 | Computers & Internet
Dvd disk drive not showing in my computer
Hi!
The chances are that the drivers for them got corrupted and you can install them fron your motherboard cd. To install them go to Control panel-> add new hardware-> search for new hardware-> if it shows up then its good else add them from the list. It will then install the drivers from your motherboard cd (the cd you got with your system or from the cd you got with your disk drive).
If this doesn't help then check for the connectors(going into disk drive from power supply and motherboard) by opening your pc.
Please rate the solution.
Thanks
Rylee
Feb 08, 2009 | Samsung SH-S182 DVD±RW Dual Layer Burner
DVD DRIVE/CD-WRITER
GO TO CONTROL PANNEL
SYSTEMS
HARDWARE
DEVICE MANAGER
CLICK DEVICE MANAGER(WINDOW)
EXPAND CD /DVD ROM DRIVES
RIGHT CLICK ON SELECTED DVD/CD DRIVE
SELECT PROPERTIES
1.SELCT DRIVER ( CLICK UPDATE DRIVER)
2.CHECK DVD REGION CODE.
3.UN-INSTALL DRIVER
4. REINSTALL DRIVER AGAIN(AFTER STEP 3)
OR
IN DEVICE MANAGER RIGHT CLIVK DVDCD ROM DRIVE
UN-INSTALL DRIVER
OK
REBOOT COMPUTER
ADD HARDWARE(CONTROL PANNEL)
IT WILL PROPMPT FOR INSTALLATION OF DRIVER
SAY OK.
PROCEED WITH WINDOW INSTRUCTIONS
DVD/CD ROM DRIVER WILL GET INSTALLED AFRESH.
HOPE IT WORKS.
Jul 01, 2008 | Computers & Internet
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
