Question about ASUS M2N-MX Motherboard
BIOS 1004 cpu not support
I flashed the bios with the latest bios v1004 from the dl section of the asus site but during post the error "cpu not support comes up" and cannot flash to a lower version as the current bios prevents this.i reflashed with the same version to no avail...is it possible this bios is not intended for this motherbord  as the file name is M2NX1004.zip
cpu: amd athlon x2 6000+
  • 2 more comments
  • de_assassin Apr 17, 2008
    its just the plain M2N-MX. thats why i find it strange i'm having this problem.
  • de_assassin Apr 19, 2008
    according to the asus site my cpu is only supported from v806 up.
    i was on 406 or 411.i'm currently stuck on v1004.
  • de_assassin Apr 20, 2008
    how would i go about killing it?
  • Anonymous Jul 16, 2008
    having same problem i installed 6gig cpu i had old version bios computer booted but said needed driver for cpu. so i put latest bios 1004 now says cpu not support shutdown in 15 sec.only thing is board supports 89w and new 6g x2 is 125w i wonder if thats the issue
I got it :-)
Damn Asus , it was a hard session ;-)
1. Make an ISO from your original Asus CD denn insert (with isobuster or something) the Bios Firmware 1004 in the main Dir name the file M2N-MX.ROM
2.Burn a Second disc with the 0804 Bios ROM also rename the 0804 Rom to M2N-MX.ROM
3. Go to EZ FLASH with ALT + F2 and then insert the 1004 CD wait till Erasing is ready Then Turn OFF your PC :-) so you crashed the bios thats what you need to run the embeded CrashFRee Tool
4 After you turn your PC on insert the 0804 CD then it flashes the this Rom and we are Happy :-)
mfg Eddi Hope this helps someone
Posted on Oct 16, 2008
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
1. How to flash original bios from motherboard cd
put original drivers cd into, restart hold "Alt Gr" and "F2"
to start EZ-flash utility on board then it will load auto the cd
and will instal original bios rom from motherboard driver cd named M2N-MX.ROM
2. Downgrade, upgrade bios install Asus Update utility for win7
( for xp instal xp version from motherboard cd) stick to options downgrade, or not if upgrade and flow the installation work for downgrade !!!
3. Upgrade AFUDOS Upgrade only, sing AFUDOS, use rw cd/dvd using nero burning rom utility create boot cd or dvd and drag fowder bios containing files AFUDOS and M2N number.ROM then burn the cd. Restart and boot from cd starting msdos comand: (F:\ ) pres enter, (cd bios) enter, (dir) enter to see the files, to flash (afudos /iM2Nnumber.ROM) for more info see youtube videos
4. How to downgrade from protected from last bios M2NMX1004 is protected from downgrade, you already have installed the protected rom, burn boot cd or dvd from part 3 on my exponential with the same rom and reinstall the same rom but when you see erase and rewrite start cut the power from cable or back power button then you will corrupt the bios and using original board driver cd into start and press Alt GR and F2 to start EZ-flash utility on board, then it will load auto the cd and will install original bios rom from motherboard driver cd named M2N-MX.ROM
5.After that use new Asus Update utility for win7 from softpedia.com is compitable witw win7 to downgrade, upgrade bios my DualCore AMD Athlon 64 X2, 2900 MHz 5600+ work ferfec with version bios M2N-MX0302, all other version have usb problem with linux storage no usb 2.0 detected cannot transfer faster !
Bay the way part me for my bad english i decide to post my experience to help to other, like other post help me many times ...
Than You and good look!
Update utility
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
bios roms M2N-MX
http://www.asus.com/Motherboards/M2NMX/HelpDesk_Download/
Posted on Aug 14, 2014
I am having the same problem. I have a AMD 6 gig and flashed my bios to ver 1004. I can not get to a post to select boot from CD and get the CMOS checksum bad for CPU supported. Unable to get to a F12 to select boot option to try and use the flash utility? Any Ideas?
Posted on Nov 08, 2008
Guest:de_assassin. login info was on the other pc
Posted on Apr 22, 2008
Thanks for the help..decided it was easyer just to get a new bord. needed to upgrade anyway :D. got the gigabyte ga-m57sli-s4
    Genius:
  • 1,027 Answers
If your board is the plain jane M2N-MX it is the correct one, however if you have the MX SE or SE Plus then the bios is incorrect and as 1004 prevents going back to a different bios version your chances of flashing back is at 50-50.
Posted on Apr 16, 2008
  • Mark Williams
    Mark Williams Apr 18, 2008
    I've had this happen once to me on an asus board. They require the flash utility before the flash .bin is installed Then after the flash I had to put in the new cpu. Check the bios versions and see what processors are supported.
  • Mark Williams
    Mark Williams Apr 19, 2008
    Asus link
    bios 1004 supports Athlon X2 4850e
    because the bios prevents downgrading I would suggest either get this processor or try to kill the bios.
    you better have the bios flash utility and Bios 804 before attempting.
CPU overvoltage error"
Hi
Did n't you just post in hardware about flashing the BIOS?
Did you enter the BIOS & check the cpu voltage setting to make sure it's correct?
Actually, after the flash you probably should have used the ClearCMOS jumper to reset the BIOS,
then ran thru ALL the settings & manually adjust them for best performance.
Jan 03, 2011 | ASUS P5PE-VM Motherboard
My unit was replaced by asus mother board P5PE-vm and there is an error message, intel cpu uCode loading error. how do i get rid of this error? it is pissed seeing this error
If you don't ask Asus will not do it for you.
You can either call Asus and ask for an updated bios, (they charge about $6.00 not including shipping) or you can update the bios you're self. Everything you need to flash the bios is on their web site;
http://www.asus.com/product.aspx?P_ID=k3h0ZFVu9Lo1dUvk&content=download
The last three bios updates are for support new CPUs.
Cheers'
Mike
Jan 27, 2010 | ASUS P5PE-VM Motherboard
Problem with my Asus p5pe-vm motherbord.When i start it,the message CPU uCode loading error appears.What to do...HELPPPPPPP
If your over clocking your CPU settings reset to default. See if you still get the error. If you still get the error than update your bios. There are a couple of way to do this. You can use the software on your Asus CD or you can down load the latest BIOS-Utilities, Afudos BIOS update tool V2.36. Than download the bios file, P5PE-VM BIOS 1501.
Using built-in EZ Flash to flash BIOS Please be informed that not all motherboards support EZ Flash,
please use DOS flash utility to update BIOS if your motherboard does not support EZ Flash; http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=960&SLanguage=en-us
Happy holidays!
Mike
Dec 19, 2009 | ASUS P5PE-VM Motherboard
BIOS WON'T START OR LOAD, ANYONE CAN HELP ME? Mainboard: P5S-MX SE Having troubled my CPU, it works for 2 years but now this is what happened. It won't start. First, i detached all the hardware attached...
Remove The CMOS Battery, For 10-15 seconds to reset The Bios to it,s default settings.
Try the memory Module/Ram in a different Slot.
Re-seat the CPU.
Mike @ Compurepair.
Oct 16, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Same problem
You need to flash the bios to a newer version for this cpu to be supported by your motherboard. Your descriprtion says asus so go to www.asus.com; click on the support link; lookup your specific board model #; select the operating system you are running. Download the latest bios file and follow the directions on the download site for proper flashing. Once you have flashed the bios everything should identify properly and allow you to continue setup. Hope this helps.
Jul 19, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
ASUS P5KPL-CM Bios Problem with Core2Duo 2.8 Ghz Processor.
I recommend going to this site and getting the latest Bios for the board.
http://support.asus.com/download/download.aspx?SLanguage=en-us
I don't know your expertise with computers but it will require you downloading their Bios boot disk utility and creating a boot disk. then copy the Bios file to the same disk. When you boot it up it will guide you through the Bios flash process.
Be aware that you can completely kill the Bios if it has a problem during the flashing so only do it if you are positive you can get through it.
Alternately if you can push the F1 and get into the OS the Motherboard utility disk should have an updater you can use from inside windows.
May 04, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
File P4P800SE.ROM not found
Sounds like you're trying to flash the bios..
Using ASUS EZ Flash to update the BIOS: The ASUS EZ Flash feature allows you to easily update the BIOS without having to go through the long process of booting from a diskette and using a DOS-based utility. The EZ Flash is built-in the BIOS firmware so it is accessible by simply pressing <Alt + F2> during the Power-On Self Tests (POST). To update the BIOS using ASUS EZ Flash: 1. Visit the ASUS website (www.asus.com) to download the latest BIOS file for your motherboard and rename the downloaded file as P4P800SE.ROM. Save the BIOS file to a floppy disk. 2. Reboot the system. 3. To launch EZ Flash, press <Alt+F2> during POST
Hope this helps
Chris (ziraffa)
Dec 31, 2008 | ASUS P4P800SE Motherboard
CPU not support found !!
you need to change settings in your bios for the type of cpu you changed to
Or reset your bios to default it could still be set up for old cpu
Aug 02, 2008 | ASUS M2N-MX Motherboard
Intel upu ucode loading error
While starting computer a msg appear " intel upu ucode loading error" after pushing F1 computer get start my computer having ASUS mother board P5BMX/WIFI-AP and intel core2duo procesor Please help
May 19, 2008 | Computers & Internet
Asus bios problem
I sounds to me like u flashed the BIOS the wrong way with the wrong update. Try to go back to the old version 0609 ? and have www.drivers.com scan your cpu to find the right BIOS for you.
Apr 22, 2008 | Intel Motherboard
ASUS M2N-MX Motherboard Logo
809 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
