Question about Sewing Machines
Bobbin casing for elna 8000
I have elna 8000. i had thread wrap around the bobbin and pop out the bobbin casing. I took it apart, but can't put it back together.... when i opened it up there was a little metal piece, looks like a prong with a straight piece attached. not sure where that goes. any ideas? Thanks
  • Peter Bradshaw May 11, 2010
    How big is this "prong"
    Problem Solver:
  • 5 Answers
There is one small metal piece 3/4 inch long and shaped like the letter "T" that fits under the right hand needle plate snap one screw. Attach to underneath square nut and can be seen sticking out from the top holding the bobbincase in place after the top plate is replaced and everything is back together. If this is not it, a picture would help as I have repair 100's of Elna 5000 to 9000's.
SewTech
Posted on Apr 21, 2008
  •  Catherine McMoran
    Catherine McMoran Jun 06, 2012
    a picture would help the book has a red arrow in the way so can't see where it goes
Should there be thread like packing that goes around the bobbin shaft[ the metal bar that goes under the bed of the machine ] ? Elna 7100
The only thread that should be under the bed of the machine should be on the bobbin itself and the thread tail that extends beyond the bobbin. If thread is wrapped somewhere else, that needs to be eliminated and the machine cleaned of all debris.
Jul 05, 2017 | Elna Sewing Machines
In my old but good elna sewing machine thread got stuck in bobbin case and it is jammed
then you need to get the bobbin case out and clear all thread . if you can not get it then you need to take to a repair shop
Nov 02, 2015 | Elna 2005 Mechanical Sewing Machine
Why is the top thread wrapping around the bobbin and causing a huge
Take the full, spool and casing apart there will be threads caught up that you can,t see, once you put it back check tension for stitching before starting again
Mar 06, 2015 | Sewing Machines
My elna 2800 is jamming the bobbin the thread keeps wrapping around the bobbin case. What can I do
try changing the needle, make sure the machine is threaded correctly,using every thread guide. make sure the top thread hasn't come off the thread take up lever, try a different bobbin, could also be a timing problem
Dec 03, 2014 | Elna Sewing Machines
I have an Elna 6005 that has started skipping stitches and the bobbin raises up and hits the plate, What can I do to fix.
Check two things:
1. Look at the bobbin and see if the thread is wrapped around it like it should be or if it looks jumbled, criss crossed or snagged in some place. Best thing to do is try a different bobbin and see if it sews correctly.
2. Check the needle and make sure it isn't bent or in wrong. Try a different needle.
If i'm understanding what you mean by raising up and hitting the plate it sounds like the bobbin thread is caught somewhere or the bobbin case is not inserted correctly. Take it out and put it back in again and feel for it to go into the right place and listen for a slight "click" as it goes in.
Apr 23, 2011 | Elna Heirloom Edition 6005
Thread getting caught underneath
you need to replace your shukle that holds the tread bobbing below.it is either slack or broken . if it is slack then you tighten the little screw that holds a cover that gives the thread tension .if its broken then replace it.once the thread is slack below it will cause your thread to bundle up.
Mar 10, 2007 | Euro-Pro Shark 80 - 7133
Sewing Machines Logo
286 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
