I was flooded last year and am now trying to put my PC together.....some wires/cables and all instructions were lost. I have main cable from pc to monitor, keyboard, speakers and mouse. As well as the cable from pc to monitor what others do I need please. Its an emachines 220 and it seems ok but the monitor is dead.
    Scholar:
  • 55 Answers
Make sure that your monitor is plugged into mains and that it is switched on. If the monitor is on you can see a "orange" light bottom left on the screen. If it comes on with a "No signal" on your screen, then you know that the screen is working. If the light is green, you know that your PC and monitor are "communicating".
You can also check if the cable from the screen (blue connector 15pin male) is connected to the correct VGA port at the back of your pc. Sometimes pc have 2 or 3 VGA ports meaning they have an onboard VGA, and a additional installed graphics card.
If you suspect the mon to be dead, then try the monitor on a different machine. In this way you can distinguish if the monitor is dead or your PC.
Posted on Apr 16, 2008
Orange light on and it wont turn on
I found this online. Many people have said this worked for them but you need to make sure you follow the instructions carefully.
Step By Step:
(Disconnect all cables, Inc the power)
1. Open the case of your Dell Pc
2. On the power supply box (top right) find the GREEN wire
(The green wire will almost always be the power switch on all Pc's)
3. Cut it at around the middle
4. Strip Both Ends
5.Find a long enough piece of wire that will reach to the front of the pc
6. Solder the GREEN wires back together but putting your seperate peice of wire inbetween them
7. Tidy them up with zip ties and shrink tubing (Electrical Tape if not)
8. Plug the power cable into the pc
9. Hold the wire onto the chassis of the pc
10. If the fans start at full speed, press the power button and let the wire off
11. your pc should be running as normal.
Mar 02, 2014 | Dell Latitude E5500 Laptop
I have a 1998 eclipse spyder. The other day my boyfriend put a battery in the car that was higher then the one that was in it and it hit metal and shorted out the car while i was driving it. It melted the...
Wow, The throttle cable will be the next ground the system would
find if it lost the main ground. It would be too small to carry the
load and melt the plastic to the cable. Have to change that part.
Make sure the ground from the battery is good to the engine,
AND the body.If the engine doesn't have a good ground to the battery the throttle cable will take the load if the body ground is good. There should be a smaller ground that runs to
the body somewhere,doesn't matter where,
Also if the throttle is stuck wide open there will be no fuel allowed
to the motor. Made that way so if it gets flooded, wide open is a
"clear flood "mode
Feb 09, 2013 | 1998 Mitsubishi Eclipse
I would like to conect my laptop to my LCD TV,I did it before but now I can not do it,I have 14 pins VGA cable conected direct to the TV -PC outlet. TV is seted on PC input. Please help me.
Press FN button together with the function button on your keyboard that has the image of 2 monitors. try pressing these button together and see if you can come up with a selection on your screen. There are 3 options under this function. It will be the main monitor option, Extending monitor 1 to monitor 2 option and lastly disabling monitor 1 while using monitor 2 option.
Should you have any other questions just please leave a message.
Cheers~
Musicaddict
Sep 11, 2010 | Computers & Internet
I need detailed instructions on what cables go where on my new power supply for my Gatewat 700GR desktop PC
I found this detailed instide view on Gateway's support website. I must say that this instructional support site is extremely well put together. Hope this helps. Best Regards, -md
http://support.gateway.com/s/PC/R/3726/3726iv.Gatewat 700GRshtml
Nov 09, 2009 | Gateway 700GR PC Desktop
Last week I put a 4-hub on my desktop and laptop. one wire from wall to main hub, one ethernet cable from hub to laptop, one ethernet cable from hub to rear ethernet port on desktop. The internet on the...
check if we are getting good ip address 192.xxxxxxxxxxxxxxxxxx
not the 169.xxxxxxxxxxxxxx
relese renew if 169.xxxxxxxx is the case
if no reply.. try using another cable and check the connections
Sep 20, 2009 | Dell Latitude D600 Notebook
Sony lbt v702 hifi system stack
i have a sony stack system i had put away for a couple of years, i have now put it back together, but when i wire both speakers up, the sound go s to a point then cuts out, whith a mesage on the front saying protect, it i take one speaker off! nothing happens, can any one help please?
thak you for your time.
Steve.
Sep 22, 2008 | Audio Players & Recorders
EPSON PHOTO PC 500 DIGITAL CAMERA
Serial meaning 2.5mm stereo headphone looking jack to DB9 or "atari joystick" looking plug? I had one on my first Toshiba PDR-M1 camera but that was like 9 years ago. You can probably find the pinouts online for that cable, I believe it is a standardized cable.
The stereo plug is wired to the PC serial port as shown in the following diagram:
tip ring sleeve +---------------------------------+
| RxD | Gnd | TxD | 2.5 mm Stero Plug |
DB9*: pin 2 pin 5 pin 3 +---------------------------------+
DB9*: Optionally short together pin 4 (DTR) to pin 6 (DSR) and
pin 7 (RTS) to pin 8 (CTS)
The following table also describes the camera cable's wiring: Camera PC's
Plug DB9* Signal Name Direction
- 1 Carrier detect (CD) input to PC
tip 2 Receive data (RxD) input to PC
sleeve 3 Transmit data (TxD) output from PC
- 4 \ Data terminal ready (DTR) output from PC
ring 5 | Signal ground (Gnd) -
- 6 / Data set ready (DSR) input to PC
- 7 \ Request to send (RTS) output from PC
- 8 / Clear to send (CTS) input to PC
- 9 Ring indicator (RI) input to PC
* Note that the cable's D-subminature DB9 RS-232 serial port connector is female. This connector also goes by the historically more correct name of "DE-9J".
Feb 22, 2008 | Epson PhotoPC 500 Digital Camera
Wi-fi cables
White is main and black is aux
Dec 27, 2007 | Toshiba Satellite P35-S611 Notebook
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
