Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Need help with color on panasonic hdtv
The only thing wrong on my tv is that there is a red glare to it.OK,you watching tv you see the picture and it has double picture and its red
    Genius:
  • 1,694 Answers
Convergence circuit repair needed.....Requires chassis pull,
IC replacement and check / replace current limiting resistors.
T.
Posted on Apr 17, 2008
Color in tv is very green you cant tell what suppose to be what i was watching cartoons with kids and the animal that suppose to be red was black i tried adjusting color temp and every thing even resetting...
If your using a tuner for your TV channels and you are using component video cables make sure that the red cable is not plugged into the audio socket. red blue and green cables should all be plugged into the "component" input on the tv not audio.
Dec 27, 2010 | LG 42LC2D 42 in. LCD HDTV
I have a Panasonic Multimedia Projection HDTV when tv is turned on it has red & blue color spots & red verticle lines showing on the screen what could be causing this to be happening
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have shadows colors pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Need lg 32lh30 calibration specs
I think I have a solution involving far less effort. Have you tuned your picture settings? Out of the box, the settings are ok and the presets will do the trick for most. But if you're like myself, you want the best picture possible. Here are my settings:
Picture menu:
Aspect ratio: Just Size
Energy Saving: Off
Picture Mode: Expert 2
Backlight: 35
Contrast: 90
Brightness: 54
H Sharpness: 40
V Sharpness: 42
Color: 50
Tint: 0
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On [grayed out]
Color Standard: HD [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
OPC: Off
Expert Pattern: Off[grayed out]
Color Filter: Off
White balance: Warm
Method: 10 point IRE
Pattern: Outer
IRE: [see below]
Luminance: 137
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [-8, 1, -40]
90 [-13, -5, -40]
80 [-20, -12, -40]
70 [-17, -14, -33]
60 [-17, -12, -31]
50 [-17, -13, -26]
40 [-13, -12, -19]
30 [-6, -4, -8]
20 [-6, -4, -10]
10 [2, 3, -1]
Color management system
Red color: 2
Red tint: 0
Green color: -1
Green tint: -7
Blue color: 2
Blue tint: 7
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -2
These are taken from CNET.com
Nov 08, 2009 | LG 32LH30 32 in. LCD HDTV
PANASONIC 36" TAU --- NEED HELP
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
PSP 6 pin gen 2 cable not working on tv?
you have the wrong cable. the cable you have is for HDTV's only.
by the ports on the TV, you have a standard TV.
The cable's colors are Red, Blue, Green, Red, and White. If you have a HDTV or these ports on the back of the TV, connect them like in the picture.
from what you said, it seems like your TV's port colors are Yellow, Red and White. If you only have these ports on the back (Yellow, red, white), you need this cable:
Aug 30, 2008 | Sony PlayStation Portable (PSP) Console
Color looks horrible when playing dvds. when watching tv, the color is fine. help!
U have to use a hdmi cable ok or red green blue coumpount cable ok that way get a better picture thx for using fix ya .
Feb 05, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp 61R WP4h
side fade is down side of projection tv's
there is no harm other than you have to be careful now.
Dec 04, 2007 | Panasonic PT-47WX53 47" Rear Projection...
I have the JVC AV-48wp74
ok! you have defctive convergence correction circuit! thats why the color is abnormally function!
Oct 21, 2007 | JVC AV-48WP74 48" Rear Projection...
Red Shadow on scheen
your tv needs to be align take it to a tech so that the tv can get a convergence adjustment it is call color bleeding.these things when a set gets old this wil cost between 440.00 TO $75.00,in this the comb filter and the screen voltage will be checked.
Mar 29, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
