E7-00 tried to get the plate off as in picture but can get the wire harness for the fan out. cant figure out if the whole plastic piece comes out of the plate or if the wires snap into the plastic piece that stays within the plate... it tried everything up to cutting the wires... any ideas
  • 19,396 Answers
Take a photo and post it here, I will be back in several hours, do not cut or bend anything.
Posted on Apr 16, 2008
My Braun electric kettle won't click on. Do I need to replace the kettle or is there some way it can be fixed?
It's possible it can be fixed. Ours also no longer clicked. I took it apart and found that the flat plastic piece in the handle that activates the circuitry in the base had broken away from the rocker piece in the base. Fortunately the same flat plastic piece conveniently had a couple of holes in it in a helpful location. I looped some wire through the holes and also around the bottom rocker piece to hold the two pieces together.
I reassembled the kettle and tried it out and it now works fine! Problem fixed.
To disassemble, take the four screws out of the bottom of the kettle. (You'll need the appropriate star bits to do so.) Put those screws in a safe location... Lift off the bottom plate.
Now, the plastic for the handle is held in place by the typical notched clasps used by so many plastic appliances. You unsnap the clasps by CAREFULLY inserting a straight blade screw driver between the handle plastic and the kettle and GENTLY prying the handle plastic away from the kettle. You'll hear the internal clasps "popping" as they snap loose. You CANNOT take the handle all the way off this way. You just loosen it. Now, the top of the handle is a separate piece. Do the same for this. The top will pop completely off.
Next, GENTLY remove the lid. You can slide it a bit up and away. It's a tight fit, so you need to use a little force, but not too much.
Once you've done this, there are two metal pins that hold the main part of the handle to the kettle. They have a little ridge around the top that you can use to pry them out with your fingernail. Once those pins are removed, the handle will simply come off.
BE CAREFUL! The various parts in the handle are now loose! If you aren't careful they'll fall off and you'll have to figure out how to reassemble them.
Now, you'll notice the long flat plastic piece running down the side of the kettle. That piece was hidden behind the handle. It is SUPPOSED to be fastened to a rocker plate at the bottom. If you look at the end of the flat piece at the bottom you will likely see what I did. It had just disconnected from the rocker plate. Take some wire and wire the two pieces together using the little hole-like slots at the end of the flat piece. Just loop the wire through the hole and down around the rocker plate piece exposed inside where the handle is.
While applying this wire, it will be helpful to put a little masking tape across the various handle pieces to keep them from falling off. This is important because you'll probably be wiring the pieces together with the kettle on its side like I did, and the parts will fall off if you aren't careful. When you are done wiring things together you just remove the tape.
Once you've done this, reassemble the kettle in the reverse order you disassembled it.
You'll notice that once you've wired together the two separated pieces, pressing the switch on the top pulls up on the flat plastic piece which pulls the rocker plate which closes the circuit in the base.
Jan 16, 2011 | Braun WK200 Cordless Electric Kettle
How to install wiring harness
Step 1
The first thing that must be done is to strip the wires so that about a quarter of an inch is showing of the wire that comes out of your CD player's wires. Every single wire which is about 12 wires or so, must be stripped in order to proceed to the next step.
Step 2
After your wires are stripped. Take the new wire harness, the one I'm assuming you made sure is fit for your model of vehicle. You could buy these harnesses at BestBuy or your local car audio store. Take the harness and if you got a good quality harness it should be already stripped. If they're not already stripped, then strip them.
Step 3
Now here's the tricky part that's only tricky until you read this step.
Just match up the colors from your CD player's wires, to the wire harness's wires. That's right, it's as simple as that. Twist the wire from the CD player and the wire harness together about 4-7 times until the wire is secure.
Step 4
A crimp set includes little plastic bits that the 2 wires go into when twisted, then the wire put in the plastic bit and the plastic bit is then pushed down with force (crimped) to secure the wires from coming apart or touching other wires. A good note to remember is that if the blue wire from the CD player doesn't match a wire on the harness, then that is okay. Just crimp the blue wire by itself. The blue wire is used for aftermarket amplifiers to tell the amplifier to turn on when the radio is on.
Step 5
To avoid any incidents, unplug the negative (black) part of the battery on your car. Now plug the end piece of the wire harness (the plastic piece), into the car's radio input (car's plastic piece). If they 2 harnesses do not fit together than you have made a mistake and purchased the wrong harness
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 13, 2010 | Dell Dimension 4600 PC Desktop
How are the two top sections held together? I need to get at the wiring.
I have the Bissell Big Green model 1672 and have used it for many years. Recently, the fan or suction blower began to emit a burnt smell so I shut it off. I had difficulty figuring out how to dissemble the top motor unit. Here is what I found.
Don't pry up on the very top disk, which is an air outlet. It will only break off and won't allow access to anything. If you do break it off, drill holes through the four posts and use stainless steel screws to re-attach the disk to the plastic posts it sits on.
Now, beneath the air outlet is the rest of the motor unit. The motor unit consists of three pieces. The bottom piece is the lid to the waste water receptacle. It is concave pointing down (lid shaped). The top piece is the domed lid for the motor unit. The middle piece is a flat plate between the other two pieces. The top of the flat plate (inside the unit) has mountings for the suction fan and the pump.
The flat plate is bolted to the bottom piece and the top piece (domed lid) is simply snapped down to the flat plate. If you take a flashlight and look inside the area where the AC cord is stored, you can see that the domed lid is a distinct piece from the flat plate. The model 1672 and 1680 (or 1680-3 if you wish) are nearly identilcal.
To access the internal parts in the motor unit, you cannot pry between bottom piece and the the flat plate because they are bolted together. But you can remove the top domed lid. To remove the domed lid, position the motor unit in front of you with the switches at 9 o-clock. Three snap-downs which attach the domed lid to the flat plate are at 1 o'clock, 2:30, and 7 o'clock. Wedge a flat bladed screwdriver or pocketknife between the edge of the domed lid and the flat plate at those locations and the lever the domed lid out and then up. The domed lid will separate from the bolted-together flat plate and bottom piece.
Wiring from the switches remain attached to to the electrical components. You will see that the AC cord has white, black, and green wires. The green ground wire connects to the fan ground at the 9 o'clock position. The white power connects to upper connector on the pump and also to the fan at the 7:30 position. Black feeds both switches on model 1672 and then a black wire runs from the correct switch to the bottom connector on the pump or to the connector on the fan at the 1:30 position.
Model 1680 has a third switch which feeds power to the floor sweeper. It has its own connection to the green ground and white power and goes through the third switch to connect to black.
If you need to replace the pump or the fan, shop around carefully. The pump, for example, can be found for $30 plus shipping, but some will want to charge you $80.
Nov 30, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Broke the flimsy support plastic ring - Need to order new one
i would do a tack together job on it,,
get some thick fuse wire and tiy it round inside the grill holes on the out side edge tiy each one together at about every inch apart around the grill that will hold the two grill's tight, then if you still have the broken plastic bits glue them back on using supper glue its cheeper that trying to get part that you may never find?
Oct 27, 2009 | Minka Aire F602-BNCH Gyro? Fan
How do i get the metal piece off the review mirrow-96 caprice the thing fell off i cant figure how the metal comes out and it doesnt have a place where you can use a allen wrench
I'm guessing that you mean the mounting plate that attaches to the windshield. The plastic cover over that piece of the mirror comes off. It slides off toward the ceiling end of the mirror. With that off, you will see a small slot on the bottom of the mirror and mounting bracket. Slide a small screwdriver, like a sewing machine screwdriver into that slot. There is a clip in there that needs to be pressed and the plate will come off. The clip should press toward the windshield.
Jun 12, 2009 | 1998 GMC Jimmy
Code 1481
SOMETIMES THE WIRING HARNESS GET DAMAGED WHEN FAN REMOVED. GM HAS BULLETIN TO REPLACE COOLING FAN WIRING HARNESS PART# 89024920
Harness Assembly, Engine Cooling Fan Wiring
  1. Place the cooling fan assembly on a bench.
  2. Disconnect the harness electrical connector from the cooling fan clutch.
  3. Remove the harness from the plastic guide while feeding the wires out of the slot.
  4. Before installing the new harness, wrap the affected area on the wires with electrical tape to keep the protective sleeve in place. Be sure to keep the tape approximately 25 mm (1 in) away from the connector so the wires can be fed into the slot.
  5. Feed the wires into the slot and install the harness to the plastic guide.
  6. Connect the harness electrical connector to the cooling fan clutch.
  7. Install the cooling fan. Refer to the Cooling Fan and Shroud Replacement procedure in the Engine Cooling sub-section of SI.
Nov 25, 2008 | 2003 Chevrolet TrailBlazer
Break lights
on my buick lesabre you have two star screws right on top of the tail light plate then you take them out you can pull out the whole case and you have all 4 bulbs exposed just turn the case and the socket come out and change bulbs
I hope it helps
Nov 13, 2008 | 1989 Buick LeSabre
29 people viewed this question
jasbo
jasbo
