Question about Cameras
I am interested in buying Nikon's new digital D60 camera what i need to know is if I can use all the Nikon lenses I have that fit my 35mm camers
  • 423 Answers
The D60 works best with their new "DX" series lenses. Other Nikon mount lenses will fit on the camera, however you will lose many of the functions, primarily auto focus. You need to weigh the pros & cons of using your existing lenses without full functions, vs. maybe looking at the D80 model or a gently used D50, D70 or D70s, all of which will work better with earlier generation lenses.
Posted on Apr 16, 2008
I have a 35mm film Nikon camera with Quantaray NF AF Lenses. I'd like to find an affordable digital camera that I can still use these lenses, any suggestions ?
Those lenses will fit on every Nikon digital SLR. However, the autofocus will only work on cameras with an autofocus motor, the the AF will not work on the D40, D40x, D60, D3000, D3100, D5000, and D5100. Note that this is just the focusing: if you're willing to focus manually then those lenses will work perfectly well on those cameras.
Due to the smaller image sensor of most digital cameras, the lenses will act as if they were about 1.5 times longer. Thus a 50mm lens on a digital camera will give about the same field of view as a 75mm lens would on a film camera. This applies to all Nikon dSLRs except for the D3 family and the D700, which behave in this respect like a 35mm film camera.
You have to decide what's affordable for you, balancing such factors as weight, ease-of-use, and of course cost.
You can see the current Nikon lineup at
Jul 20, 2011 | Quantaray 28-200MM F3.8-5.6 Lens for Canon...
I want to go digital will my lens fit on a digital camera if yes what model camera should i get
Any of your lenses will fit on any Nikon digital SLR camera. However, there are several things to consider.
Most Nikon digital SLRs have a sensor smaller than a frame of 35mm film. This means that your lenses will give the same angle of view as a lens with a focal length 1.5 times longer. For example, your 50mm lens will give the same angle of view as a 75mm lens would. This applies to all Nikon dSLRs except the D700 and D3 series.
If the lens does not have the electronics to communicate with the camera, some dSLRs will not be able to meter with them. Of the current models, the D7000, D300s, D700, and D3 series will work.
Most old autofocus lenses will not autofocus on some dSLRs. Unless the lens is designated "AF-S" they will not autofocus on the D3000, D3100, and the older D40, D40x, and D60.
Feb 09, 2011 | Nikon N55 35mm SLR Camera
I'm looking to buy a Nikon F65 35mm film AF SLR Camera and I was unsure if you can use the lens from a Digital SLR?
Yes, as long as it's not a DX lens. DX lenses are designed for the smaller image area of some digital cameras and will cause vignetting (dark corners) on a 35mm camera. The vibration reduction feature of VR lenses won't work, but won't cause any problems.
DX lenses will fit and work, but as mentioned above, you will get dark corners.
Nov 15, 2010 | Nikon F65 35mm SLR Camera
Buying an SLR digital camera
Hard to tell, but I'd give a slight advantage to the Canon 1000D over the Nikon D60 (closest competitor) for 2 main reasons. The Canon has liveview which the D60 lacks and the Canon is largely backwards compatible with older Canon and third party lenses - so you can get good quality older lenses which will work perfectly with the 1000D. With Nikon on the other hand you need to either buy lenses with internal autofocus motors or you'll be stuck with only manual focus.
Besides that there's not really much difference, since both cameras produce great images and are very similar in features handling and price etc. To sum it all up - I suggest you go with the Canon.
Hope that helps with your decision.
Jul 25, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
My Nikon D60 fell and the lens came off. Now the lens no longer holds -- it appears that a piece of plastic has chipped which prevents the lens to click close. Where do you recommend I get it fixed. I...
If you are no longer covered by an in-store warranty, whether an extended service or recent sale (typically 30 days) type, going back to Best Buy probably will not help (but asking about it can't hurt).
Nikon Customer Support may be the best place to get the camera repaired, but you'll have to determine if the cost is worth it. If you decide to buy new, be aware that not all Nikon lenses work with all Nikon cameras. Otherwise, if you buy a new Nikon, you'll be able to reuse many of the accessories you currently own for the D60. This can save you a fair amount of money - but make sure your lenses and other accessories will work with the new Nikon model you're planning on buying *first*
Contact Nikon Service for more help with your D60 below:
I hope this helps!
Oct 30, 2009 | Nikon D60 Digital Camera with 18-55mm lens
My Nikon D60 wont auto focus on any of my lenses. Could it be a problem with the body?
The d60 needs Auto focus lenses(Ones with motors inside the lense) it doesn`t autofocus on other lenses. this was done to reduce the price of the camera body
Hope this helps
Aug 04, 2009 | Nikon D60 Digital Camera with 18-55mm lens
I have 2 quantaray lenses which I brought with my 35mm SRL are these lenses compatiable with Digital SRL cameras???
Which type of lens mount, what digital camera.
Nikons will fit older Nikon lenses.
Canon it seems only fits AF lenses
Olympus digital only takes their own new mounts.
Minolta lenses will fit the new Sony/Minolta digitals.
Pentax digital will take any K-mount or older thread mount. Need to change some menu setting though. Need a K to 42mm for the thread mounts.
Mounts are all different, so a Canon won't fit a Nikon, Sony or Pentax and vise versa.
Jul 04, 2009 | Cameras
Nikon Lenses
They will fit but will work only in manual mode
Jun 14, 2009 | Nikon 50-300mm f/4.5 Manual Focus Lens...
Promaster Spectrum 7 Lens
I believe Promaster does not have any lenses with focus motor in the lens, so it will not autofocus with your D60. Their AF versions for Nikon will work with your camera's metering system for proper exposure, but you would have to focus manually.
Dec 30, 2008 | Nikon D60 Digital Camera with 18-55mm lens
Quantaray 100-300mm Lens for Nikon
Yes the new nikon D60 needs lens with a built in a/f motor. Your lens will go on and work but you will
have to manual foucs
Sep 30, 2008 | Quantaray Zoom 100-300mm f/4.5-6.7 for...
Cameras Logo
120 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
