Question about Vacuums
I have a Eureka "The Boss" vacuum that doesnt seem to be sucking up as much as it should and did in the past when vacuuming on carpet and hard floor surfaces.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
I have a Eureka "The Boss" vacuum that doesn’t seem to be sucking up as much as it should and did in the past when vacuuming on carpet and hard floor surfaces.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This could be because the vacuum has a clog or blockage, it may need a belt change every 4 to 6 months as recommended by the factory, sometimes the material you pickup on the carpet and bare floors will plug the pores of the inside if the paper bag or dirt cup filter, if the filter is clogged it looses the suction power or the bottom plate is not on properly or all of the above. These are some of the items to check when you lose suction.
http://www.eureka.com Customer Service Phone Number
1-800-282-2886 Hours of Operation
Monday thru Friday 8:00 am to 7:30 pm CST
Saturday and Sunday 10:00 am to 6:30 pm CST
Posted on Apr 16, 2008
I have a eureka 4D boss vacuum that won't go into barefloor mode and has no suction in carpet mode
turn the beater head over and see if something is stuck ours was totally plugged with stuff till I cleaned it last week for wife .
Dec 24, 2015 | Eureka Vacuums
Eureka boss sucked up water and won't work
The water probably got into the motor causing it to "burn" out. The motor will need to be replaced, but by the time you include labor cost it may be cheaper just to replace the vacuum.
Dec 24, 2013 | Electrolux Eureka Boss SmartVac Vacuum...
No suck at head hose has suck how do i get to belt, is there a free manual?
You should be able to easily locate the belt from the underside. Make sure your brushes are not clogged with animal/human hair, fibers/threads,etc. Try eureka.com to request paperwork.
Sep 23, 2013 | Eureka 5849A Boss Bagless Upright Cyclonic...
I replaced the belt in our Eureka Boss Smart Vac, it still seems loose, it uses a type R belt. The beater belt still doesn't seem to turn properly and seems that it doesn't pick up very well when I use it...
Check to see that the beater brush is not frozen up. Pull the brush and clean it, spraying some WD40 on each end piece that holds the brush in place. Also be sure the belt is properly installed so that the brush turns in the correct direction. If the brush is not turning or not turning in the correct direction, it will not beat the dirt from the carpet so that it can be picked up by the vacuum's suction.
Oct 01, 2010 | Eureka Vacuums
Bag model for Eureka Mega Boss 4460 type E
The model 4460 is for a Victory model which uses Eureka Type AA bags
They can be found at http://www.totalvac.com/eureka_aa_bags.html
Jun 10, 2010 | Eureka Mega Boss 4460DT Vacuum
I have a Eureka 'The Boss Smart Vac'. The beater
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Eureka The Boss Smart Replacement Belts
Owner's Guide (3,666K download)
Dec 09, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
The vacuum is blowing out a lot of air, doesn't ****
make sure the dirt cup is empty and the filter cleaned .. once the filter is clogged it wont work ...make sure everything is assembled correctly to seal the cup ... this nice little vacuum should work good except on deep carpet ..
Sep 28, 2009 | Eureka Boss SuperLite Bagless Upright...
Eureka vacuum cleaner
That means that the belt2_bing.gif is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet and therefore doesn't pick up well. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Aug 29, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka 2812 shop boss wet/dry..water is being sprayed out of the
je ne trouve pas un magasin ou je puisse acheter des filtre a poussiere
Jun 20, 2009 | Eureka 2812 Wet/Dry Vacuum
The brush does not spin when making contact with carpeting
I tried the electrical-tape-around-the-wooden-spindle technique. After a minute or so, it's back to functioning normally.
Mar 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Vacuums Logo
253 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
