Question about Sony Playstation 3 (PS3) Console
PS3 Won't Play Blu-Ray
I just bought a new 40gb PS3 and it will not play blu-ray movies out of the box. When I insert a movie, it loads for a few seconds, then cuts off and my TV says "no signal", as if nothing was connected. When I eject the disc, the regular PS3 screen returns. Regular DVD's and CD's will play with no problem. I tried a few blu-ray movies and even the disc included in the PS3 box with no luck. I downloaded the newest updates online and tried just about everything I could think of. Any possible solutions for this?
Thank you
  • 4 more comments
  • Anonymous Dec 06, 2008
    Same problem...
  • no blu-ray Dec 06, 2008
    I have the saem problem. I hear the menu screen but see nothing. When I insert a blue-ray, it loads then cuts off and my TV says "no signal", as if nothing was connected. When I eject the disc, the regular PS3 screen returns. Regular DVD's and CD's will play with no problem.
    I once did play blu-ray including the disk that came with it.
  • jornov Dec 29, 2008
    My 40 gig unit will not play blue ray. It did for 6 months and suddenly quit.
    It is very loud. Best buy says my unit is bad and will sell me another or an additional $108.
    Thank goodness I did not buy a 3,000 Sony HDTV.
    jornov@gmail.com
  • birdly23 Dec 29, 2008
    My blue ray player will play the movie for a few minutes and then freeze up. It then says that it couldn't read disc. What's the best way to go about fixing this.
  • Anonymous Jan 03, 2009
    be quiet
  • Anonymous Mar 03, 2009
    I bought my 80GB in South Korea when I was living there. Now I've moved to America. I looked up the Blue Ray region codes, and I was under the impression that South Korea and North America should have the same Blue Ray region. However, I was unable to play ANY blue ray disc I BOUGHT! It's an act of deception and violation of my rights from these companies!
    Scholar:
  • 65 Answers
If there is no picture on the TV screen: Back to top
  • Check that the input mode of the TV is appropriate for the connector in use on the PLAYSTATION®3 computer entertainment system.
  • There may be a problem with the cable in use. Try using another cable that is compatible with the PLAYSTATION®3.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
If the DVD or Blu-ray Disc™ (BD) cannot be played, or the picture is distorted: Back to top
  • When outputting DVD content or PLAYSTATION®3 system format software in SD resolution, only discs recorded in the NTSC standard can be played.
  • If the PLAYSTATION®3 is connected to a VCR or a combination TV/VCR unit, copy protection encoding on some DVDs and BDs may cause image distortion, or may cause the image to become lighter or darker. In such cases, connect the system to the TV directly.
  • If the DVD or BD does not match the region code set in the PLAYSTATION®3, it cannot be played.
  • Some DVDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to temporarily increase the viewer age restriction level.
  • Some BDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to change the parental control level.
  • The BD may be disc-locked. Enter the password that was set when the disc was created.
if non of that works you need to contact Sony at
1-800-345-7669 (SONY)
Mon - Sat 6:00AM - 8:00PM PST
Sun 7:00AM - 6:30PM PST
Good Luck,
-Rel
Posted on May 30, 2008
You can go to the main screen when you turn on the playstation and restore default settings. After doing this you will have to set up the playstation again but it should work.
Posted on Aug 12, 2009
I had my ps3 vertical all i did after resetting the settings was lay it down and and it acknowledges the discbut still wont play not sure if it helps anyone else googling this problem
Posted on Jan 10, 2010
Ist the PS3 connected to a HDTV? it needs to be connected to a HDTV for it to work (the 5 composite cables connection or a HDMI cable connection is required)
Posted on Dec 09, 2008
Vizio vbr210 error 11000404 How do I update firmware to watch newer blu ray movies?
I had the same problem -- we even returned the disc and got a new one. Go to the Vizio site and download the firmware for your player. Put it on a USB stick and plug it into the player. Follow the onscreen instructions (basically just press OK). The entire process takes less than 5 minutes from download to finish.
The Hunger Games works perfectly now.
Aug 21, 2012 | Vizio VBR210 Blu-Ray Player
My new 3.15 ps3 won't play blu-ray but will play everything else no problem. no problems to play games or to play normal dvd's. When playing a blu-ray the UNIVERSAL part at the start of the movie plays...
f the Blu-ray Disc does not support 1080p 24Hz video mode, the video output may not display properly.
If a Blu-ray Disc movie is not loading properly or is freezing on a title screen, this may be caused by the PLAYSTATION 3 attempting to download BD-Live content from congested movie studio servers. If you experience this issue, you may choose to temporarily bypass the BD-Live content until the congestion at the movie studio servers has cleared.
Go to Settings icon (Settings) > Video Settings icon (Video Settings) > [BD Internet Connection], select "Confirm". Then reload the Blu-ray movie and the PLAYSTATION 3 will prompt you if you wish to allow the disc to access BD-Live content. Choose to not access BD-Live content to see if the movie will now load.
For some reason you seem to think this is a PS3 problem. Why do you think this is a PS3 problem? If you can play PS3 games, then I will say it is not a PS3 problem, as all PS3 games are on Blu-ray, and if you were having problems playing PS3 games, then that could account for the movie not working.
Since only the movie isn't working, I am going to say you have a defective Blu-ray disc. Did you just buy this movie, or have you viewed it before using the PS3? If you have never viewed it on the PS3, then the problem lies in the disc, and you need to take it back and have it exchanged.
If you have played the disc in the PS3 before (the PS3 you are having a problem with, not a different PS3 or Blu-ray player), or you still think it is a PS3 problem, then use the "Disc Troubleshooting" support page. Normally, if a Blu-ray movie will not play, it won't play at all, and it is because the Blu-ray laser has gone out. It sounds to me that the disc is bad, but this is only going on the information you have supplied.
Here is the Disc Troubleshooting support page mentioned above:http://playstation.custhelp.com/app/answ…
**EDIT**
Sorry, I just noticed you gave a UK link. Here is the support page for the UK. You will have to do a search on the site to find the Disc Troubleshooting page for your region.http://uk.playstation.com/support/
**EDIT**
Okay, here is your Disc Troubleshooting page for the UK:http://faq.en.playstation.com/cgi-bin/sc…
Mar 27, 2010 | Sony Playstation 3 (PS3) Console
QuickPlay won't play one blu ray disc but plays all others.
I would take the movie back. We have found DVDs which cause similar problems.
Feb 03, 2010 | HP Pavilion dv9000z Notebook
Blu ray movies on PS3 - Black and White.
look through the system settings for anything that has to do with movie playback options
Jul 31, 2009 | Sony PS3 40GB Best Sellers Bundle Console
Can watch movies (not blu ray) and play ps2games (not ps3)
You need a new blu-ray laser. model number kes 400aaa. takes about 30mins to change out.
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
Blu-ray laser 40gb ps3 local
if your ur blue-ray wont play the movies try this 1st before you waste ur cash......Check the 24 Hz setting in the BD/Blu-ray setting area. Some televisions do not support this option. Turn it off. It will prevent blu-ray movies from playing.
Mar 30, 2009 | Video Game Consoles & Games
Problem with playing
Occasionally the software on most blu-ray players needs to be updated to the newest technology. The reason some discs play and some don't is because the discs that play are most-likely older movies or from a company that still used the "outdated" software. So the discs that don't play (most likely discs made with the updated software) won't play on your player until you've update the player's software. To do this visit, in your case, Sony's website for update info. There are a few ways you can get the info. You can download it directly to your player (if it has online accessibility) or you can request that they send you an update disc. Either way, most companies provide the update for free. Hope this helps, good luck!
Jan 14, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Ps3 won't play my ps3 disks or movies
sounds like the blu ray diode is burnt.
Send it to Sony for warranty replacement
Aug 30, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
6,597 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
