Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Terrible smell When I run the dishwasher there is a terrible smell.  It cleans fine.  I run the top one and there is water in the bottom trap that seems to be the source of the problem.  I turkey basted it out.  Ran rinse cycle with baking soda but it still stinks.
  • Lakebum Apr 18, 2008
    Yep, same thing. Water would not always drain. Take the rack out, then the arm (unscrew it), then the stainless pan thing. When you take it out, you'll notice some build up of stuff on the back side. I had a bunch of lent-like stuff clogging some of the holes. I scrubbed the entire thing - both sides and it drains much faster and smell is gone.
    Of course, this clogging led to the motor bearings going out I guess because the bearings went out and I have to now replace the motor component which sucks. So don't let this go too long... Now I need to find a source for the motor (Stator) part...
    Since the dishwasher drains through the sink/disposal, you might also check your drain trap under the sink.
  • Fisher and P... Master
  • 2,651 Answers
Yea disposers are most likely cause of odores backin up into the d/w's you can try running through a cycle with a bowl full of vinegar. the vinegar will flush put of the bowl during wash and get all the nooks and crannies clean
Posted on May 02, 2008
Should there be a little water left in the dishwasher
yeah there should be a bit but the bottom should also have dishwasher salt in there. this is the bottom. the salt helps kill smells also helps cleaning. when you bought the dishwasher it should of come with a funnel thats for filling the salt into the system.
Jun 08, 2017 | Frigidaire FGHD2433K 24 in Builtin...
Terrible smell inside the dishwasher. Bad drain smell
The smell usually comes when the unit is unable to drain water completely, you can run your dishwasher at its hottest temperature setting with 2 cups of vinegar inside the unit. After this take off the lower front panel and clean the drain pump assembly completely, also clean the drain hose, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Aug 05, 2011 | Dishwashers
What causes the pungent odor in dishwasher? It seems that the all the water are not being dried
Hi, this is a very common problem and can be sorted out easily, rather than explain it here i include some weblinks that explain it all in detail. plus my favorite below.
Here is one that takes the smells, hard water stains etc out of your dishwasher and plastic and glass ware. Fill up dishwasher, with plastic glasses, glass ware, dishware. No metal, of any kind! anything you want sparkly and clean.
No detergent! Fill up a small bowl at the Bottom of the dishwasher with vinegar, 1 cup of white. Run the cycle, do not dry. Fill up with 1 cup of bleach, run again. This takes care of all hard water stains, germs that are causing smell etc. Also check for food at the bottom of the dishwasher.
The site below explains WHY you get those smells.
Aug 19, 2010 | Samsung 24 in. DB5710DT Stainless Steel...
Dishes smell when they come out of the dishwasher
There is a new product out that works well for this problem.
It is called Affresh D, You can find it at most stores near the dishwashing detergents. It comes in a yellow bag.
Aug 01, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Dishes arent clean
We have had a terrible problem with dirty dishes after cycle since getting this dishwasher as a warranty replacement for a Maytag Jetclean (that worked WONDERFULLY but completely blanked out one day). I can't say I have a great answer for you, but our problem is apparently that there is not enough water for the cycle. This varies from time to time it seems like. We have good pressure in our home and good pressure going to the dishwasher, so the problem is possibly valves??? I don't know, we are waiting to see if this will fix the problem. We also have an element that glows and smells hot (could be due to low water also. These are the things I know--perhaps you could make sure you have good water pressure all the way up to the dishwasher to eliminate a water line problem.
Mar 19, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Bad smell in dishwasher, have cleaned and even used bleach. The smell just comes back. even smells on the dishes. the smell is like a stink bug.
Three things, dryer coil, food stuck inside.
Most washers have a one way valve on the drain and a water trap
created with the line, so no water or smell can go into the machine.
Check the valve, remove the hose,that should be under the sink,
wrap a cloth around it and blow,it should not be able to blow into it.
Then make sure the hose at some point go higher then where it
connects to the drain.
Fill a bucket and fill the washer until you see a little in the bottom of the machine, watch it for a few minutes to see if it drains, it
shouldn't, dump in a bottle of white vinegar and run the machine, make sure dry is off. Then run it again, do not add anything.
Feb 17, 2010 | KitchenAid 24 in. KUDI01ILBS Stainless...
My Ge Dishwasher (bought less than a yr ago....has a terrible odor. Vinegar solves it for a few days but comes back....any way to remove the ''basket'' to see if food is trapped?
Couple things you can check. One is check the drain and where it is connected, Usually into the disposal. If so then remove the hose and give it a good cleaning or re plaice. Sometimes the hose can fill up with small food particles from the dishwasher and remain stuck in there and work its way back into your clean water.
Also try this, run some hot water in your faucet, and smell the water, if your detecting a odor, then you may want to flush out your water heater, may be filled up with excess tank contaminates etc.
Good Luck!
Hope this helps you out.
Nov 04, 2009 | GE Dishwashers
Smells fishy
You probably have rotting food scraps in the food trap. Take the bottom arm off, remove the filter, and clean. You can also add some bleach to the bottom of the tank and run the dishwasher empty to sanitize the inside. Run a second empty load to rinse. This should help rid the dishwasher of the nasty smell.
Jul 05, 2009 | Dishwashers
There is a terrible smell in the dishwasher
All DW that I know of will have water sitting at the bottom.. it keeps the seal moist..check your drain line make sure its clean and not clog... when your DW goes into drain listen to see if its drainning like it did when you first used it... I'll check back later..
Jul 20, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
SHU43 Bosch Built-in dishwasher
Try running citric acid (3 tablespoons) through.
You can get it from a drug store.
Or, run 1/2 cup vinegar through.
Do this in both the dish washer and the disposal.
After doing this try running some water into the disposal and then see if the next time you run the dishwasher if it still smells.
You could be having a problem with water not staying in the drain trap under your sink that is why if you run water and fill the trap, then you will find out if it was the dry trap that caused the smell from sewer gases backing up into the house trough the garbage disposal.
Apr 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
537 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
