I do not think it is the water pump. The bearing on the pump seems to be ok. Would a bad top radiator hose cause the car to overheat? Any suggestions??
Try the overflow tank cap. The seal will go bad and not hold the psi causing the water to flow out this is something you will not always see which will cause the engine to overheat or temp gauge to rise. Also the thermostat could be sticking and cause the temp gauge to rise. Are the fans turning on when the temp gets high? If so then I would resort to the above first. If the fans are not coming on, the relay or fan/s could be the problem.
How is the thermostat? that would cause it to overheat, a warped head would cause it to over heat too
