Question about Superstar SS-121 120-Channels Base CB Radio
It's a two way cb radio and i need to know were i can send it or take it to get it working, it'a old a motorola cb bcb97110 fcc data cb1133 warr. no 250- A103202 921 please do'nt tell me i have to fix it on my own there's gota be someone out there still works on them. Name Gary Conner Phone number 269-983-2874
  • 391 Answers
Hi when you try to connect power to radio does it keep blowing fuses ,iff so remove the bottom panel/cover from the radio at the back of the radio where the power terminals enter the board you will see a black diode with a silver strip this is what we call a reversed or dummy diode remove this and your radio should work ok make sure to replace with new one you can find these in most cb radios goodlyck
Posted on Mar 16, 2011
I hooked up my superstar 121 backwards how can i fix it
Posted on Feb 17, 2011
How do i register my cb radio
not sure you need to anymore. several years ago they quit doing it check with the FCC .
Aug 02, 2015 | Cobra Radio Communications
How to I syncronize all my radios so they work together
Karen-
Contact Motorola Solutions
Get Support
Mark
Motorola Mobility Support
Jan 09, 2015 | Motorola 4 Magone Bpr40 Uhf
Can you expand the freq. range of the cobra 25 CB 40 channel radio
Yes its possible to do with the EXPO kits.. or an eeprom. but beware of the FCC rules please. RX purposes' only not to be used for Transmiting..
May 05, 2013 | Cobra 25 LTD 40-Channel CB Radio
I need the frequencies for this radio
Here's a list: Frequency Chart
Keep in mind - only those frequencies in "D" can be transmitted on in the US. These are the Citizen's Band (or C.B.) Radio frequencies. The others are above and below the FCC allotted range for CB. Transmitting on these other frequencies requires an FCC issued license.
You can face fines, imprisonment or both if caught transmitting without the proper license.
Nov 29, 2011 | Connex 3300 240-Channels Base CB Radio
Never will get caught , everyone should crank it...
FCC no longer monitors CB communications. As well they want little or nothing to do with issue reported about CB radios. The FCC has less then 16 field offices in the US today. They do not have the funding to police CB radio. Its also in the 27 MHZ band, which is only used today by CB radio, and toys.
Every thing else today is going up in frequency. Cell phones are in the 800mhz range etc. There is no money in the 27mhz band.
The FCC rarely fines any one with CB radio's runing illegal equipment. Nor do they even rarely make appearances at people dwellings who run illegal equipment when reported. At most they send a letter telling them to stop using illegal equipment.
And by no means would they even attempt to pay attention to some one running a barefoot radio that has been peaked and tuned and doing some where around 20 watts.
You would have to be running multiple kilowatts and have half of a town reporting you interfering with all of their appliances before they would be knocking at your door.
Never will get caught? Heh, Never will be paid attention to is more like it.
Oct 07, 2010 | Cobra 29 LTD CB Radio
I want to find out where to go to learn how to do cb radio repair
You will need to pass the 1st Class Radio Operators exam given by the FCC ... it is very riggorous ...
I dont know all the particulars ... but that is a place to start.
Apr 21, 2010 | Radio Communications
My friend would like to purchase a Connex CX 3400 HP. The store told him that it has to be converted to a CB radio. But they can't do it because its illegal. Can you explain this to me?
These radios are know as what's called 'export' radios. They are imported under the auspices of being a 10 Meter Amateur radio and then through a typically easy modification are made to allow the selection of US CB channels. usually the modification involves plugging in a loose connector inside the radio radio chassis and/or removing a jumper wire soldered to a circuit board. If there is a nearby CB Shop they will usually do this for a modest fee.
Keep in mind that a radio needs to be Type Accepted by the FCC to be legal to use on the CB band in the US and export radios typically are not. Be sure to check the rear label for an FCC ID number.
Feb 12, 2010 | Connex 3300 240-Channels Base CB Radio
Uniden marine radio
Cb radios are usally detuned to meet fcc regulations. The other radios usually are peaked out all the way.
Jan 28, 2009 | Uniden BC248CLT Base Scanner
10 meter portable
There is no factory made 10 meter CB Radio made for US use. CB Radios use 11 meters, and the FCC doesn't allow the combination of 10 and 11 meter radios combines. Although, many people modify 10 meter radios to work on the 11 meter ( CB ) band, it's not legal. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 15, 2007 | Magnum 257 CB Radio
Radio Communications Logo
116 people viewed this question
Top Superstar Radio Communications Experts
cwradio73
Andrew Taylor
Andrew Taylor
Mike carichael
Level 1 Expert
Are you a Superstar Radio Communication Expert? Answer questions, earn points and help others
