Question about Car Audio & Video
PIONEER DEH-1100 WIRING AND RCA PLUGS
I UNDERSTAND WHEN YOU USE THE RCA PLUGS THEY ARE THE BACK SPEAKERS BUT ARE THE WIRES THEN STILL HOT TO WHERE I COULD HOOK UP MORE FRONT SPEAKERS OFF THEM OR SHOULD I RUN THE SPEAKER IN A SERIES STYLE PATTERN
  • 323 Answers
You want to run the RCA's from your cd player to the amplifier. You want to run your front speakers off the speaker wires. I believe that is what you are asking.
Do you happen to have an after-market wiring harness for that cd player? That will save you a lot of problems! You can go to walmart and get one in most cases. Just look on the back and look for the model of the vehicle you need it for.
Posted on Apr 19, 2008
Power but no sound help plz....
well here we go how do you have your pioneer radio connected .
did you run the radio speaker wire out to the factory speaker or did you have an amp connected to the rca output jacks.
1 well if the radio connect by the speaker wire out the
output chip in the radio is fried and needs repair ....
2. if u have a amp connected to power your speakers for sound
check the amp to make sure you have power and no lose connection or speaker wires disconnected.
3. it also possible that the rca jacks are fried too
I no by experience that pioneer loses ground on the audio output jack (rca) well what we did to fix it is..
take and 18 gauge wire stripe back about 1/2" to 1" of the insulation to expose the copper wire and wrap this around the metal casing of the rca jacks and then ground the wire to a ground point do this for both left and right rca jacks...
radiorepair@windowtintingin239.com
Oct 30, 2013 | Pioneer DEH-P3500 CD Player
Installed my Pioneer DEH-1100MP When radio is turned on display /tuner/aux comes up Can set stations etc but no sound With light tester to speaker wires there is power etc
Does your car have a Factory amp if so u need to find the blue wire ( on most cars) and either ground it out or and power to it, it should turn the speakers on for you to play
Sep 10, 2010 | Pioneer DEH-1100 CD Player
Hi I'd like to be able to play my Ipod through my pioneer deh-p3600, but i understand I'Il have to buy something extra to allow for an RCA input at the back. Can anyone help with what this would be? Or...
they sell cords at best buy that plug into the headphone jack on ur ipod an the other end has the rca jacks just plug the rca,s into the input rca,s on the back of the deck the rca wires are only 15 bucks at best buy. or u can buy these oneshttp://www.crutchfield.com/p_130DEHP360/Pioneer-DEH-P3600.html?tp=5684&tab=other_items#iPod Adapters
Oct 05, 2009 | Pioneer DEH-P3600 CD Player
Wiring my pioneer deh -p2000 to my speekers
Check the back of your receiver, to see the plug with a set of 8 wires that should have the following color standard:
Left front: White
Right Front: Grey
Left Rear: Green
Right Rear: Purple
Note: 1) Colored wires with a line/stripe on it is NEGATIVE, thus connect to negative on speaker. When connected, speaker cone should vibrate OUT, not inwards, otherwise reverse speaker connection;
2) You can check to see if speakers are in the right order by 'panning' balance and fader controls (from left front only to right front only, to right rear only, to left rear only in succession)
3)If there is an amplifier in your setup, the RCA plugs (like home audio plugs, should be connected instead, NEVER both!)
Hope this helps
Mark
Sep 25, 2009 | Pioneer DEH-P2000 CD Player
Need a wire diagram for pioneer DEH-1100 super tuner
Usually it's....
black = ground
red = switched battery power
yellow = constant batery power (for clock...etc)
orange = illumination
blue = amplifier turn on or accessory (electric antenna, amps etc)
green/white/purple/grey are speaker wires.
Apr 25, 2009 | Car Audio & Video
Pioneer DEH-P2900MP head unit
There is no power from the rca jacks. Option 1; connect the speaker wires directly. Any aftermarket auto manual (Hayes, Clymer) with wiring schematics will let you know what wire is what in the dash. Option 2; RCA jacks output to an amplifier. There is no power coming from the RCA jacks. They have to be used with the amp. If you chose to use the normal speaker wires, be aware that these radios do not like stock speakers or wire. If you take the time and money to replace all of it, the head unit will last much longer. If you choose to use an amplifier, it will burn out fast unless you replace the speakers and wires immediately.
Mar 04, 2008 | Pioneer DEH-P2900MP CD Receiver...
Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Dec 11, 2007 | Pioneer DEH-P6900UB CD Player
Wiring my tuner-DEH-1800 to Amp GM-5300-T into my 4 speaker system.
In most head units as in your case the Pioneer DEH-1800, there would be 2 RCA female jacks at the rear of the unit. These are your OUTPUTs.
While in most amps including your GM-5300-T, there would similar RCA jacks which would be your INPUTs.
You need to connect the output to the input using an audio cable terminated at both ends with RCA plugs. Further you need to connect the remote trigger on from the head unit to the remote/external amp to switch it on.
A more comprehensive connection diagram is available at page 6 of the GM-5300T Manual which may be downloaded from here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Pioneer DEH-1800 CD Player
Car Audio & Video Logo
281 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
