Question about Gateway MT3705 Notebook
Fails to boot
I have a gateway MT3705 that fails to boot. When I first turn it on it will start to boot (windows splash) and then goes to a "failed windows boot, look for problems" search. It runs for about 3 minutes then freezes. I turn the computer off and then restart, the fan and hard drive are going but the lcd is dark. If I keep it turned off for 10 or so minutes it starts back up and repeat the failed boot test. I tried a boot disk, but that freezes also after 3-5 minutes.
  • 1 more comment
  • MissingNHL Apr 17, 2008
    I tried the Hirens Boot CD, I can boot off the cd but the pc still freezes after 3-5 minutes. Now I cannot even get it too boot off of the cd, just a flashing cursor when I power it up.
    With some more playing around I got the boot disk to work again, however I am getting freezing and a crackle from the speakers after I make each selection on the keyboard (ie arrow keys up/down).
  • nocturnal247 Dec 30, 2008
    Almost same problem here.... power on, DOS bootup screen, then hangs. Doesnt try to boot. You can press F2 for "SETUP" but it doesnt load.
    Whats wrong ?
    Genius:
  • 1,027 Answers
You might try a Hirens Boot CD, un-zip the files, create a bootable cd from the .ISO file and boot your troubled system, select virus scan on boot.
Posted on Apr 16, 2008
  • Mark Williams
    Mark Williams Apr 17, 2008
    Since the boot cd loads into RAM memory and bypasses the hard drive you have eliminated that. So now we are back to Bad motherboard or Processor.
  • Mark Williams
    Handy little tool set that boot cd.
Gateway zx4351 operating system missing
When did you get this Gateway? Where did you get it? I assume you mean that it has no OS, cause Gateway does NOT make an operating System. Need more details, please!
Nov 08, 2014 | Computers & Internet
Tip
Quit the Registry Editor and log off
Automate the above task using this utility
This tiny utility provides you the option to choose a color from the Color Picker dialog and can reset the logon Wallpaper if you want. Choose your preferred Color and click Apply Background color. Remove Logon Screen wallpaper option clears the logon
How to disable the Windows XP Splash Screen / logo at startup ?
To disable the Windows XP splash screen (logo) at startup, and to see the list of drivers loading at startup, follow these steps:
Click Start, Run and type MSCONFIG
Click the Boot.ini tab
Under Operating Systems section, select the appropriate entry and then enable the /SOS switch in the Boot Options section below
Click OK and close MSCONFIG utility.
The corresponding entry in the Boot.ini file is automatically added. Example given below:
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect
becomes
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect /sos
The /sos parameter displays the names of the drivers as they load during the boot process. Use when startup fails (while loading drivers) to determine which driver is failing to load. See Boot Parameter Reference for more information.
Also see /noguiboot parameter, which can also disable the splash screen.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
My toshiba tablet won't let me go past the welcome screen
If this is under warranty take it back. If it isn't power the unit on with just the battery powering the unit. When you see the Windows splash screen drop the battery out after the screen goes black put the battery back in and press the power button. This should bring up the on screen menu telling you it failed to start or shut down correctly. Select, Boot in Safe Mode and see if the system will power on. If that fails you need to do a system restore. To access system restore options power the unit on and press and hold the F10 key, this will bring up the restore Windows options. From that menu select to restore your operating system. If that fails you will have to do a complete restore to factory default settings. If that fails you will have to replace the hard drive.
Dec 25, 2011 | Toshiba Tablets & eReaders
When i turn on it goes start to pc entering power saving mode
Are you sure it isn't the monitor entering powersave mode?
An unhooked monitor (especially flatscreen DELLs ) will go into powersave mode if it isn't getting a signal but is getting power.
First unplug and then replug your monitor. Both ends of the cord, the end in the back of the monitor (if it comes out at all) and the end that plugs into the computer.(unplug it from the wall first)
Reboot computer.
If that fails...(and you do have a video card)
Unplug everything from the computer, open the box, ground yourself by touching the metal frame of the computer case and reseat your video card....you may have to undo one screw to get it out.
DON'T drop the screw into the case!
Put it all back together and try again.
If that all fails Boot Windows (windows right?) into safe mode and change the power settings for the monitor...perhaps something got changed or broken by an update.
If that fails....
Get Linux.
TickMagnet
Aug 17, 2011 | Gateway 505GR PC Desktop
Pxe-e61: media test failure check cable pxe-m0p:exiting broadcom pxe rom operating system not found
Normally, your laptop should be configured to boot up from the hard drive before trying the network boot up. When the hard drive fails or is no longer available, or the boot up sequence in BIOS Setup has been changed so that the network boot is set before the hard drive, the symptom you describe fails.
I would recommend that you do the following:
1. Check BIOS Setup & make sure the boot sequence is set in the correct order (Hard Drive 0 should be before Network Boot).
2. Make sure that the hard drive is seated properly in its slot & that all connections are tight.
3. Make sure that the hard drive powers up when you turn on the laptop.
If none of this helps, then your hard drive has failed.
Mar 08, 2011 | Gateway MT3705 Notebook
Installed RAM and now monitor has no display. I
The splash screen with the LG Flatron logo is the monitor's splash screen not the PCs.
The machine is NOT booting up the splash screen is the monitor coming on.
Remove the 1Gb stick an see if the machine performs normally.
If it does then power it off, remove the power cord and CAREFULLY reinstall the new stick.
If it fails to boot you may have a defective memory module.
If the machine fails to boot with the new stick removed make sure you have the original memory seated properly and all cables securely attached
Jan 03, 2011 | EliteGroup Computers & Internet
Nv52 sound card drivers for XP does not work
This problem is listed under MT3705 notebook, which doesnt use NV52 drivers but sigmatel
http://support.gateway.com/support/drivers/search.asp?st=pn&param=1014142R
If all else fails remove the drivers restart PC and get windows update to try and solve it.
Aug 02, 2009 | Gateway MT3705 Notebook
Explorer Fails to Start
Do you have all the latest patches and are you sure you computer is free of virus or malware? If you feel you are protected then did this occur shortly after an MS Patch/update. Check and see if you can either unistall the last patch or boot to the last known good configuration (press F8 between the bios splash screen and the windows splash screen at boot up). If you are not up to date on your security, then start with that and then work your way into a repair...
Jul 08, 2009 | Microsoft Windows Vista Home Basic Edition
Starting
The error you are receiving is indicating that the Windows Operating System settings cannot be located on your hard drive to complete the loading of Windows. There are several possible causes, starting with a hardware failure of the hard drive. Others could involve a corruption of the registry due to unknown causes.
The first thing to try is the F8 menu during boot (Start tapping F8 when you see the Gateway Splash Screen) and try to boot to the SAFE MODE. If that fails, boot to F8 again and select the Last Known Good option on the menu.
If that fails to boot to windows, then recovering the OS doesn't look to optimistic. Other options are bootcfg /rebuild to check and see if the boot.ini file is corrupted
http://support.microsoft.com/kb/291980/en-us
and if that fails I suggest running diagnostics on the hard drive.
A longer shot at recovering the OS is what is known as a HIVE copy in the recovery console. This is essentially a system restore done manually in the recovery console, and is the last ditch effort before reinstalling Windows. Steps for Hive copy are at the bottom of this post:
http://dellcommunity.com/supportforums/board/message?board.id=dim_other&thread.id=210955
Jul 19, 2008 | Gateway GT5220 PC Desktop
No screen after Boot
Try booting to the safe mode (f8) and see if there is any difference. If there is no difference, the video adapter is most likely failing.
If you can boot into the safe mode, then reboot and try the vga mode on the same menu, if you can boot to the desktop, then try to increase the resolution. if it fails, try a new video driver.
Jun 01, 2008 | HP Compaq Presario V2000 Notebook
Gateway MT3705 Notebook Logo
335 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
