Laptop shuts off after powered on omnibook 6000 It runs for a few seconds and shuts down .... it that a bad power supply or what?
    Scholar:
  • 55 Answers
You might have a broken or dirty CPU fan. The CPU heat sink fan is responsible to cool down your CPU while it is on. If it is broken or stuck(dirty), then your machine will power off automatically preventing CPU damage or worse-case-scenario:FIRE caused by "burnout".
Your CPU heat sink might not be mounted on your LT properly. Also causing overheating; thus shutting down.
Its a laptop right ? Right! Another thing you could try is to unplug the battery, and let it run from AC power only and see if it makes any difference.
Posted on Apr 16, 2008
Dell inspiron 6000 dead when connect power adeptor to laptop the led light on psu goes off is this mother board fault or psu.
If the led on the power supply turns off after connecting it to your laptop, the problem most likely lies with the power supply especially if the machine will run on battery power. This can be tested by
1. Turn the laptop off.
2. Remove the battery and power supply plug.
3. Press and hold the power button for at least 15 seconds to reset the laptop.
4. Replace the power supply plug into the laptop without replacing the battery.
5. If the computer will not start and there are no lights turning on on the laptop the power supply is bad.
6. Replace the battery and attempt to start the machine both with and without the power supply plugged in.
Apr 04, 2011 | Dell Inspiron 6000 Notebook
The computer suddenly shut down & will not re-boot. On turning on there may be a few seconds to allow option of opening up in safe mode which is applied but within a few seconds the system shuts down...
Bad Power Supply.
Weak voltage power rail.
One of the leading causes of computer failure.
Replace the Power Supply.
[The next cause of failure is the computer is dirty inside, as well as inside the Power Supply's case.
Dirt, dust, etc, takes a Power Supply down quick ]
Need guidance of how to replace your Power Supply, or guidance in finding a decent replacement Power Supply let me know in a Comment.
Regards,
joecoolvette
Dec 02, 2010 | Packard Bell Computers & Internet
I have a dell inspiron 6000 laptop When i press the start button the power lights stay on for about 5 seconds , then it switches off again. I dose not seam to engage the the operating system I would like...
Check that your power supply/AC adpater is plugged in and working. It could be that you are running on the battery only and if the battery is drained, it tries to start then shuts down again.
Feb 11, 2010 | Dell Inspiron 6000 Notebook
Inspiron 6000 starts to boot but then shuts down after only 10 seconds. New Battery, power supply measures ok. Caps lite is on.
Try reseating the RAM memory modules, see if any change.
If no change, remove, battery, Drives, Wireless card and RAM, see if the system will run longer or give an error code. If something changes, add 1 RAM module and try again. If the system runs, then add items back one at a time until you determine the faulty item.
If the system issue doesn't change, odds are a motherboard problem. Motherboard are about $100 on Ebay
Dec 06, 2009 | Dell Inspiron 6000 Notebook
I have a hp omnibook 4150 it beeps 1-3-3-1 but does not power up whats wrong
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Dec 04, 2009 | HP OmniBook 4150 PC Notebook
My A215 wont stay powered up. It shut down and
Try running the computer on the Battery power and check if the power sustains. If not, then disconnect the power cord and remove the battery and leave it for a few hours then try turning it on.
If the problem exists then the power supply unit is required to be replaced. You may contact service center to get the power supply unit replaced.
Oct 01, 2009 | Toshiba Satellite A215-S7422 Notebook
Where is the resest button for my omnibook xe3 laptop
Their is no reset button for this laptop. Pushing the power button and holding it down for a few seconds will force a shutdown if that is what you are looking for. Laptops aren't like PDA's where you stick a nail in a little hole and it reboots the system.
Armymason
Mar 02, 2009 | HP OmniBook XE3 Notebook
Omnibook 6000 will not run POST. Has LEDs permanently on
When was the last time a BIOS update was done? See if one is available for this laptop and give it a try. FOLLOW THE INSTRUCTIONS TO THE LETTER WHEN DOING THIS OR YOU CAN RENDER THE LAPTOP INOPERABLE!! If youre not comfortable doing this, have a service technician do it for you. Sounds like the problems really went into overdrive when the new drive was installed.
Feb 28, 2009 | HP OmniBook 6000 Notebook
Flashing lightning bolt on Compaq C300
This sounds like a battery problem. The best way to test this is to remove the battery and then power the laptop up with just the power cord plugged in but no battery. If the computer boots then the battery is bad you will need a replacement. Also try letting the battery charge for a day. Be sure that the charging light is coming on when you have it plugged in.
Dec 09, 2008 | Compaq Presario Notebook
Asus a8v-vm se fans always run
Hi jderek4, try this. locate the toggle switch on the back of the power supply. Just find it do not flip it.
Plug the PSU's power cord into the PC. Just as you got a good connection & the PC begains to power up move the toggle switch to it's other position. The PC should power off that very second.
If the PC does not shut off than the PSU is bad. If it did shut down wait a few seconds. Press the cases power on button. The PC should start to boot up. Let it finish loading. Click the start button & choose to shut down windows. The PC should shut off.
Yes? If not than your back to (bad power supply). Swap it out.
Mike
Mar 29, 2008 | ASUS A8V-VM Motherboard
Computers & Internet Logo
David Payne
David Payne
